Автор Гілка: smartcl: Non-medium error count  (Прочитано 3254 раз)
Відсутній Volodymyrko
  • дописів: 370
  • I Like FreeBSD !
« : 2009-03-30 11:04:11 »
на одному із серверів  на одного із хардів  ось така не дуже весела картинка
smartctl -a /dev/sda
smartctl version 5.38 [x86_64-pc-linux-gnu] Copyright (C) 2002-8 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
Device: SEAGATE  ST373455SS       Version: 0002
Serial number: 3LQ2P4ZL00009830VZWZ
Device type: disk
Transport protocol: SAS
Local Time is: Mon Mar 30 09:39:58 2009 GMT
Device supports SMART and is Enabled
Temperature Warning Enabled
SMART Health Status: OK
Current Drive Temperature:     20 C
Drive Trip Temperature:        68 C
Elements in grown defect list: 0
Vendor (Seagate) cache information
  Blocks sent to initiator = 3312202922
  Blocks received from initiator = 1419940947
  Blocks read from cache and sent to initiator = 2401435663
  Number of read and write commands whose size <= segment size = 49289992
  Number of read and write commands whose size > segment size = 2213
Vendor (Seagate/Hitachi) factory information
  number of hours powered up = 7549.47
  number of minutes until next internal SMART test = 6
Error counter log:
           Errors Corrected by           Total   Correction     Gigabytes    Total
               ECC          rereads/    errors   algorithm      processed    uncorrected
           fast | delayed   rewrites  corrected  invocations   [10^9 bytes]  errors
read:    1840269        1         0   1840270    1840270       3895.904           0
write:         0        0         0         0          0   242748708.592           0
Non-medium error count:      160
[GLTSD (Global Logging Target Save Disable) set. Enable Save with '-S on']
SMART Self-test log
Num  Test              Status                 segment  LifeTime  LBA_first_err [SK ASC ASQ]
     Description                              number   (hours)
# 1  Background short  Completed                   -    7383                 - [-   -    -]
Long (extended) Self Test duration: 721 seconds [12.0 minutes]
а саме мене цікавить рядок
Non-medium error count :  160  (тиждень   тому було 155)
на іншим хардах там "0"-лі
non-medium error counter (only a single number displayed). This represents the number of recoverable events other than write, read or verify errors.
може хтось стикався з таким ?
