Автор Гілка: Vim shortcuts )  (Прочитано 3574 раз)
Відсутній Satan
  • дописів: 141
  • C++ Guru
Vim shortcuts )
« : 2007-04-15 17:48:31 »
іноді читаю мануали по Віму і виписую найбільш потрібні (мені) команди. Тут пропоную останній едішн )
Читати кожен день перед сном  ;)
-- HELP MODE
      CTRL-] - jump to the tag
      CTRL-O - jump to older position
      CTRL-T - pop tag (== CTRL-O ?)
-- NORMAL MODE
      h - left
      j - down
      k - up
      l - right
      x - delete a character
      dd - delete a line
      J - delete a line break
      u - undo
      CTRL-R - redo
      o - create new empty line bellow and go to INSERT mode
      O - create new empty line abouve
      ZZ - save and exit
---- MOVING
            CTRL-G - Telling where you are
            w(W) - move forward one word(WORD - see keyword for details)
            b(B) - move backward one word(WORD)
            e(E) - move to next end of word(WORD)
            ge(gE) - move to previous end of word(WORD)
            $ - go to the last character in line
            0 - go to the first character in line
            ^ - go to the first non-blank character in line
            fx - search right in the line for x character
            Fi - search left in the line for i character
            tx - search right in the line for x character (but stop before it)
            Ti - search left in the line for i character (but stop before it)
            ; - repeat search to the left
            , - repeat search to the right
            % - move to the matching paren. (),{},[] - can be defined with 'matchpairs' option.
            G - go to the end of file
            1G - go to the first line
            45G - go to the line 45
            gg - go to the begin of file
            30% - go to the 30% line
            H - go to the first line on the screen
            M - go to the middle line on the sceen
            L - go to the last line on the screen
-- COMMAND-LINE mode
      :q - quit
      :q! - ovveriden quit
      :e! - reload the file (overriden)
      :set [no]showmode - display current mode
      :set [no]number - show line numbers
      :set [no]ruler - show cursor position
      :h[elp] {subject} - show help (subject can contain wildcards like * and ?)
            :help deleting - find how to delete text
            :help x - help on the x command
            :help index - complete index of Vim commands
            :help CTRL-A - help on CTRL-A in NORMAL mode
            :help i_CTRL-H - help on CTRL-H in INSERT mode
            :help -t - help on what does as a command line argument
            :help 'number' - help on 'number' option
            :help i_<Up> - help on UP key in INSERT mode
            :help E37 - help on Error code 37
Ubuntu 8.04
Re: Vim shortcuts )
« Відповідей #1 : 2007-04-16 15:04:01 »
Re: Vim shortcuts )
« Відповідей #2 : 2007-04-16 16:33:53 »
www.viemu.com
Так оце оці варезописателі таку картину намалювали? М-да... В мене з viemu пов'язані виключно неприємні спогади. Через те, що в найвідповідальніший момент це чудо техніки просто вирубилось.
Ну і до оригінального vim-у viemu як до неба рачки.
« Змінено: 2007-04-16 16:35:00 від Cthulhu »
