Автор Гілка: ffmpeg здурів  (Прочитано 1849 раз)
ffmpeg здурів
« : 2009-05-16 02:08:07 »
02:04 youtube$ ffmpeg -i ud.flv test.mpg
FFmpeg version 0.5, Copyright (c) 2000-2009 Fabrice Bellard, et al.
  configuration: --prefix=/usr --libdir=/usr/lib64 --shlibdir=/usr/lib64 --mandir=/usr/share/man --enable-static --enable-shared --cc=x86_64-pc-linux-gnu-gcc --disable-debug --disable-network --enable-libmp3lame --enable-libvorbis --enable-libxvid --disable-demuxer=v4l --disable-demuxer=oss --disable-muxer=oss --enable-x11grab --enable-pthreads --enable-libamr-nb --enable-libamr-wb --enable-nonfree --disable-altivec --disable-vhook --enable-gpl --enable-postproc --enable-avfilter --enable-avfilter-lavf --enable-swscale --disable-stripping --enable-hardcoded-tables
  libavutil     49.15. 0 / 49.15. 0
  libavcodec    52.20. 0 / 52.20. 0
  libavformat   52.31. 0 / 52.31. 0
  libavdevice   52. 1. 0 / 52. 1. 0
  libavfilter    0. 4. 0 /  0. 4. 0
  libswscale     0. 7. 1 /  0. 7. 1
  libpostproc   51. 2. 0 / 51. 2. 0
  built on May 15 2009 22:39:20, gcc: 4.1.2 (Gentoo 4.1.2 p1.1)
Seems stream 0 codec frame rate differs from container frame rate: 1000.00 (1000/1) -> 13.08 (157/12)
Input #0, flv, from 'ud.flv':
  Duration: 00:00:11.25, start: 0.000000, bitrate: 288 kb/s
    Stream #0.0: Video: flv, yuv420p, 176x144, 224 kb/s, 13.08 tbr, 1k tbn, 1k tbc
    Stream #0.1: Audio: mp3, 22050 Hz, mono, s16, 64 kb/s
Output #0, mpeg, to 'test.mpg':
    Stream #0.0: Video: mpeg1video, yuv420p, 176x144, q=2-31, 200 kb/s, 90k tbn, 12 tbc
    Stream #0.1: Audio: mp2, 22050 Hz, mono, s16, 64 kb/s
Stream mapping:
  Stream #0.0 -> #0.0
  Stream #0.1 -> #0.1
[mpeg1video @ 0xb709d0]MPEG1/2 does not support 12/1 fps
Error while opening codec for output stream #0.0 - maybe incorrect parameters such as bit_rate, rate, width or height
02:05 youtube$ ffmpeg -i ud.flv test.avi
Output #0, avi, to 'test.avi':
    Stream #0.0: Video: mpeg4, yuv420p, 176x144, q=2-31, 200 kb/s, 90k tbn, 13.08 tbc
Stream mapping:
  Stream #0.0 -> #0.0
  Stream #0.1 -> #0.1
Press [q] to stop encoding
frame=   60 fps=  0 q=1.6 Lsize=     287kB time=11.24 bitrate= 208.9kbits/s
video:180kB audio:88kB global headers:0kB muxing overhead 6.800534%
02:05 youtube$
Дивно, з яких це пір ffmpeg перестав розуміти розширення mpg?
Зовсім недавно конвертував ним і ніяких проблем не було  :o
Re: ffmpeg здурів
« Відповідей #1 : 2009-05-16 17:40:00 »
потрібно вказати вихідний fps напр. 30
в MPEG1 по специфікації досить обмежений набір частоти кадрів (здається на форумах казали 23.976, 24, 25, 29.97, 30, 50, 59.94 та 60), але не зміг швидко знайти джерело специфікації
Re: ffmpeg здурів
« Відповідей #2 : 2009-05-16 19:28:33 »
Дякую, що роззули мені очі  :-[ допомогло.
19:22 youtube$ ffmpeg -i ud.flv -r 25 test.mpg
    Stream #0.0: Video: mpeg1video, yuv420p, 176x144, q=2-31, 200 kb/s, 90k tbn, 25 tbc
Stream mapping:
  Stream #0.0 -> #0.0
  Stream #0.1 -> #0.1
[mpeg1video @ 0x25c09d0]warning, clipping 1 dct coefficients to -255..255
frame=  279 fps=  0 q=1.6 Lsize=     480kB time=11.12 bitrate= 353.6kbits/s
video:386kB audio:88kB global headers:0kB muxing overhead 1.311952%
Думаю, для телевізора найкраще - 50 герц. Просто перекодовую для двд плеєра (Supra з якимись там циферками і буковками). Може хто займався перекодуванням для плеєра - які там параметри найкраще форсувати?
