Автор Гілка: Agere system HDA Modem - як примусити запрацювати?  (Прочитано 9178 раз)
Відсутній Melody
  • дописів: 6
Дистро - Мандріва 2008 free... зтягла драйвер ltmodem-kv_2.6.11-6mdk-2.6-7balk.i586.rpm. Встав. Але модем всеодно не распознається ((
Ось що мені сказав сканмодем:
Only plain text email is forwarded by the  Discuss@Linmodems.org List Server,
 as HTML can contain viruses. Use as the email Subject Line:
           YourName, YourCountry Mandriva Linux release 2008.0 (Official) for i586
Kernel 2.6.22.9-desktop-2mdv on an i686 /  kernel 2.6.22.9-desktop-2mdv
 With this Subject Line cogent experts will be alerted, and useful case names left in the Archive.
 YourCountry will enable Country specific guidance. Your contry's local Linux experts
 can be found through: http://www.linux.org/groups/index.html.
They will know your Country's modem code, which may be essential for dialup service.
Responses from Discuss@Linmodems.org are sometimes blocked by an Internet Provider mail filters.
 So in a day, also check the Archived responses at http://www.linmodems.org
--------------------------  System information ----------------------------
CPU=i686,  Mandriva Linux release 2008.0 (Official) for i586
Linux version 2.6.22.9-desktop-2mdv (root@n2.mandriva.com) (gcc version 4.2.2 20070909 (prerelease) (4.2.2-0.RC.1mdv2008.0)) #1 SMP Fri Nov 16 14:31:33 EST 2007
 scanModem update of:  2008_03_09
The modem symbolic link is /dev/modem -> ttyS2
 There are no blacklisted modem drivers in /etc/modprobe*  files
The Advanced Linux Sound Architecture (ALSA) packages providing audio support,
also includes drivers for some modems. The ALSA diagnostics are written during
bootup to /proc/asound/ folders.
The ALSA verion is 1.0.15rc1
The modem cards detected by "aplay -l"  are:
card 0: SB [HDA ATI SB], device 6: Si3054 Modem [Si3054 Modem]
The /proc/asound/pcm file reports:
00-06: Si3054 Modem : Si3054 Modem : playback 1 : capture 1
00-02: ALC262 Analog : ALC262 Analog : capture 2
00-00: ALC262 Analog : ALC262 Analog : playback 1 : capture 2
about /proc/asound/cards:
 0 [SB             ]: HDA-Intel - HDA ATI SB
                      HDA ATI SB at 0xd0300000 irq 17
 The modem codec file for the the HDA card is: /proc/asound/card0/codec#1
Codec: Generic 11c1 Si3054
Address: 1
Vendor Id: 0x11c11040
Subsystem Id: 0x2118144d
Revision Id: 0x100200
Modem Function Group: 0x1
 The audio card hosts a softmodem chip:  0x11c11040
 The softmodem chip 0x11c11040 is not yet supported under Linux.
 Code must be developed by manufacture LSI Inc.
 See details in http://linmodems.technion.ac.il/bigarch/archive-seventh/msg00915.html
 Read InfoGeneral.txt about alternatives modem hardware.
USB modem not detected by lsusb
For candidate card in slot 00:14.2, firmware information and bootup diagnostics are:
 PCI slot      PCI ID            SubsystemID      Name
 00:14.2      1002:4383      144d:c034      Audio device: ATI Technologies Inc SBx00 Azalia
 Modem interrupt assignment and sharing:
 17:      64913   IO-APIC-fasteoi   ohci_hcd:usb1, HDA Intel
 --- Bootup diagnostics for card in PCI slot 00:14.2 ----
ACPI: PCI Interrupt 0000:00:14.2[A] -> GSI 16 (level, low) -> IRQ 17
 === Finished modem firmware and bootup diagnostics section. ===
 === Next deducing cogent software ===
Predictive diagnostics for card in bus 00:14.2:
      Modem chipset  detected on
CLASS="Class 0403: 1002:4383"
NAME="Audio device: ATI Technologies Inc SBx00 Azalia"
PCIDEV=1002:4383
SUBSYS=144d:c034
IRQ=17
HDA=1002:4383
SOFT=1002:4383.HDA
CHIP=0x11c11040
IDENT=Agere_11c11040_chip_is_not_supported
SLMODEMD_DEVICE=hw:0,6
Driver=snd-hda-intel
 For candidate modem in:  00:14.2
   Class 0403: 1002:4383 Audio device: ATI Technologies Inc SBx00 Azalia
      Primary PCI_id  1002:4383
----------------end Softmodem section --------------
 Completed candidate modem analyses.
 The base of the UDEV device file system is: /dev/.udev
 Versions adequately match for the compiler installed: 4.2.2
             and the compiler used in kernel assembly: 4.2.2
 Minimal compiling resources appear complete:
   make utility - /usr/bin/make
   Compiler version 4.2
   linuc_headers base folder /lib/modules/2.6.22.9-desktop-2mdv/build
 However some compilations and executable functions may need additional files,
 in the FileNames.h (so called kernel "h"eaders) collection installed in  /usr/include/ .
 For martian_modem, additional required packages are libc6-dev (and for Debian/Ubuntu,  linux-libc-dev). The also required headers of package libc6 are commonly installed by default.
If a driver compilation fails, with message including some lack of some FileName.h (stdio.h for example), then
Some additional kernel-header files need installation to /usr/include. The minimal additional packages are libc6-dev
and any of its dependents, under Ubuntu linux-libc-dev
If an alternate ethernet connection is available,
$  apt-get update
$  apt-get -s install linux-kernel-devel
will install needed package
For Debian/Ubuntu related distributions, run the following command to display the needed package list:
Otherwise packages have to be found through http://packages.ubuntu.com
Once downloaded and transferred into a Linux partition,
they can be installed alltogether with:
$ sudo dpkg -i *.deb
Checking pppd properties:
      -rwsr-xr-t 1 root root 317284 2007-08-21 01:57 /usr/sbin/pppd
In case of an "error 17" "serial loopback" problem, see:
    http://linmodems.technion.ac.il/linmodems/archive-sixth/msg02637.html
To enable dialout without Root permission do:
      $ su - root  (not for Ubuntu)
         chmod a+x /usr/sbin/pppd
or under Ubuntu related Linuxes
Checking settings of:      /etc/ppp/options
lock
noauth
noipdefault
usepeerdns
In case of a message like:
   Warning: Could not modify /etc/ppp/pap-secrets: Permission denied
see http://linmodems.technion.ac.il/bigarch/archive-sixth/msg04656.html
 Don't worry about the following, it is for the experts
 should trouble shooting be necessary.
L modem ttyS2
# UDEV rule for ltmodem
#  creates symlink /dev/modem to /dev/ttyLTM?, and takes care of permissions
KERNEL="ttyLTM[0-9]", NAME="%k", SYMLINK="modem"
 Checking for modem support lines:
     /device/modem symbolic link:   lrwxrwxrwx 1 root root 5 2008-04-25 20:41 /dev/modem -> ttyS2
slmodemd created symbolic link /dev/ttySL0:
     Within /etc/udev/ files:
/etc/udev/devices.d/modem.nodes:L modem ttyS2
/etc/udev/rules.d/ltmodem-2.6.11-6mdk.rules:# UDEV rule for ltmodem
/etc/udev/rules.d/ltmodem-2.6.11-6mdk.rules:#  creates symlink /dev/modem to /dev/ttyLTM?, and takes care of permissions
/etc/udev/rules.d/ltmodem-2.6.11-6mdk.rules:KERNEL="ttyLTM[0-9]", NAME="%k", SYMLINK="modem"
     Within /etc/modprobe.conf files:
/etc/modprobe.d/ltmodem:# ltmodem configuration
/etc/modprobe.d/ltmodem:alias /dev/modem ltserial
/etc/modprobe.preload:# ltmodem configuration
     Within any ancient /etc/devfs files:
     Within ancient kernel 2.4.n /etc/module.conf files:
--------- end modem support lines --------
Зтягла wvdial, kppp, minicom... при спробі з'єднання kppp каже: модем зайнятий, хоча порт я обрала той, що вказав сканмодем...
Допоможіть будьласка!
А: дівчат у нас мало (це м'яко кажучи), тому як виключення цей допис переклав за відсутності відповідей - але велике прохання правила всеж прочитати :)
« Змінено: 2008-04-25 23:15:10 від ISBear »
на жаль схоже, що Ваш модем не підтримується через slmodem, підтвердження було в кінці березня цього року, тобто шансів, що щось змінилося дуже мало...
Капець, а це що таке? У мене питання: як DalekiyObriy визначив за недіючим посиланням непрацездатність модему і як Melody вдалося встановити і задіяти драйвер для іншої версії ядра? :o
Відсутній Melody
  • дописів: 6
Так ось я не розумію, чому ядро у мене виявляється як і686,а насправді-то i586...Тому я правильно обрала модуль, чи ні? Що ще можна спробувати?
Полазив по мережі ще. В принципі спростувань того, про що написав DalekiyObriy не знайшов. Але все ж спробуйте:
1. Завантажте архів
2. Розпакуйте його.
3. Пересуньте програму slmodemd до теки /usr/sbin
4. Виконайте команду
slmodemd -c RUSSIA -- alsa hw:0,6
Якщо буде створено пристрій, то програма повідомить його назву, саме цю назву і слід вписати під час налаштування kppp.
P.S. Sandr вибачте, що трохи ввів Вас в оману: сам тільки-но розібрався до кінця (звик до звичайних PCI-модемів).
Edit:
Таки справді не працює — перевіряв у багатьох місцях... Marvin Stodolsky всіх записує до списку бажаючих, але результатів на початок квітня не видно... :(
« Змінено: 2008-04-26 21:29:39 від yurchor »
Капець, а це що таке? У мене питання: як DalekiyObriy визначив за недіючим посиланням непрацездатність модему…
не знаю, що сталося з сайтом, сподіваюсь він працює не через slmodem ;), але ось кешована версія листа з ґуґля:
Re: Sven, Germany kernel 2.6.22-14-generic
by Marvin Stodolsky :: Rate this Message:
Reply | Reply to Author | View Threaded | Show Only this Message
Sven
CHIP=0x11c11040
remains true.
You have been added to the List of those awating a solution.
But until then, read InfoGeneral.txt abour alternatives
MarvS
ключова фраза тут CHIP=0x11c11040
власне у розсилці було сказано, що Si3054 Modem має декілька конфігурацій, і якраз оцей підступний чіп є: а) новим, б) закритим, в) без драйверів...
повідомлення було 27 березня 2008, так що з slmodem шансів дуууже мало, десь всі посилаються на файл GenericInfo.txt в якому мають бути альтернативні шляхи, але я цього файлу так і не знайшов…
якщо хтось знайде інший шлях, думаю Melodi буде вдячна… головне — не копати DalekiyObriy у процесі пошуку, бо зарадити проблемі це не допоможе ;)
Відсутній Sandr
  • дописів: 461
  • Мій вибір — Лінукс!
    • ФОП Осипенко
Висловлю свою суб'єктивну думку з приводу цих софт-модемів.
Враховуючи цілу купу недоліків модемів цього типу:
-- підвищене навантаження на процесор;
-- відсутність реакції на сигнал "зайнято";
-- пряма залежність підтримки з'єднання від роботи процесора;
-- установлення з'єднання за п'ятим-десятим разом;
-- нестабільність передачі даних;
-- відсутність належної технічної підтримки з боку виробника;
-- розрив зв'язку при найменшому перевантаженні процесора;
-- часте "зависання" модема (відсутність набору номеру);
-- необхідність перезавантаження системи для виводу модему зі стану "зависання";
-- і т.д. і т.п. (і це я лише виявив за пару днів тестування).
Вважаю, що мабуть не варто скупитися й морочити собі й іншим голову, а придбати нормальний зовнішній модем, або хоча б внутрішній апаратний. Бо навіть при наявності драйвера цей модем нічого, окрім зіпсованих нервів, не принесе...
P.S. Вибачте, якщо висловився трохи не в тему  :-/
openSUSE + KDE
Но-но, то Ви просто не вмієте його готувати. ;)
/me якраз пише з-під такого модема...
Тепер Ви розумєте чому я по-дурному наїхав на DalekiyObriy. Мені теж у свій час всі торочили: та викинь ти його, він не працює, такі модеми нікому не потрібні...
Накопав ось що: здається наші китайські друзі знайшли вихід. Тут, у теці з підозріливою назвою 11c11040/ лежить пакуночок для Red Flag. До обіду перепакую під Mandriva і десь викладу.
Ось пакуночок.
1) Встановити
2) Перезавантажитись і потицяти у kppp на предмет /dev/modem
Скоріше за все не допоможе, але чому б не спробувати? (чесне піонерське, вірусів і руткітів всередині немає :))
Якщо не допоможе, просто вилучіть пакунок (здається зробив все, щоб вилучався чисто).
« Змінено: 2008-04-27 11:05:03 від yurchor »
Відсутній Melody
  • дописів: 6
Ой, дякую..Останніій пакунок спробую встановити, а ось з  slmodemd нічого не вийшло=(( Термінал ігнорує останню строку
Не подивився, що у Вас 2mdv. Перепакував і знову виклав... (див. вище)
Відсутній Melody
  • дописів: 6
Встановила, у списку пакунків є, але модем не впізнається.
« Змінено: 2008-04-27 11:43:53 від Melody »
Відсутній Sandr
  • дописів: 461
    • ФОП Осипенко
Подібна тема
« Відповідей #12 : 2008-04-27 11:59:08 »
Шановна Melody, ознайомтеся з оцією темою:
http://[center]http://linux.org.ua/cgi-bin/yabb/YaBB.pl?num=1208836770[/center]
Можливо там знайдете інформацію, яка дещо проллє світло на Вашу проблему.
openSUSE + KDE
Re: Подібна тема
« Відповідей #13 : 2008-04-27 15:11:50 »
Це буде трохи не ввічливо, але ознайомлюватися з тою темою мабуть немає сенсу (хіба що поглянути на виставку багатобічного неввігластва :-[). У Вас зовсім інший модем.
Якщо не спрацьовує depmod -a && modprobe agrserial (від root), то jigsaw's falling into place there was nothing to explain... :'(
За рік індусокодери (це не жарт, ними займаються саме індуси) LSI не написали драйвера, отже, скоріше за все, вже ніколи не напишуть, добре, якщо я помиляюся.
Відсутній Melody
  • дописів: 6
хех..так жаль втраченого часу..місяць шукала пояснень.НЕВЖЕ усі, хто має такі модеми просто забили на нього? depmod -a && modprobe agrserial -нічого не зрозуміла, поясніть будь ласка. А мені на іншому форумі казали, що є якийсь унивірсальний модуль для лінмодемів, але він працює якби у демці- 14,4 кбіт.сек. Ніхто не чув про нього? і martian, наприклад..
