Автор Гілка: memtest FAILURE  (Прочитано 18427 раз)
Відсутній Volodymyrko
  • дописів: 370
  • I Like FreeBSD !
memtest FAILURE
« : 2009-05-07 17:28:09 »
на одноому FreeBSD-сервері
# memtest 2000 1
memtester version 4.0.8 (64-bit)
Copyright (C) 2007 Charles Cazabon.
Licensed under the GNU General Public License version 2 (only).
pagesize is 4096
pagesizemask is 0xfffffffffffff000
want 2000MB (2097152000 bytes)
got  2000MB (2097152000 bytes), trying mlock ...locked.
Loop 1/1:
  Stuck Address       : ok
  Random Value        : ok
  Compare XOR         : ok
FAILURE: 0x4a5ccc9a2364532e != 0x4a5ccc9a2464532e at offset 0x01d36e78.
  Compare SUB         : FAILURE: 0x1f0a34c2878ed788 != 0x5b80b045638ed788 at offset 0x01d36e78.
FAILURE: 0x71b6798e23e97054 != 0x353ffe0b47e97054 at offset 0x05a76478.
  Compare MUL         :   Compare DIV         : ok
  Compare OR          : ok
^C
# memtest 2100 1
pagesize is 4096
want 2100MB (2202009600 bytes)
got  2100MB (2202009600 bytes), trying mlock ...locked.
Loop 1/1:
  Stuck Address       : ok
  Random Value        : ok
  Compare XOR         : ok
  Compare SUB         : ok
FAILURE: 0x4510e8b053af4d != 0x73bcb0aead53af4d at offset 0x06492070.
  Compare OR          : ok
  Compare AND         : ok
^C
але не завжди
# memtest 2000 1
pagesize is 4096
Loop 1/1:
  Stuck Address       : ok
  Random Value        : ok
  Compare XOR         : ok
  Compare SUB         : ok
  Compare MUL         : ok
  Compare DIV         : ok
  Compare OR          : ok
  Compare AND         : ok
  Sequential Increment: ok
  Solid Bits          : ok
  Block Sequential    : setting 115^C
# memtest 2600 1
pagesize is 4096
want 2600MB (2726297600 bytes)
got  2600MB (2726297600 bytes), trying mlock ...failed for unknown reason.
Continuing with unlocked memory; testing will be slower and less reliable.
Loop 1/1:
  Stuck Address       : ok
  Random Value        : ok
  Compare XOR         : ok
  Compare SUB         : ok
FAILURE: 0x760685e005ff5488 != 0xfc7d80fb2dff5488 at offset 0x07cd9a70.
  Compare MUL         : FAILURE: 0x00000001 != 0x00000003 at offset 0x07cd9a70.
  Compare DIV         : FAILURE: 0x77b36214fefca0c1 != 0x77b36214fefca0c3 at offset 0x07cd9a70.
  Compare OR          :   Compare AND         : ok
  Solid Bits          : ok
  Block Sequential    : ok
  Checkerboard        : ok
  Bit Spread          : ok
  Bit Flip            : ok
  Walking Ones        : setting  78^C
в мене проблеми з памятюю  ???
та ше й сьогодні збірка ядра через раз вилітала з помилками .. для тестування збирав кілька раз.. особливо з опціює -j 5
« Змінено: 2009-05-07 17:29:10 від vova07 »
Відсутній Pablo
  • дописів: 96
  • Погроміст
Re: memtest FAILURE
« Відповідей #1 : 2009-05-11 09:22:56 »
Не обовязково з пам'яттю. Мемтест комплексно ганяє звязку процесор-шини-пам'ять. Ще більше заставляє сумніватись те, що збійна комірка у різних тестах має різні адреси.
Тихіше їдеш -дальше будеш...
від місця призначення
