Автор Гілка: Очистити диск  (Прочитано 8994 раз)
Відсутній Djalin
  • дописів: 662
Re: Очистити диск
« Відповідей #15 : 2017-09-02 23:13:42 »
Вибчаюсь за затримку - трохи прихворів - отож
lspci -vvnn -s "0000:00:1c.5"
Показав
djalin@djalin-X302UA:~$ lspci -vvnn -s "0000:00:1c.5"
00:1c.5 PCI bridge [0604]: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 [8086:9d15] (rev f1) (prog-if 00 [Normal decode])
    Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Latency: 0
    Interrupt: pin B routed to IRQ 124
    Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
    I/O behind bridge: 0000c000-0000cfff
    Memory behind bridge: dfa00000-dfafffff
    Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
    BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
        PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
    Capabilities: <access denied>
    Kernel driver in use: pcieport
    Kernel modules: shpchp
через sudo  каже більше
djalin@djalin-X302UA:~$ sudo lspci -vvnn -s "0000:00:1c.5"
[sudo] пароль до djalin:
    Latency: 0
    Capabilities: [40] Express (v2) Root Port (Slot+), MSI 00
        DevCap:    MaxPayload 256 bytes, PhantFunc 0
            ExtTag- RBE+
        DevCtl:    Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
            RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop-
            MaxPayload 128 bytes, MaxReadReq 128 bytes
        DevSta:    CorrErr+ UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
        LnkCap:    Port #6, Speed 8GT/s, Width x1, ASPM L1, Exit Latency L0s <1us, L1 <16us
            ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp+
        LnkCtl:    ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk+
            ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
        LnkSta:    Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive+ BWMgmt+ ABWMgmt-
        SltCap:    AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
            Slot #9, PowerLimit 10.000W; Interlock- NoCompl+
        SltCtl:    Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
            Control: AttnInd Unknown, PwrInd Unknown, Power- Interlock-
        SltSta:    Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
            Changed: MRL- PresDet- LinkState-
        RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
        RootCap: CRSVisible-
        RootSta: PME ReqID 0000, PMEStatus- PMEPending-
        DevCap2: Completion Timeout: Range ABC, TimeoutDis+, LTR+, OBFF Not Supported ARIFwd+
        DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis+, LTR+, OBFF Disabled ARIFwd-
        LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
             Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
             Compliance De-emphasis: -6dB
        LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
             EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
    Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
        Address: fee00298  Data: 0000
    Capabilities: [90] Subsystem: ASUSTeK Computer Inc. Sunrise Point-LP PCI Express Root Port [1043:1050]
    Capabilities: [a0] Power Management version 3
        Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
        Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
    Capabilities: [100 v1] Advanced Error Reporting
        UESta:    DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
        UEMsk:    DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
        UESvrt:    DLP+ SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
        CESta:    RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
        CEMsk:    RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
        AERCap:    First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
    Capabilities: [140 v1] Access Control Services
        ACSCap:    SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd- EgressCtrl- DirectTrans-
        ACSCtl:    SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
    Capabilities: [220 v1] #19
« Змінено: 2017-09-02 23:15:56 від Djalin »
Відсутній Djalin
  • дописів: 662
Re: Очистити диск
« Відповідей #16 : 2017-09-02 23:20:39 »
При переході в корінь ніц не змінилось
djalin@djalin-X302UA:~$ cd /
djalin@djalin-X302UA:/$ ls
0    boot   dev  home        initrd.img.old  lib64       media  opt   root  sbin  srv  tmp  var      vmlinuz.old
bin  cdrom  etc  initrd.img  lib             lost+found  mnt    proc  run   snap  sys  usr  vmlinuz
djalin@djalin-X302UA:/$ sudo du -hsx
15G    .
[code]
щось явно не те - почитаю про цю команду - мо щось змінилось чи я не так роблю...
ncdu - поставив - дивлюся
Re: Очистити диск
« Відповідей #17 : 2017-09-03 00:26:13 »
У du ви як аргумент вказуєте директорію чи список директорій, яким треба підрахувати розмір (див. мій приклад). -s — для сумування результату і показу лише кінцевої цифри, -h — для використання K M G замість гігантських чисел, -x — для того, щоб воно працювало в межах однієї файлової системи. Віртуальні файлові системи на кшталт /dev, /proc, /sys можуть видавати дивні результати, але то нормально.
По вмісту часопису нічого не скажу, не стикався, але ясно, що проблема полягає не в тому, що в лог щось пишеться і він розростається, а в тому, що є якась проблема з залізом чи дровами.
Edit:
Гугл каже, що проблему може вирішити додавання pci=noaer до аргументів завантаження ядра.
Edit:
Також я б спробував поставити новіше ядро (hwe?)
« Змінено: 2017-09-03 00:41:59 від Михайло Даниленко »
Відсутній Djalin
  • дописів: 662
Re: Очистити диск
« Відповідей #18 : 2017-09-03 01:17:32 »
Новіше ядро мені подобається більше - але тоді що порадите - ставити тестовий дебіан?
Убунта ніби остання
До речі про дебіан - чи є сенс ставити не назву а стан - наприклад testing?
« Змінено: 2017-09-03 01:20:27 від Djalin »
Миха́йло Даниленко
Re: Очистити диск
« Відповідей #19 : 2017-09-03 03:08:13 »
Можна спробувати щось таке: https://wiki.ubuntu.com/Kernel/MainlineBuilds
У мене постійно testing (на ноуті). Раз на пару тижнів оновлюю систему — проблем зазвичай не виникає.
gdekjifgb
Re: Очистити диск
« Відповідей #20 : 2017-09-03 12:15:43 »
а з яким залізом проблема? з віфійною карткою? І на що конкретно дивитись у виводі lspci ?
https://linux.org.ua/index.php?topic=11213.msg201220#msg201220
s:/home/xuser# du /250/* -h 2>/dev/null |sort -rh |head -n20
djalin2
Re: Очистити диск
« Відповідей #21 : 2017-09-05 16:46:22 »
Ситуація не виправилась, логи все одно пухнуть
kern.log
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] Linux version 4.12.0-12-generic (buildd@lcy01-21) (gcc version 7.1.0 (Ubuntu 7.1.0-13ubuntu1) ) #13-Ubuntu SMP Thu Aug 17 16:13:25 UTC 2017 (Ubuntu 4.12.0-12.13-generic 4.12.
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.12.0-12-generic.efi.signed root=UUID=ab273808-471d-4a6a-8a80-b9a75b6ba6d7 ro quiet splash vt.handoff=7
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] KERNEL supported cpus:
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   Intel GenuineIntel
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   AMD AuthenticAMD
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   Centaur CentaurHauls
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] e820: BIOS-provided physical RAM map:
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009ffff] usable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000081a6bfff] usable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x0000000081a6c000-0x0000000081a6cfff] ACPI NVS
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x0000000081a6d000-0x0000000081a96fff] reserved
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x0000000081a97000-0x0000000081ae8fff] usable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x0000000081ae9000-0x0000000081f29fff] reserved
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x0000000081f2a000-0x0000000085240fff] usable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x0000000085241000-0x0000000085f1cfff] reserved
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x0000000085f1d000-0x00000000862b1fff] usable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x00000000862b2000-0x0000000087127fff] ACPI NVS
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x0000000087128000-0x0000000087f85fff] reserved
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x0000000087f86000-0x0000000087ffdfff] type 20
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x0000000087ffe000-0x0000000087ffefff] usable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x0000000088000000-0x00000000880fffff] reserved
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BIOS-e820: [mem 0x0000000100000000-0x0000000273ffffff] usable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] NX (Execute Disable) protection: active
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] efi: EFI v2.40 by American Megatrends
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] efi:  ESRT=0x87ec4e18  ACPI=0x863b6000  ACPI 2.0=0x863b6000  SMBIOS=0xf05e0  SMBIOS 3.0=0xf0600  MPS=0xfca40
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] SMBIOS 3.0.0 present.
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] DMI: ASUSTeK COMPUTER INC. X302UA/X302UA, BIOS X302UA.206 02/22/2016
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] e820: last_pfn = 0x274000 max_arch_pfn = 0x400000000
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] MTRR default type: write-back
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] MTRR fixed ranges enabled:
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   00000-9FFFF write-back
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   A0000-BFFFF uncachable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   C0000-FFFFF write-protect
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] MTRR variable ranges enabled:
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   0 base 00C0000000 mask 7FC0000000 uncachable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   1 base 00A0000000 mask 7FE0000000 uncachable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   2 base 0090000000 mask 7FF0000000 uncachable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   3 base 008C000000 mask 7FFC000000 uncachable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   4 base 008A000000 mask 7FFE000000 uncachable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   5 base 0089000000 mask 7FFF000000 uncachable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   6 base 0088800000 mask 7FFF800000 uncachable
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   7 disabled
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   8 disabled
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   9 disabled
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] e820: last_pfn = 0x87fff max_arch_pfn = 0x400000000
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] found SMP MP-table at [mem 0x000fcc60-0x000fcc6f] mapped at [ffff8aa9c00fcc60]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] esrt: Reserving ESRT space from 0x0000000087ec4e18 to 0x0000000087ec4e50.
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] Scanning 1 areas for low memory corruption
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] Base memory trampoline at [ffff8aa9c0095000] 95000 size 24576
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] Using GB pages for direct mapping
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BRK [0x56d24000, 0x56d24fff] PGTABLE
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BRK [0x56d25000, 0x56d25fff] PGTABLE
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BRK [0x56d26000, 0x56d26fff] PGTABLE
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BRK [0x56d27000, 0x56d27fff] PGTABLE
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BRK [0x56d28000, 0x56d28fff] PGTABLE
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BRK [0x56d29000, 0x56d29fff] PGTABLE
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BRK [0x56d2a000, 0x56d2afff] PGTABLE
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BRK [0x56d2b000, 0x56d2bfff] PGTABLE
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BRK [0x56d2c000, 0x56d2cfff] PGTABLE
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] BRK [0x56d2d000, 0x56d2dfff] PGTABLE
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] Secure boot could not be determined
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] RAMDISK: [mem 0x32243000-0x35118fff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: Early table checksum verification disabled
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: RSDP 0x00000000863B6000 000024 (v02 _ASUS_)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: XSDT 0x00000000863B60A0 0000BC (v01 _ASUS_ Notebook 01072009 AMI  00010013)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: FACP 0x00000000863DAFA8 00010C (v05 _ASUS_ Notebook 01072009 AMI  00010013)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: DSDT 0x00000000863B61F8 024DAA (v02 _ASUS_ Notebook 01072009 INTL 20120913)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: FACS 0x0000000087126F80 000040
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: APIC 0x00000000863DB0B8 000084 (v03 _ASUS_ Notebook 01072009 AMI  00010013)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: FPDT 0x00000000863DB140 000044 (v01 _ASUS_ Notebook 01072009 AMI  00010013)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: FIDT 0x00000000863DB188 00009C (v01 _ASUS_ Notebook 01072009 AMI  00010013)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: MCFG 0x00000000863DB228 00003C (v01 _ASUS_ Notebook 01072009 MSFT 00000097)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: HPET 0x00000000863DB268 000038 (v01 _ASUS_ Notebook 01072009 AMI. 0005000B)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: SSDT 0x00000000863DB2A0 000315 (v01 SataRe SataTabl 00001000 INTL 20120913)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: ECDT 0x00000000863DB5B8 0000C1 (v01 _ASUS_ Notebook 01072009 AMI. 00000005)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: LPIT 0x00000000863DB680 000094 (v01 INTEL  SKL-ULT  00000000 MSFT 0000005F)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: SSDT 0x00000000863DB718 000248 (v02 INTEL  sensrhub 00000000 INTL 20120913)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: DBGP 0x00000000863DB960 000034 (v01 INTEL           00000000 MSFT 0000005F)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: DBG2 0x00000000863DB998 000054 (v00 INTEL           00000000 MSFT 0000005F)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: SSDT 0x00000000863DB9F0 003E21 (v02 DptfTa DptfTabl 00001000 INTL 20120913)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: SSDT 0x00000000863DF818 005863 (v02 SaSsdt SaSsdt   00003000 INTL 20120913)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: UEFI 0x00000000863E5080 000042 (v01                 00000000      00000000)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: SSDT 0x00000000863E50C8 000E58 (v02 CpuRef CpuSsdt  00003000 INTL 20120913)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: BGRT 0x00000000863E5F20 000038 (v01 _ASUS_ Notebook 01072009 AMI  00010013)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: DMAR 0x00000000863E5F58 0000F0 (v01 INTEL  SKL      00000001 INTL 00000001)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: TPM2 0x00000000863E6048 000034 (v03        Tpm2Tabl 00000001 AMI  00000000)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: Local APIC address 0xfee00000
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] No NUMA configuration found
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] Faking a node at [mem 0x0000000000000000-0x0000000273ffffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] NODE_DATA(0) allocated [mem 0x273fd3000-0x273ffdfff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] Zone ranges:
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   Normal   [mem 0x0000000100000000-0x0000000273ffffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   Device   empty
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] Movable zone start for each node
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] Early memory node ranges
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   node   0: [mem 0x0000000000001000-0x0000000000057fff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   node   0: [mem 0x0000000000059000-0x000000000009ffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   node   0: [mem 0x0000000000100000-0x0000000081a6bfff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   node   0: [mem 0x0000000081a97000-0x0000000081ae8fff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   node   0: [mem 0x0000000081f2a000-0x0000000085240fff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   node   0: [mem 0x0000000085f1d000-0x00000000862b1fff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   node   0: [mem 0x0000000087ffe000-0x0000000087ffefff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   node   0: [mem 0x0000000100000000-0x0000000273ffffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x0000000273ffffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] On node 0 totalpages: 2068745
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   DMA zone: 64 pages used for memmap
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   DMA zone: 29 pages reserved
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   DMA zone: 3998 pages, LIFO batch:0
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   DMA32 zone: 8454 pages used for memmap
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   DMA32 zone: 541035 pages, LIFO batch:31
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   Normal zone: 23808 pages used for memmap
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000]   Normal zone: 1523712 pages, LIFO batch:31
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] Reserving Intel graphics memory at 0x0000000089000000-0x000000008affffff
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: PM-Timer IO Port: 0x1808
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: IRQ0 used by override.
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: IRQ9 used by override.
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] Using ACPI (MADT) for SMP configuration information
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0x00058000-0x00058fff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0x81a6c000-0x81a6cfff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0x81a6d000-0x81a96fff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0x81ae9000-0x81f29fff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0x85241000-0x85f1cfff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0x862b2000-0x87127fff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0x87128000-0x87f85fff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0x87f86000-0x87ffdfff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0x87fff000-0x87ffffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0x88000000-0x880fffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0x88100000-0x88ffffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0x89000000-0x8affffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0x8b000000-0xdfffffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
Sep  5 16:36:05 djalin-X302UA kernel: [    0.000000] e820: [mem 0x8b000000-0xdfffffff] available for PCI devices
[code]
сіслог
[code]
Sep  5 16:36:05 djalin-X302UA rsyslogd: [origin software="rsyslogd" swVersion="8.16.0" x-pid="698" x-info="http://www.rsyslog.com"] start
Sep  5 16:36:05 djalin-X302UA rsyslogd: rsyslogd's groupid changed to 108
Sep  5 16:36:05 djalin-X302UA rsyslogd: rsyslogd's userid changed to 104
Sep  5 16:36:05 djalin-X302UA systemd[1]: Started Create list of required static device nodes for the current kernel.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Started Uncomplicated firewall.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Starting Create Static Device Nodes in /dev...
Sep  5 16:36:05 djalin-X302UA systemd[1]: Started Create Static Device Nodes in /dev.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Starting udev Kernel Device Manager...
Sep  5 16:36:05 djalin-X302UA systemd[1]: Mounted Kernel Debug File System.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Mounted POSIX Message Queue File System.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Mounted Huge Pages File System.
Sep  5 16:36:05 djalin-X302UA systemd-modules-load[254]: Inserted module 'lp'
Sep  5 16:36:05 djalin-X302UA systemd[1]: Started Set the console keyboard layout.
Sep  5 16:36:05 djalin-X302UA systemd-modules-load[254]: Inserted module 'ppdev'
Sep  5 16:36:05 djalin-X302UA systemd-modules-load[254]: Inserted module 'parport_pc'
Sep  5 16:36:05 djalin-X302UA rsyslogd-2039: Could not open output pipe '/dev/xconsole':: No such file or directory [v8.16.0 try http://www.rsyslog.com/e/2039 ]
Sep  5 16:36:05 djalin-X302UA systemd[1]: Started Load Kernel Modules.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Mounting FUSE Control File System...
Sep  5 16:36:05 djalin-X302UA systemd[1]: Mounting Kernel Configuration File System...
Sep  5 16:36:05 djalin-X302UA systemd[1]: Starting Apply Kernel Variables...
Sep  5 16:36:05 djalin-X302UA systemd[1]: Mounted Kernel Configuration File System.
Sep  5 16:36:05 djalin-X302UA rsyslogd-2007: action 'action 10' suspended, next retry is Tue Sep  5 16:36:35 2017 [v8.16.0 try http://www.rsyslog.com/e/2007 ]
Sep  5 16:36:05 djalin-X302UA systemd[1]: Mounted FUSE Control File System.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Started udev Kernel Device Manager.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Starting Remount Root and Kernel File Systems...
Sep  5 16:36:05 djalin-X302UA systemd[1]: Started Remount Root and Kernel File Systems.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Reached target Local File Systems (Pre).
Sep  5 16:36:05 djalin-X302UA systemd[1]: Starting Flush Journal to Persistent Storage...
Sep  5 16:36:05 djalin-X302UA systemd[1]: Activating swap /swapfile...
Sep  5 16:36:05 djalin-X302UA systemd[1]: Starting udev Coldplug all Devices...
Sep  5 16:36:05 djalin-X302UA systemd[1]: Starting Load/Save Random Seed...
Sep  5 16:36:05 djalin-X302UA systemd[1]: Started Apply Kernel Variables.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Starting Network Service...
Sep  5 16:36:05 djalin-X302UA systemd[1]: Started Flush Journal to Persistent Storage.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Started udev Coldplug all Devices.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Starting Show Plymouth Boot Screen...
Sep  5 16:36:05 djalin-X302UA systemd[1]: Started Load/Save Random Seed.
Sep  5 16:36:05 djalin-X302UA systemd-networkd[282]: Enumeration completed
Sep  5 16:36:05 djalin-X302UA systemd[1]: Started Network Service.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Starting Wait for Network to be Configured...
Sep  5 16:36:05 djalin-X302UA systemd[1]: Activated swap /swapfile.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Reached target Swap.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Started Show Plymouth Boot Screen.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Reached target Encrypted Volumes.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Started Forward Password Requests to Plymouth Directory Watch.
Sep  5 16:36:05 djalin-X302UA systemd-networkd-wait-online[302]: ignoring: lo
Sep  5 16:36:05 djalin-X302UA systemd[1]: Created slice system-systemd\x2dbacklight.slice.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:intel_backlight...
Sep  5 16:36:05 djalin-X302UA systemd-udevd[287]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Sep  5 16:36:05 djalin-X302UA systemd[1]: Started Load/Save Screen Backlight Brightness of backlight:intel_backlight.
Sep  5 16:36:05 djalin-X302UA mtp-probe: checking bus 1, device 4: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6"
Sep  5 16:36:05 djalin-X302UA mtp-probe: checking bus 1, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3"
Sep  5 16:36:05 djalin-X302UA mtp-probe: checking bus 1, device 2: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2"
[code]
завантажую дебіан тестовий...
djalin2
Re: Очистити диск
« Відповідей #22 : 2017-09-05 16:48:07 »
чомусь сіслог не зберігся
gdekjifgb
Re: Очистити диск
« Відповідей #23 : 2017-09-05 16:53:05 »
а чому варіант із вимкненням логування не підходить?
djalin2
Re: Очистити диск
« Відповідей #24 : 2017-09-05 17:09:05 »
Бо це голову в пісок - проблема то лишається - а якщо це реально апаратна?
Відсутній recht
  • дописів: 125
Re: Очистити диск
« Відповідей #25 : 2017-09-05 18:13:13 »
Тобто ця тема вичерпана?
Чому саме тестінг? Я би, для початку, спробував стабільний реліз.
djalin2
Re: Очистити диск
« Відповідей #26 : 2017-09-05 18:15:33 »
Аби ж то - тестовий дебіант стоїть, а логи все рівно пухнуть....
Мабуть таки доведеться відключати - принаймні тимчасово - хоча ця ідея мені і не подобається.
djalin2
Re: Очистити диск
« Відповідей #27 : 2017-09-05 18:18:31 »
lsb_release -a
No LSB modules are available.
Distributor ID:    Debian
Description:    Debian GNU/Linux testing (buster)
Release:    testing
Codename:    buster
Поки повернуся до хуби, а там як складеться...
Відсутній Djalin
  • дописів: 662
Re: Очистити диск
« Відповідей #28 : 2017-09-05 18:48:41 »
Пане rechtУ мене лишається стійке враження, що тему ви не читаєте :-)
Edit:
Edit:
У тестійну ядро ж новіше ніж у стабільному - хіба ні?
Ну й у стабільних релiзах глючив WI-FI  - виправилось лише в останніх версіях.
Миха́йло Даниле́нко
Re: Очистити диск
« Відповідей #29 : 2017-09-05 19:32:35 »
Краще не початок, а кінець логу наводити — на початку ідуть повідомлення, які логуються при завантаженні ядра та визначенні девайсів — вони нормальні. Щось типу виводу
tail -n 50 /var/log/syslog
