Автор Гілка: CPU temp  (Прочитано 1286 раз)
Відсутній Volodymyrko
  • дописів: 370
  • I Like FreeBSD !
CPU temp
« : 2011-11-03 17:08:10 »
захотів на сервері (debian-6) дивитися температуру cpu
встановив lm-sensors
далі sensors-detect .. всяди YES//  ... далі /etc/init.d/module-init-tools start...
# sensors
max1617-i2c-0-18
Adapter: SMBus I801 adapter at 0400
temp1:        +0.0°C  (low  = +27.0°C, high = +65.0°C)
temp2:        +2.0°C  (low  =  -6.0°C, high =  +8.0°C)
max1617-i2c-0-19
max1617-i2c-0-1a
w83627dhg-isa-0a10
Adapter: ISA adapter
Vcore:       +1.20 V  (min =  +0.60 V, max =  +1.49 V)
in1:         +1.82 V  (min =  +1.62 V, max =  +1.99 V)
AVCC:        +3.31 V  (min =  +2.96 V, max =  +3.63 V)
in4:         +1.54 V  (min =  +1.35 V, max =  +1.65 V)
in5:         +1.26 V  (min =  +1.13 V, max =  +1.38 V)
in6:         +1.42 V  (min =  +1.42 V, max =  +1.52 V)
3VSB:        +3.30 V  (min =  +2.96 V, max =  +3.63 V)
Vbat:        +3.15 V  (min =  +2.96 V, max =  +3.63 V)
fan1:       8035 RPM  (min =  712 RPM, div = 8)
fan2:       8035 RPM  (min =  712 RPM, div = 8)
fan3:          0 RPM  (min =  753 RPM, div = 128)  ALARM
fan4:       8437 RPM  (min =  712 RPM, div = 8)
fan5:       7670 RPM  (min =  712 RPM, div = 8)
temp1:       +30.0°C  (high = +60.0°C, hyst = +55.0°C)  sensor = thermistor
temp2:       +41.5°C  (high = +95.0°C, hyst = +92.0°C)  sensor = diode
temp3:       +41.0°C  (high = +80.0°C, hyst =  +0.0°C)  sensor = diode
cpu0_vid:   +1.300 V
а де ЦПУ ??
не можу найти як то вирішити.. навіть не знаю де і як шукати
може хто має  стикався...
  • дописів: 370
  • I Like FreeBSD !
Re: CPU temp
« Відповідей #1 : 2011-11-03 17:17:56 »
це що мого "Intel(R) Xeon(R) CPU           X3430  @ 2.40GHz" немає в підтримці того lm_sensors???
Intel       Pentium II/III-based Xeon       no       adm1021       I2C       2.5.54       Integrated sensors. Force parameter needed. Read the docs.
 Intel       Pentium M, Core, Core 2       yes       coretemp       MSR       2.6.22       Integrated digital sensor in CPU. Driver contributed by Rudolf Marek. Support for single-core Core 2 / Celeron M-400 series added in kernel 2.6.24. Support for Penryn-based Core 2 Duo/Quad was added in kernel 2.6.25.
 Intel       Core i3, Core i5, Xeon 5500 series       yes       coretemp       MSR       2.6.27       Integrated digital sensor in CPU. Support for Lynnfield-based Core i5 was added in kernel 2.6.32. Support for Clarkdale and later cores was added in kernel 2.6.35.
