Автор Гілка: wrapper  (Прочитано 2835 раз)
wrapper
« : 2009-08-05 21:37:58 »
на dict.linux.org.ua багато питають, отже:
Значення з ІТ:
* Primitive wrapper class, a computer term referring to a Java class in object-oriented programming
* TCP Wrapper, software used for filtering network access
* Wrapper (data mining), a technique used in data mining
* Wrapper Library
      o Driver wrapper, software that functions as an adapter between an operating system and a driver
      o Wrapper pattern, where some computer programming code allows certain classes to work together that otherwise would not
Загальне:
* обгортка
* о(б)кладинка (?)
wrapper library - бібліотека-обгортка?
