Автор Гілка: autoconf та libnet-config  (Прочитано 4234 раз)
Відсутній Микола Федчик
  • дописів: 28
  • Catch your train!
« : 2005-04-07 12:19:46 »
Створюю невеличку програму, що використовує libnet.
Що треба занести в configure.in, аби була можливість використовувати результати
libnet-config --cflags
libnet-config --defines
під час генерації Makefile за допомогою configure ?
Re: autoconf та libnet-config
« Відповідей #1 : 2005-04-07 13:30:22 »
1.1.x http://cvs.sourceforge.net/viewcvs.py/tcpreplay/tcpreplay/configure.in?rev=1.61
dnl ##################################################
dnl Checks for libnet (shamelessly horked from dsniff)
AC_MSG_CHECKING(for libnet)
AC_ARG_WITH(libnet,
[  --with-libnet=DIR       use libnet in DIR],
[ case "$withval" in
  yes|no)
     AC_MSG_RESULT(no)
     AC_MSG_RESULT($withval)
     if test -f $withval/include/libnet.h -a -f $withval/lib/libnet.a; then
        owd=`pwd`
        if cd $withval; then
          withval=`pwd`
          cd $owd
        fi
            LNETINC="-I$withval/include"
            LNETINCDIR="$withval/include"
            LNETLIB="-L$withval/lib -lnet"
     else
        AC_ERROR(libnet.h or libnet.a not found in $withval)
     fi
  esac ],
[ if test -f ${prefix}/include/libnet.h; then
     LNETINC="-I${prefix}/include"
     LNETINCDIR="$prefix/include"
     LNETLIB="-L${prefix}/lib -lnet"
  elif test -f /usr/include/libnet.h; then
     LNETINCDIR="/usr/include"
     LNETLIB="-lnet"
  else
     AC_MSG_RESULT(no)
     AC_ERROR(libnet not found)
  fi
  AC_MSG_RESULT(yes) ]
AC_SUBST(LNETINC)
AC_SUBST(LNETLIB)
OLDLIBS="$LIBS"
LIBS="$LNETLIB"
dnl Check to see what version of libnet
dnl this code has been reduced a lot, but probably still could be
dnl reduced quite a bit more if we chose too
AC_MSG_CHECKING(for libnet version)
AC_TRY_RUN([
#include <string.h>
#define LIBNET_LIL_ENDIAN 1
#include "$LNETINCDIR/libnet.h"
#define LIB_TEST "1.0"
 * simple proggy to test the version of libnet
 * returns zero if it's 1.0.x
 * or one otherwise
int
main (int argc, char *argv[])
      if (strncmp(LIB_TEST, LIBNET_VERSION, 3) == 0)
            exit(0);
      exit(1);
      libnet_ver_10=yes
      AC_MSG_RESULT(1.0.x),
      libnet_ver_10=no,
      libnet_ver_10=no
AC_TRY_RUN([
#include <string.h>
#define LIB_TEST "1.1"
 * or one otherwise
int
            exit(0);
      exit(1);
      libnet_ver_11=yes
      AC_MSG_RESULT(1.1.x),
      libnet_ver_11=no,
      libnet_ver_11=no
if test $libnet_ver_10 = no -a $libnet_ver_11 = no ; then
      AC_MSG_RESULT(unknown)
      AC_MSG_ERROR(Unable to determine version of libnet)
fi
if test $libnet_ver_10 = yes ; then
        AC_MSG_ERROR(Libnet version 1.0.x is no longer supported.
            Please upgrade to 1.1.0 or better)
fi
dnl restore LIBS
LIBS="$OLDLIBS"
« Відповідей #2 : 2005-04-07 13:35:37 »
Ну і в Makefile.in:
INCS            = ... @LNETINC@
LIBS            = ... @LNETLIB@
  • дописів: 28
  • Catch your train!
« Відповідей #3 : 2005-04-08 10:59:43 »
Дякую! 8)
