Автор Гілка: Screen resolution  (Прочитано 5513 раз)
Відсутній nickson
  • дописів: 66
Re: Screen resolution
« Відповідей #15 : 2007-07-30 13:19:40 »
Я на це звернув увагу. Коли nv, то X-Server запускакється, а коли встановлюється двайвер і змінює nv на nvidia, то не запускається. Ось з таким конф файлом
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 1.0  (buildmeister@builder3)  Wed Jun 13 18:39:30 PDT 2007
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf(5) manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
    Identifier     "Default Layout"
    Screen         "Default Screen" 0 0
    InputDevice    "Generic Keyboard"
    InputDevice    "Configured Mouse"
    InputDevice    "stylus" "SendCoreEvents"
    InputDevice    "cursor" "SendCoreEvents"
    InputDevice    "eraser" "SendCoreEvents"
EndSection
Section "Files"
      # path to defoma fonts
    FontPath        "/usr/share/fonts/X11/misc"
    FontPath        "/usr/share/fonts/X11/cyrillic"
    FontPath        "/usr/share/fonts/X11/100dpi/:unscaled"
    FontPath        "/usr/share/fonts/X11/75dpi/:unscaled"
    FontPath        "/usr/share/fonts/X11/Type1"
    FontPath        "/usr/share/fonts/X11/100dpi"
    FontPath        "/usr/share/fonts/X11/75dpi"
    FontPath        "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
    Load           "i2c"
    Load           "bitmap"
    Load           "ddc"
    Load           "extmod"
    Load           "freetype"
    Load           "glx"
    Load           "int10"
    Load           "vbe"
EndSection
Section "InputDevice"
    Identifier     "Generic Keyboard"
    Driver         "kbd"
    Option         "CoreKeyboard"
    Option         "XkbRules" "xorg"
    Option         "XkbModel" "pc105"
    Option         "XkbLayout" "us"
EndSection
    Identifier     "Configured Mouse"
    Driver         "mouse"
    Option         "CorePointer"
    Option         "Device" "/dev/input/mice"
    Option         "Protocol" "ImPS/2"
    Option         "ZAxisMapping" "4 5"
    Option         "Emulate3Buttons" "true"
EndSection
    Identifier     "stylus"
    Driver         "wacom"
    Option         "Device" "/dev/input/wacom"
    Option         "Type" "stylus"
    Option         "ForceDevice" "ISDV4"            # Tablet PC ONLY
EndSection
    Identifier     "eraser"
    Driver         "wacom"
    Option         "Type" "eraser"
EndSection
    Identifier     "cursor"
    Driver         "wacom"
    Option         "Type" "cursor"
EndSection
Section "Monitor"
    Identifier     "Generic Monitor"
    HorizSync       28.0 - 51.0
    VertRefresh     43.0 - 60.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "nVidia Corporation NVIDIA Default Card"
    Driver         "nvidia"
EndSection
Section "Screen"
    Identifier     "Default Screen"
    Device         "nVidia Corporation NVIDIA Default Card"
    Monitor        "Generic Monitor"
    DefaultDepth    24
    SubSection     "Display"
        Depth       1
        Modes      "1024x768" "800x600" "640x480"
    EndSubSection
        Depth       4
    EndSubSection
        Depth       8
    EndSubSection
        Depth       15
    EndSubSection
        Depth       16
    EndSubSection
        Depth       24
    EndSubSection
EndSection
отримую такий лог:
X Window System Version 7.2.0
Release Date: 22 January 2007
X Protocol Version 11, Revision 0, Release 7.2
Build Operating System: Linux Ubuntu
Current Operating System: Linux NicksonPC 2.6.20-15-generic #2 SMP Sun Apr 15 07:36:31 UTC 2007 i686
Build Date: 04 April 2007
      Before reporting problems, check http://wiki.x.org
      to make sure that you have the latest version.
.............. і т.д. і .т.п. .....
(II) Setting vga for screen 0.
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Enabling RENDER acceleration
(II) NVIDIA(0): Support for GLX with the Damage and Composite X extensions is
(II) NVIDIA(0):     enabled.
(EE) NVIDIA(0): Failed to initialize the NVIDIA kernel module! Please ensure
(EE) NVIDIA(0):     that there is a supported NVIDIA GPU in this system, and
(EE) NVIDIA(0):     that the NVIDIA device files have been created properly.
(EE) NVIDIA(0):     Please consult the NVIDIA README for details.
(EE) NVIDIA(0):  *** Aborting ***
(II) UnloadModule: "nvidia"
(II) UnloadModule: "ramdac"
(II) UnloadModule: "wfb"
(II) UnloadModule: "fb"
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
Відсутній rangel
  • дописів: 281
  • Python programmer
« Відповідей #16 : 2007-07-30 14:20:35 »
#depmod -a
#modprobe nvidia
« Змінено: 2007-07-31 08:24:52 від rangel »
Roman Suprotkin
