Автор Гілка: Xorg & widescreen problem!  (Прочитано 3010 раз)
Відсутній infinity9
  • дописів: 25
  • "Use the Force, read the source"
« : 2007-07-27 23:27:53 »
Маю таку проблему: монітор Acer AL1916wa та систему Gentoo Linux 2007 профайл з Х системою:
X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux C3Pio 2.6.21.1 #4 SMP Wed Jun 13 15:43:09 EEST 2007 i686
Build Date: 18 May 2007
і це все разом перестало працювати в рідній для мого дисплея роздільній здатності 1440х900.
Ось xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 1.0  (buildmeister@builder3)  Thu Nov  9 17:55:20 PST 2006
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings:  version 1.0  (buildmeister@builder3)  Thu Nov  9 17:56:12 PST 2006
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0" 0 0
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
    RgbPath         "/usr/lib/X11/rgb"
EndSection
Section "Module"
    Load           "dbe"
    Load           "extmod"
    Load           "type1"
    Load           "freetype"
    Load           "glx"
EndSection
Section "ServerFlags"
    Option         "Xinerama" "FALSE"
EndSection
Section "InputDevice"
    # generated from data in "/etc/conf.d/gpm"
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol"
    Option         "Device" "/dev/input/mice"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    # generated from default
    Identifier     "Keyboard0"
    Driver         "kbd"
    Option         "XkbRules" "xorg"
    Option         "XkbModel" "pc105"
    Option         "XkbLayout" "us,ua(winkeys)"
    Option         "XkbOptions" "grp:ctrl_shift_toggle,grp_led:scroll"
EndSection
Section "Monitor"
    # HorizSync source: edid, VertRefresh source: edid
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Acer AL1916W"
    HorizSync       31.0 - 84.0
    VertRefresh     56.0 - 76.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Videocard0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "GeForce4 MX 440 with AGP8X"
    Option         "FlatPanelProperties" "Scaling = aspect-scaled"
    Option         "UseEDID" "FALSE"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Videocard0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
        Modes      "1440x900" "1280x1024" "1024x768" "800x600" "640x480"
    EndSubSection
EndSection
Section "Extensions"
    Option         "Composite" "enable"
EndSection
« Змінено: 2007-07-27 23:28:29 від infinity9 »
InfinitylX's space http://www.infinitylx.org.ua
Відсутній infinity9
  • дописів: 25
Re: Xorg & widescreen problem!
« Відповідей #1 : 2007-07-27 23:41:37 »
лог файл /var/log/Xorg.0.log http://infinity9.org.ua/xlog
можливо перенесіть цю тему в розділ " Встановлення та початкове налаштування"
я тут новеньки і не дуже оріентуюсь в розділах.
« Змінено: 2007-07-28 00:01:14 від infinity9 »
« Відповідей #2 : 2007-07-28 02:18:32 »
(--) NVIDIA(0): Connected display device(s) on GeForce4 MX 440 with AGP8X at
(--) NVIDIA(0):     PCI:1:0:0:
(--) NVIDIA(0):     CRT-0
(--) NVIDIA(0):     NVIDIA TV Encoder (TV-0)
(--) NVIDIA(0): CRT-0: 350.0 MHz maximum pixel clock
(--) NVIDIA(0): NVIDIA TV Encoder (TV-0): 350.0 MHz maximum pixel clock
(--) NVIDIA(0): TV encoder: NVIDIA
(II) NVIDIA(0): Assigned Display Device: CRT-0
(WW) NVIDIA(0): No valid modes for "1440x900"; removing.
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0):     "1280x1024"
(II) NVIDIA(0):     "1024x768"
(II) NVIDIA(0):     "800x600"
(II) NVIDIA(0):     "640x480"
(II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024
Відсутній infinity9
  • дописів: 25
« Відповідей #3 : 2007-07-29 10:39:09 »
"Все геніальне просто"
(с)перто :-)
Необхідно було додати ось цю стрічку до файлу xorg.conf:
Section "Monitor"
Modeline       "1440x900_60" 106.47 1440 1520 1672 1904 900 901 904 932 +HSy
nc +VSync
EndSection
Правда не знаю наскільки правильним є все після "" ......
Інформацію знайшов тут http://www.linuxquestions.org/questions/showthread.php?t=547918
Можливо хтось пояснить якого раніше працювало без Modeline а в пт зранку перестало працювати ??? :-?
Відсутній rangel
  • дописів: 281
  • Python programmer
« Відповідей #4 : 2007-07-29 13:28:37 »
а відеокарта у вас яка?
Roman Suprotkin
Відсутній infinity9
  • дописів: 25
« Відповідей #5 : 2007-07-30 11:10:13 »
Відео картка (народна) NVidia MX4 440.
Відсутній rangel
  • дописів: 281
  • Python programmer
« Відповідей #6 : 2007-08-01 12:43:07 »
nvidia-settings ?
Roman Suprotkin
