Автор Гілка: Ubuntu 6_10 vs Marvell Yukon 88E8056 PCI-E Gigabit  (Прочитано 5770 раз)
Відсутній Monarx
  • дописів: 13
Re: Ubuntu 6_10 vs Marvell Yukon 88E8056 PCI-E Gig
« Відповідей #15 : 2007-07-20 00:08:41 »
$ dpkg -l | grep -E '(kernel|linux)'
rush@Monarx:~$ dpkg -l | grep -E '(kernel|linux)'
ii  foomatic-db                                20060918-0ubuntu2             linuxprinting.org printer support - database
ii  foomatic-db-engine                         3.0.2-20060925-0ubuntu1       linuxprinting.org printer support - programs
ii  foomatic-db-hpijs                          20060925-0ubuntu1             linuxprinting.org printer support - database
ii  foomatic-filters                           3.0.2-20060918-0ubuntu1       linuxprinting.org printer support - filters
ii  iptables                                   1.3.5.0debian1-1ubuntu2       Linux kernel 2.4+ iptables administration to
ii  language-selector                          0.1.30                        Language selector for ubuntu linux
ii  language-selector-common                   0.1.30                        Language selector for ubuntu linux
ii  libdrm2                                    2.0.2+git20060809-0ubuntu1    Userspace interface to kernel DRM services -
ii  libselinux1                                1.30-1ubuntu1                 SELinux shared libraries
ii  linux-generic                              2.6.17.10                     Complete Generic Linux kernel
ii  linux-headers-2.6.17-10                    2.6.17-10.33                  Header files related to Linux kernel version
ii  linux-headers-2.6.17-10-generic            2.6.17-10.33                  Linux kernel headers for version 2.6.17 on x
ii  linux-headers-generic                      2.6.17.10                     Generic Linux kernel headers
ii  linux-image-2.6.17-10-generic              2.6.17-10.33                  Linux kernel image for version 2.6.17 on x86
ii  linux-image-generic                        2.6.17.10                     Generic Linux kernel image
ii  linux-restricted-modules-2.6.17-10-generic 2.6.17.5-11                   Non-free Linux 2.6.17 modules on x86_64 gene
ii  linux-restricted-modules-common            2.6.17.5-11                   Non-free Linux 2.6.17 modules helper script
ii  linux-restricted-modules-generic           2.6.17.10                     Restricted Linux modules for generic kernels
ii  linux-sound-base                           1.0.11-5ubuntu1               base package for ALSA and OSS sound systems
ii  module-init-tools                          3.2.2-3ubuntu3                tools for managing Linux kernel modules
ii  nvidia-kernel-common                       20051028+1ubuntu7             NVIDIA binary kernel module common files
ii  udev                                       093-0ubuntu18                 rule-based device node and kernel event mana
ii  util-linux                                 2.12r-11ubuntu2               Miscellaneous system utilities
ii  util-linux-locales                         2.12r-11ubuntu2               Locales files for util-linux
rush@Monarx:~$
ls -1l /usr/src/linux
lrwxrwxrwx 1 root src 41 2007-07-19 23:26 /usr/src/linux -> /usr/src/linux-headers-2.6.17-10-generic/
rush@Monarx:~$
ls -1l /usr/src/linux/
rush@Monarx:~$ ls -1l /usr/src/linux/
total 340
lrwxrwxrwx 1 root root     31 2007-07-08 19:59 arch -> ../linux-headers-2.6.17-10/arch
lrwxrwxrwx 1 root root     32 2007-07-08 19:59 block -> ../linux-headers-2.6.17-10/block
lrwxrwxrwx 1 root root     30 2007-07-19 23:27 config-2.6.17-10-generic -> /boot/config-2.6.17-10-generic
lrwxrwxrwx 1 root root     33 2007-07-08 19:59 crypto -> ../linux-headers-2.6.17-10/crypto
lrwxrwxrwx 1 root root     34 2007-07-08 19:59 drivers -> ../linux-headers-2.6.17-10/drivers
lrwxrwxrwx 1 root root     35 2007-07-08 19:59 firmware -> ../linux-headers-2.6.17-10/firmware
lrwxrwxrwx 1 root root     29 2007-07-08 19:59 fs -> ../linux-headers-2.6.17-10/fs
drwxr-xr-x 4 root root   4096 2006-10-25 16:30 include
lrwxrwxrwx 1 root root     31 2007-07-08 19:59 init -> ../linux-headers-2.6.17-10/init
lrwxrwxrwx 1 root root     30 2007-07-08 19:59 ipc -> ../linux-headers-2.6.17-10/ipc
lrwxrwxrwx 1 root root     33 2007-07-08 19:59 kernel -> ../linux-headers-2.6.17-10/kernel
lrwxrwxrwx 1 root root     30 2007-07-08 19:59 lib -> ../linux-headers-2.6.17-10/lib
lrwxrwxrwx 1 root root     40 2007-07-19 12:07 linux-headers-2.6.17-10-generic -> /usr/src/linux-headers-2.6.17-10-generic
-rw-r--r-- 1 root root  45479 2006-10-13 22:09 Makefile
lrwxrwxrwx 1 root root     29 2007-07-08 19:59 mm -> ../linux-headers-2.6.17-10/mm
lrwxrwxrwx 1 root root     34 2007-07-08 19:59 modules -> ../linux-headers-2.6.17-10/modules
-rw-r--r-- 1 root root 285604 2006-10-13 19:56 Module.symvers
lrwxrwxrwx 1 root root     30 2007-07-08 19:59 net -> ../linux-headers-2.6.17-10/net
drwxr-xr-x 8 root root   4096 2006-10-25 16:30 scripts
lrwxrwxrwx 1 root root     35 2007-07-08 19:59 security -> ../linux-headers-2.6.17-10/security
lrwxrwxrwx 1 root root     32 2007-07-08 19:59 sound -> ../linux-headers-2.6.17-10/sound
lrwxrwxrwx 1 root root     30 2007-07-08 19:59 usr -> ../linux-headers-2.6.17-10/usr
rush@Monarx:~$
« Відповідей #16 : 2007-07-20 00:29:49 »
Мдя. Забув ще
$ ls -dl /usr/src/linux/.*
Ось що на моєму деб'яні:
isbear@monstruozo:~$ ls -dl /usr/src/linux/.*
drwxr-xr-x 4 root root  4096 2007-05-16 20:55 /usr/src/linux/.
drwxrwsr-x 8 root src   4096 2007-05-16 21:01 /usr/src/linux/..
-rw-r--r-- 1 root root 64915 2007-05-04 03:29 /usr/src/linux/.config
-rw-r--r-- 1 root root   208 2007-05-04 03:29 /usr/src/linux/.kernelvariables
Тобто, як бачимо, .config присутній, причому посиланням не є.
Що можна спробувати - від root покласти туди конфіг, якщо він там відсутній (симлінкувати не раджу - не знаю, як воно коли модуль збирається, а принаймні при перезбірці ядра той конфіг перегенерується, отже може постраждати системний в /boot):
# cp -iv "/boot/config-$(uname -r)" /usr/src/linux/.config
Відсутній Monarx
  • дописів: 13
« Відповідей #17 : 2007-07-26 21:44:00 »
Все .... проблему, можна сказати вичерпано. Правда не так як я хотів, але все ж. Сьогодні мені принесли, раніше замовлені мною диски із убунту 7.04 (швидко справилися, десь так за 2-3 тижні). Тому я зара пишу цю месагу із Убунту, який тільки встановлюється на мою машину.
З.І. Вдячний усім тим, хто пробував допомогти мені розв'язати цю проблему  ;)
