Автор Гілка: Nvidia GeForce 7000M + Ubuntu  (Прочитано 8932 раз)
Відсутній smisha
  • дописів: 49
Re: Nvidia GeForce 7000M + Ubuntu
« Відповідей #15 : 2009-07-15 15:19:37 »
Ще одне. Після виконання команди sudo nvidia-settings в терміналі з'являються повідомлення про помилки:
smisha@smisha-laptop:~$ sudo nvidia-settings
[sudo] password for smisha:
ERROR: Cannot open display 'smisha-laptop:0.0'.
ERROR: Unable to assign attribute CursorShadow specified on line 21 of
       configuration file '/home/smisha/.nvidia-settings-rc' (no Display
       connection).
ERROR: Unable to assign attribute CursorShadowAlpha specified on line 22 of
       connection).
ERROR: Unable to assign attribute CursorShadowRed specified on line 23 of
       connection).
ERROR: Unable to assign attribute CursorShadowGreen specified on line 24 of
       connection).
ERROR: Unable to assign attribute CursorShadowBlue specified on line 25 of
       connection).
ERROR: Unable to assign attribute CursorShadowXOffset specified on line 26 of
       connection).
ERROR: Unable to assign attribute CursorShadowYOffset specified on line 27 of
       connection).
ERROR: Unable to assign attribute SyncToVBlank specified on line 28 of
       connection).
ERROR: Unable to assign attribute LogAniso specified on line 29 of
       connection).
ERROR: Unable to assign attribute FSAA specified on line 30 of configuration
       file '/home/smisha/.nvidia-settings-rc' (no Display connection).
ERROR: Unable to assign attribute TextureSharpen specified on line 31 of
       connection).
ERROR: Unable to assign attribute AllowFlipping specified on line 32 of
       connection).
ERROR: Unable to assign attribute FSAAAppControlled specified on line 33 of
       connection).
ERROR: Unable to assign attribute LogAnisoAppControlled specified on line 34 of
       connection).
ERROR: Unable to assign attribute OpenGLImageSettings specified on line 35 of
       connection).
ERROR: Unable to assign attribute RedBrightness specified on line 36 of
       connection).
ERROR: Unable to assign attribute GreenBrightness specified on line 37 of
       connection).
ERROR: Unable to assign attribute BlueBrightness specified on line 38 of
       connection).
ERROR: Unable to assign attribute RedContrast specified on line 39 of
       connection).
ERROR: Unable to assign attribute GreenContrast specified on line 40 of
       connection).
ERROR: Unable to assign attribute BlueContrast specified on line 41 of
       connection).
ERROR: Unable to assign attribute RedGamma specified on line 42 of
       connection).
ERROR: Unable to assign attribute GreenGamma specified on line 43 of
       connection).
ERROR: Unable to assign attribute BlueGamma specified on line 44 of
       connection).
ERROR: Unable to assign attribute DigitalVibrance specified on line 45 of
       connection).
ERROR: Unable to assign attribute ImageSharpening specified on line 46 of
       connection).
ERROR: Unable to assign attribute GPUScaling specified on line 47 of
       connection).
ERROR: Unable to assign attribute XVideoTextureSyncToVBlank specified on line
       48 of configuration file '/home/smisha/.nvidia-settings-rc' (no Display
       connection).
ERROR: Unable to assign attribute XVideoBlitterSyncToVBlank specified on line
       49 of configuration file '/home/smisha/.nvidia-settings-rc' (no Display
       connection).
ERROR: Unable to assign attribute XVideoSyncToDisplay specified on line 50 of
       connection).
« Відповідей #16 : 2009-07-15 15:50:47 »
Воно пише, що не може під’єднатися до іксів (графічного сервера), щоб вивести своє віконечко.
Найпростіше неправильне рішення - дозволити підключатися до дисплею всім: xhost +
Відсутній smisha
  • дописів: 49
« Відповідей #17 : 2009-07-15 16:27:24 »
Але після цих повідомлень про помилку діалог з налаштуваннями від Nvidia таки зявляється.
Відсутній smisha
  • дописів: 49
« Відповідей #18 : 2009-07-15 19:55:58 »
Я помітив що перед самим завантаженням Гнома, розділення екрану дійсно більше. Це видно по курсору і по статус-бару завантаження системи. Як тільки завантажується графічна оболонка гнома - розділення скидається і знову стає 800х600. Яскравість екрану також не зберігається.
Можливо ви в налаштуваннях Гнома щось поміняли?
Спробуйте виконати "xrandr -s 0" для переключення в перший відеорежим, прописаний в конфігурації.
Так! Перемикає в режим з потрібним розділенням. Що потрібно зробити щоб це відбувалось автоматично?
(Не памятаю щоб я десь в гномі лазив....)
Відсутній smisha
  • дописів: 49
« Відповідей #19 : 2009-07-15 20:01:48 »
Плвідомлення про помилки зявляються якщо виконати команду sudo nvidia-settings. Якщо ж перед нею розпочати сесію рута sudo -і, а вже потім nvidia-settings - то повідомлень немає. Зразу відкривається конфігуратор Nvidia.
М: Червоним пишуть дядьки з плюсометами.  :)
« Змінено: 2009-07-15 20:47:37 від Piktor »
« Відповідей #20 : 2009-07-15 20:07:46 »
Напевно запустити gnome-display-properties і виставити потрібний відеорежим. :-/
Відсутній smisha
  • дописів: 49
« Відповідей #21 : 2009-08-10 14:02:42 »
Не допомагає.
Що ж робити?
Ще раз нагадаю, що при завантаженні системи роздільна здатність правильна, а при завантаженні гнома вона змінюється на менше значення. Чому роздільна здатність сама змінюється? Хоча в xorg.conf все записано правильно.....  :(  :'(
« Відповідей #22 : 2009-08-10 18:21:19 »
Можете виконати xrandr --query --verbose і показати результат?
Відсутній smisha
  • дописів: 49
« Відповідей #23 : 2009-08-15 11:15:25 »
Ось результат команди:
Screen 0: minimum 320 x 240, current 800 x 600, maximum 1280 x 800
default connected 800x600+0+0 (0x1b2) normal (normal) 0mm x 0mm
      Identifier: 0x1ad
      Timestamp:  19337
      Subpixel:   unknown
      Clones:
      CRTC:       0
      CRTCs:      0
      Panning:    0x0+0+0
      Tracking:   0x0+0+0
      Border:     0/0/0/0
      Transform:  1.000000 0.000000 0.000000
                  0.000000 1.000000 0.000000
                  0.000000 0.000000 1.000000
                 filter:
  1280x800 (0x1ae)   51.2MHz
        h: width  1280 start    0 end    0 total 1280 skew    0 clock   40.0KHz
        v: height  800 start    0 end    0 total  800           clock   50.0Hz
  1024x768 (0x1af)   40.1MHz
        h: width  1024 start    0 end    0 total 1024 skew    0 clock   39.2KHz
        v: height  768 start    0 end    0 total  768           clock   51.0Hz
  960x540 (0x1b0)   27.0MHz
        h: width   960 start    0 end    0 total  960 skew    0 clock   28.1KHz
        v: height  540 start    0 end    0 total  540           clock   52.0Hz
  840x525 (0x1b1)   23.4MHz
        h: width   840 start    0 end    0 total  840 skew    0 clock   27.8KHz
        v: height  525 start    0 end    0 total  525           clock   53.0Hz
  800x600 (0x1b2)   25.9MHz *current
        h: width   800 start    0 end    0 total  800 skew    0 clock   32.4KHz
        v: height  600 start    0 end    0 total  600           clock   54.0Hz
  800x512 (0x1b3)   22.5MHz
        h: width   800 start    0 end    0 total  800 skew    0 clock   28.2KHz
        v: height  512 start    0 end    0 total  512           clock   55.0Hz
  720x450 (0x1b4)   18.1MHz
        h: width   720 start    0 end    0 total  720 skew    0 clock   25.2KHz
        v: height  450 start    0 end    0 total  450           clock   56.0Hz
  680x384 (0x1b5)   14.9MHz
        h: width   680 start    0 end    0 total  680 skew    0 clock   21.9KHz
        v: height  384 start    0 end    0 total  384           clock   57.0Hz
  680x384 (0x1b6)   15.1MHz
        h: width   680 start    0 end    0 total  680 skew    0 clock   22.3KHz
        v: height  384 start    0 end    0 total  384           clock   58.0Hz
  640x512 (0x1b7)   19.3MHz
        h: width   640 start    0 end    0 total  640 skew    0 clock   30.2KHz
        v: height  512 start    0 end    0 total  512           clock   59.0Hz
  640x480 (0x1b8)   18.4MHz
        h: width   640 start    0 end    0 total  640 skew    0 clock   28.8KHz
        v: height  480 start    0 end    0 total  480           clock   60.0Hz
  640x480 (0x1b9)   18.7MHz
        h: width   640 start    0 end    0 total  640 skew    0 clock   29.3KHz
        v: height  480 start    0 end    0 total  480           clock   61.0Hz
  576x432 (0x1ba)   15.4MHz
        h: width   576 start    0 end    0 total  576 skew    0 clock   26.8KHz
        v: height  432 start    0 end    0 total  432           clock   62.0Hz
  512x384 (0x1bb)   12.4MHz
        h: width   512 start    0 end    0 total  512 skew    0 clock   24.2KHz
        v: height  384 start    0 end    0 total  384           clock   63.0Hz
  400x300 (0x1bc)    7.7MHz
        h: width   400 start    0 end    0 total  400 skew    0 clock   19.2KHz
        v: height  300 start    0 end    0 total  300           clock   64.0Hz
  320x240 (0x1bd)    5.0MHz
        h: width   320 start    0 end    0 total  320 skew    0 clock   15.6KHz
        v: height  240 start    0 end    0 total  240           clock   65.0Hz
« Відповідей #24 : 2009-08-15 11:43:55 »
Ну у вас виставлено, що типовий режим: 800x600. Спробуйте поперемикати відеорежими з допомогою xrandr --size ... , напр. xrandr -s 1280x800
Відсутній smisha
  • дописів: 49
« Відповідей #25 : 2009-08-15 18:38:46 »
xrandr -s 1280x800   - розширення міняється, але після перезавантаження системи знову встановлюється 800Х600.
« Відповідей #26 : 2009-08-16 09:06:49 »
Я перепрошую, ви вже казали що у вас xrandr перемикає відеорежими.
Типовим відеорежимом у вас стоїть 800x600. Відеорежими виставляються в xorg.conf. Документація пише, що типовим відеорежимом стає той, який вказаний першим у опції Modes у підсекції Display секціїї Screen. Якщо такої опції нема, то ікси формують список відеорежимів автоматично зі стандартних відеорежимів VESA.
Не знаю, наскільки це відповідає правді, так як в іксах часто щось змінюють останнім часом. Раніше це працювало, а зараз ікси надто розумні. Спробуйте додати Modes "1280x800" "1024x768" "800x600" у xorg.conf у всі підсекції Display у секції Screen і подивіться, чи допоможе.
Якщо не вийде, поставте виклик xrandr у автозавантаження - майже так само робить gnome-display-settings.
Відсутній case0lc
  • дописів: 310
« Відповідей #27 : 2009-08-16 17:10:09 »
В  Ubuntu 9.04 не виставляються. Якщо nvidia-settings не працює, то це помилка в драйвері. Або поновіть драйвер, або використовуйте xrandr
Відсутній smisha
  • дописів: 49
« Відповідей #28 : 2009-08-16 19:42:33 »
nvidia-settings  працює до першого перезавантаження. Потім розділення збивається.
Чи можна в xrandr задати розділення екрану, яке буде використовуватись по замовчуванню?
Відсутній smisha
  • дописів: 49
« Відповідей #29 : 2009-08-17 16:42:12 »
А як викликати xrandr -s 1280x800 під час завантаження, підкажете?  :-/
