Автор Гілка: Posfix -  spam!!  (Прочитано 1192 раз)
Відсутній 100matolog
  • дописів: 5
Posfix -  spam!!
« : 2009-09-11 09:10:25 »
Допоможіть разобратся.
В останні кілька днів в логах ось таке
Sep 11 08:47:56 router postfix/qmgr[4388]: DA439367CAF: from=<alimaasif1@cantv.net>, size=4116, nrcpt=10 (queue active)
Sep 11 08:47:56 router postfix/qmgr[4388]: D5AD93C67ED: from=<best4g@club-internet.fr>, size=2954, nrcpt=30 (queue active)
Sep 11 08:47:57 router postfix/qmgr[4388]: D6F35356DE6: from=<best4g@club-internet.fr>, size=2753, nrcpt=50 (queue active)
Sep 11 08:47:57 router postfix/qmgr[4388]: D317F3698CA: from=<best4g@club-internet.fr>, size=2954, nrcpt=50 (queue active)
Sep 11 08:47:57 router postfix/smtp[4440]: DCC77355F7D: host ecis.com[206.180.224.209] said: 451 4.1.8 ACCESS DELAYED Possibly forged hostname for 195.177.73.203 have your system administrator fix your DNS (in reply to RCPT TO command)
Sep 11 08:47:57 router postfix/qmgr[4388]: D4BE33879D6: from=<best4g@club-internet.fr>, size=2954, nrcpt=30 (queue active)
Sep 11 08:47:57 router postfix/qmgr[4388]: DC4383655FD: from=<alimaasif@cantv.net>, size=3915, nrcpt=10 (queue active)
Sep 11 08:47:57 router postfix/smtp[4407]: D0EDC368E89: host mx2.gawab.com[66.220.20.52] said: 422 Server busy. Please try again later (#4.3.1) (in reply to RCPT TO command)
Sep 11 08:47:57 router postfix/smtp[4407]: D0EDC368E89: lost connection with mx2.gawab.com[66.220.20.52] while sending DATA command
Sep 11 08:47:57 router postfix/qmgr[4388]: D98E1364FC9: from=<alimaasif@cantv.net>, size=3915, nrcpt=40 (queue active)
Sep 11 08:47:57 router postfix/smtp[4423]: D175B27FC40: to=<bwayshea@aol.com>, relay=mailin-04.mx.aol.com[64.12.138.88], delay=325984, status=deferred (host mailin-04.mx.aol.com[64.12.138.88] said: 421-:  (DYN:T1)  http://postmaster.info.aol.com/errors/421dynt1.html 421 SERVICE NOT AVAILABLE (in reply to end of DATA command))
Sep 11 08:47:57 router postfix/smtp[4423]: D175B27FC40: to=<bxlulu1@aol.com>, relay=mailin-04.mx.aol.com[64.12.138.88], delay=325984, status=deferred (host mailin-04.mx.aol.com[64.12.138.88] said: 421-:  (DYN:T1)  http://postmaster.info.aol.com/errors/421dynt1.html 421 SERVICE NOT AVAILABLE (in reply to end of DATA command))
Sep 11 08:47:57 router postfix/qmgr[4388]: D7AAB359956: from=<alima_asif@cantv.net>, size=4116, nrcpt=10 (queue active)
Имхо через мій стервер луплять спам .. але начебто релеінга у мну для чужих мереж немає
Вирубав внутрішню сітку
все одно луплять.
ось конфиг postfix-а
[root@router ~]# cat /etc/postfix/main.cf
#-----------------CLAMAV----------------------#
content_filter = scan:127.0.0.1:10025
receive_override_options = no_address_mappings
command_directory = /usr/sbin
daemon_directory = /usr/libexec/postfix
default_privs = nobody
myhostname = router.cei.com.ua
mydomain = cei.com.ua
mydestination = $myhostname, localhost.$mydomain, localhost, $mydomain, tynnyi.com
local_recipient_maps = unix:passwd.byname $alias_maps $virtual_mailbox_maps
unknown_local_recipient_reject_code = 550
smtpd_client_restrictions = reject_unknown_client
mynetworks = 127.0.0.1/8, 192.168.0.0/24
smtpd_sasl_auth_enable = yes
smtp_sasl_security_options = noanonymous
broken_sasl_auth_clients = yes
strict_rfc821_envelopes = yes
disable_vrfy_command = yes
smtpd_helo_required = yes
smtpd_helo_restrictions = permit_mynetworks, permit_sasl_authenticated, check_helo_access hash:/etc/postfix/helo_access, check_helo_access regexp:/etc/postfix/helo_regexp, check_helo_access regexp:/etc/postfix/dul_checks, reject_invalid_hostname
smtpd_sender_restrictions = permit_sasl_authenticated, permit_mynetworks, check_sender_access regexp:/etc/postfix/sender_access, reject_non_fqdn_sender, reject_unknown_sender_domain
smtpd_recipient_restrictions = reject_unauth_pipelining, permit_sasl_authenticated, permit_mynetworks, reject_non_fqdn_recipient, reject_unknown_recipient_domain, reject_unlisted_recipient, check_recipient_access regexp:/etc/postfix/recipient_access, reject_unauth_destination, reject_unknown_client
smtpd_banner = HELLO cei.com.ua
mailbox_size_limit = 1000000000
alias_maps = hash:/etc/aliases
debug_peer_level = 2
debugger_command =
         PATH=/bin:/usr/bin:/usr/local/bin:/usr/X11R6/bin
         xxgdb $daemon_directory/$process_name $process_id & sleep 5
sendmail_path = /usr/sbin/sendmail.postfix
newaliases_path = /usr/bin/newaliases.postfix
mailq_path = /usr/bin/mailq.postfix
setgid_group = postdrop
html_directory = no
manpage_directory = /usr/share/man
sample_directory = /usr/share/doc/postfix-2.3.3/samples
readme_directory = /usr/share/doc/postfix-2.3.3/README_FILES
полагодив - там у спули було мильон с лишком листив - почистив чергу - все стало арбайтен
« Змінено: 2009-09-11 12:31:52 від 100matolog »
