Автор Гілка: Garnome 2.20  (Прочитано 2766 раз)
Відсутній Dimon-z
  • дописів: 3
Garnome 2.20
« : 2008-03-30 12:08:39 »
Допоможiть,у мене така проблемма,коли доходить до збiрки xrender,то выдиае помилку
checking for X... no
configure: error: X is required, but it was either disabled or not found.
Коли вказав   --x-includes=/usr/X11R6   --x-libraries=/usr/X11R6
то ось яка помилка
checking for X... libraries /usr/X11R6, headers /usr/X11R6
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking for XTHREADS in Xlib... yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for RENDER... no
checking X11/extensions/render.h usability... no
checking X11/extensions/render.h presence... yes
configure: WARNING: X11/extensions/render.h: present but cannot be compiled
configure: WARNING: X11/extensions/render.h:     check for missing prerequisite headers?
configure: WARNING: X11/extensions/render.h: see the Autoconf documentation
configure: WARNING: X11/extensions/render.h:     section "Present But Cannot Be Compiled"
configure: WARNING: X11/extensions/render.h: proceeding with the preprocessor's result
configure: WARNING: X11/extensions/render.h: in the future, the compiler will take precedence
configure: WARNING:     ## ------------------------------------------ ##
configure: WARNING:     ## Report this to the AC_PACKAGE_NAME lists.  ##
checking for X11/extensions/render.h... yes
checking X11/extensions/renderproto.h usability... no
checking X11/extensions/renderproto.h presence... yes
configure: WARNING: X11/extensions/renderproto.h: present but cannot be compiled
configure: WARNING: X11/extensions/renderproto.h:     check for missing prerequisite headers?
configure: WARNING: X11/extensions/renderproto.h: see the Autoconf documentation
configure: WARNING: X11/extensions/renderproto.h:     section "Present But Cannot Be Compiled"
configure: WARNING: X11/extensions/renderproto.h: proceeding with the preprocessor's result
configure: WARNING: X11/extensions/renderproto.h: in the future, the compiler will take precedence
checking for X11/extensions/renderproto.h... yes
checking for xAnimCursorElt... no
configure: error: Render headers too old. Version 0.8 or later is required.
як виправити?
Re: Garnome 2.20
« Відповідей #1 : 2008-03-30 14:47:00 »
Render headers too old. Version 0.8 or later is required.Яка у Вас версія Slackware і яку версію xrender там встановлено?
