Автор Гілка: VMware Workstation в Kubuntu  (Прочитано 2883 раз)
Відсутній nickson
  • дописів: 66
« : 2007-07-08 21:05:27 »
Перший раз спробував поставити цю віртуалку (VMware-workstation-5.5.2-29772.tar) на кубунту. При збиранні виникла ось така помилка:
What is the location of the directory of C header files that match your running
kernel? [/lib/modules/2.6.20-15-generic/build/include]
Extracting the sources of the vmmon module.
Building the vmmon module.
Using 2.6.x kernel build system.
make: Entering directory `/tmp/vmware-config0/vmmon-only'
make -C /lib/modules/2.6.20-15-generic/build/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.20-15-generic'
  CC [M]  /tmp/vmware-config0/vmmon-only/linux/driver.o
In file included from /tmp/vmware-config0/vmmon-only/linux/driver.c:80:
/tmp/vmware-config0/vmmon-only/./include/compat_kernel.h:21: error: expected declaration specifiers or ‘...’ before ‘compat_exit’
/tmp/vmware-config0/vmmon-only/./include/compat_kernel.h:21: error: expected declaration specifiers or ‘...’ before ‘exit_code’
/tmp/vmware-config0/vmmon-only/./include/compat_kernel.h:21: warning: type defaults to ‘int’ in declaration of ‘_syscall1’
make[2]: *** [/tmp/vmware-config0/vmmon-only/linux/driver.o] Error 1
make[1]: *** [_module_/tmp/vmware-config0/vmmon-only] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-2.6.20-15-generic'
make: *** [vmmon.ko] Error 2
make: Leaving directory `/tmp/vmware-config0/vmmon-only'
Unable to build the vmmon module.
For more information on how to troubleshoot module-related problems, please
visit our Web site at "http://www.vmware.com/download/modules/modules.html" and
"http://www.vmware.com/support/reference/linux/prebuilt_modules_linux.html".
Execution aborted.
В чому тут справа?
Re: VMware Workstation в Kubuntu
« Відповідей #1 : 2007-07-08 21:12:51 »
Пошукайте на тему vmware-any-to-any update. Там є патч який усуває цю проблему.
P.S. Якщо не треба гратись то раджу Server - номери до нього роздають безкоштовно.
Відсутній nickson
  • дописів: 66
« Відповідей #2 : 2007-07-08 21:28:49 »
А що за Server? Можна конкретніше про нього, або лінк?
« Змінено: 2007-07-08 21:29:11 від nickson »
« Відповідей #3 : 2007-07-08 22:05:41 »
VMWare Server. Разом з VMWare Player входить до безкоштовних продуктів. Особливо приємно то, що гостьову систему можна завантажувати разом з головною - графічний інтерфейс усього лише консоль для підключення до серверу. Серед недоліків: не має підтримки апаратного прискорення відео. Особисто мені - саме то (якщо врахувати відеокартку з 16 мегабайтами мізків та проц 2 ГГц Athlon 64)
Відсутній nickson
  • дописів: 66
« Відповідей #4 : 2007-07-08 22:25:15 »
Важливий недолік. Хоча.. що мені вже говорити, :) - у мене в самому лінуксі не має підтримки і драйвери не пашуть з моєю нещасною x800gto.
Взалалі мені віртуалка з маздаєм потрібна як мінімум для двох речей - Photoshop і ABBYY Lingvo
« Змінено: 2007-07-08 22:27:41 від nickson »
« Відповідей #5 : 2007-07-08 23:33:20 »
Стосовно першого не впевнений, а от лінгва досить пристойно йде під вайном. Але я плюнув на ліцензійну угоду та переробив словники щоб підключити їх до stardict.
Відсутній nickson
  • дописів: 66
« Відповідей #6 : 2007-07-09 21:20:23 »
vmware-any-to-any update не допомогло.
А vmware Server встановився, але не запускається. Не знаю, чому, може через невдале встановлення vmware Workstation?
Mokus
« Відповідей #7 : 2008-01-13 10:36:57 »
Photoshop 7 іде під вайном
Данило Теодорович
« Відповідей #8 : 2008-01-13 13:24:37 »
Невже, GAIM в чомусь не сильний? Я його перекомпільованим на оффтопіку бачив.
« Відповідей #9 : 2008-01-13 13:42:36 »
Так. Він доволі слабкий у роботі з графікою - не вміє її редагувати ;D
« Змінено: 2008-01-13 13:42:58 від Praporshic »
Данило Теодорович
« Відповідей #10 : 2008-01-13 13:54:29 »
Не знаю...як на мене він простий, як двері.
« Відповідей #11 : 2008-01-13 14:02:29 »
Так. І ще він тепер зветься Pidgin  ::)
Пане, Ви хоч назви перевіряйте коли щось пишете.
Данило Теодорович
« Відповідей #12 : 2008-01-13 14:25:16 »
Тьфу...три рази і в іншу сторону від ваших постів і на 180 градусів від вашого форуму
/me гучно промовив GIMP!!!!, та й завернувся в подумках, що він не годний до серйозної балаканини і йому стало соромно :-[
