Автор Гілка: не можу обновити php в ubuntu?  (Прочитано 1918 раз)
Відсутній Volodymyrko
  • дописів: 370
  • I Like FreeBSD !
Ubuntu 10.04.1 LTS
# apt-cache showpkg libapache2-mod-php5
Package: libapache2-mod-php5
Versions:
5.3.2-1ubuntu4.7 (/var/lib/apt/lists/ua.archive.ubuntu.com_ubuntu_dists_lucid-updates_main_binary-i386_Packages) (/var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_lucid-security_main_binary-i386_Packages)
5.3.2-1ubuntu4 (/var/lib/apt/lists/ua.archive.ubuntu.com_ubuntu_dists_lucid_main_binary-i386_Packages)
5.2.10.dfsg.1-2ubuntu6.7 (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_karmic-security_main_binary-i386_Packages)
 Description Language:
5.2.10.dfsg.1-2ubuntu6 (/var/lib/apt/lists/ru.archive.ubuntu.com_ubuntu_dists_karmic_main_binary-i386_Packages) (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_karmic_main_binary-i386_Packages) (/var/lib/dpkg/status)
Dependencies:
5.3.2-1ubuntu4.7 - libbz2-1.0 (0 (null)) libc6 (2 2.11) libcomerr2 (2 1.01) libdb4.8 (0 (null)) libgssapi-krb5-2 (2 1.6.dfsg.2) libk5crypto3 (2 1.6.dfsg.2) libkrb5-3 (2 1.6.dfsg.2) libpcre3 (2 7.7) libssl0.9.8 (2 0.9.8k-1) libxml2 (2 2.7.4) zlib1g (2 1:1.1.4) mime-support (0 (null)) apache2-mpm-prefork (20 2.0.52) apache2-mpm-itk (0 (null)) apache2.2-common (0 (null)) php5-common (5 5.3.2-1ubuntu4.7) libmagic1 (0 (null)) ucf (0 (null)) tzdata (0 (null)) php-pear (0 (null)) libapache2-mod-php4 (0 (null)) libapache2-mod-php5filter (0 (null))
5.3.2-1ubuntu4 - libbz2-1.0 (0 (null)) libc6 (2 2.11) libcomerr2 (2 1.01) libdb4.8 (0 (null)) libgssapi-krb5-2 (2 1.6.dfsg.2) libk5crypto3 (2 1.6.dfsg.2) libkrb5-3 (2 1.6.dfsg.2) libpcre3 (2 7.7) libssl0.9.8 (2 0.9.8k-1) libxml2 (2 2.7.4) zlib1g (2 1:1.1.4) mime-support (0 (null)) apache2-mpm-prefork (20 2.0.52) apache2-mpm-itk (0 (null)) apache2.2-common (0 (null)) php5-common (5 5.3.2-1ubuntu4) libmagic1 (0 (null)) ucf (0 (null)) tzdata (0 (null)) php-pear (0 (null)) libapache2-mod-php4 (0 (null)) libapache2-mod-php5filter (0 (null))
5.2.10.dfsg.1-2ubuntu6.7 - libbz2-1.0 (0 (null)) libc6 (2 2.7) libcomerr2 (2 1.01) libdb4.7 (0 (null)) libgssapi-krb5-2 (2 1.6.dfsg.2) libk5crypto3 (2 1.6.dfsg.2) libkrb5-3 (2 1.6.dfsg.2) libpcre3 (2 7.7) libssl0.9.8 (2 0.9.8f-5) libxml2 (2 2.7.4) zlib1g (2 1:1.1.4) mime-support (0 (null)) apache2-mpm-prefork (20 2.0.52) apache2-mpm-itk (0 (null)) apache2.2-common (0 (null)) php5-common (5 5.2.10.dfsg.1-2ubuntu6.7) libmagic1 (0 (null)) ucf (0 (null)) tzdata (0 (null)) php-pear (0 (null)) libapache2-mod-php4 (0 (null)) libapache2-mod-php5filter (0 (null))
5.2.10.dfsg.1-2ubuntu6 - libbz2-1.0 (0 (null)) libc6 (2 2.7) libcomerr2 (2 1.01) libdb4.7 (0 (null)) libgssapi-krb5-2 (2 1.6.dfsg.2) libk5crypto3 (2 1.6.dfsg.2) libkrb5-3 (2 1.6.dfsg.2) libpcre3 (2 7.7) libssl0.9.8 (2 0.9.8f-5) libxml2 (2 2.7.4) zlib1g (2 1:1.2.3.3.dfsg) mime-support (0 (null)) apache2-mpm-prefork (20 2.0.52) apache2-mpm-itk (0 (null)) apache2.2-common (0 (null)) php5-common (5 5.2.10.dfsg.1-2ubuntu6) libmagic1 (0 (null)) ucf (0 (null)) tzdata (0 (null)) php-pear (0 (null)) libapache2-mod-php4 (0 (null)) libapache2-mod-php5filter (0 (null))
Provides:
5.3.2-1ubuntu4.7 - phpapi-20090626+lfs
5.3.2-1ubuntu4 - phpapi-20090626+lfs
5.2.10.dfsg.1-2ubuntu6.7 - phpapi-20060613+lfs
5.2.10.dfsg.1-2ubuntu6 - phpapi-20060613+lfs
Reverse Provides:
в налаштуваннях apt прописані репозиторії karmic, для того щоб можна було використовувати php-5.2 (а не 5.3, яке є по замовчуванні)
в /etc/apt/preferences.d/php
Package: php5
Pin: release a=karmic
Pin-Priority: 991
Pin-Priority: 991
dpkg -l |g php
ii  libapache2-mod-php5                 5.2.10.dfsg.1-2ubuntu6            server-side, HTML-embedded scripting languag
ii  php-pear                            5.2.10.dfsg.1-2ubuntu6            PEAR - PHP Extension and Application Reposit
ii  php5                                5.2.10.dfsg.1-2ubuntu6            server-side, HTML-embedded scripting languag
на скільки я розумію в мене стоїть зараз версія 5.2.10.dfsg.1-2ubuntu6 ... але я ю хотів оновитися до 5.2.10.dfsg.1-2ubuntu6.7
# apt-get  install libapache2-mod-php5
Reading package lists... Done
Building dependency tree
Reading state information... Done
libapache2-mod-php5 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
# apt-get  install -php5
E: Command line option 'p' [from -php5] is not known.
root@ns1:/etc/apt/preferences.d# apt-get  install php5
Підкажіть,  чи я шось не так роблю.. чи чогось не розумію.. ??? чому   "is already the newest version" ?
  • дописів: 370
  • I Like FreeBSD !
Re: не можу обновити php в ubuntu?
« Відповідей #1 : 2011-01-13 15:23:33 »
вдалося таки обновити...
правда не знаю чи то був правильний спосіб..
забрав тимчасово файлик /etc/apt/preferences.d/php..
apt-get update
apt-get   -t karmic install php5 php5-cgi php5-cli php5-curl php5-gd php5-mhash php5-mysql php5-xmlrpc php-pear php5-mcrypt   php5-common  libapache2-mod-php5
пішов процес.............
відновив файлик..
apt-get  сказав що хоче зробити downgrade
root@ns1:/etc/apt/preferences.d# apt-get -s upgrade
The following packages will be DOWNGRADED:
  libapache2-mod-php5 php-pear php5 php5-cgi php5-cli php5-common php5-curl php5-gd php5-mhash php5-mysql php5-xmlrpc
0 upgraded, 0 newly installed, 11 downgraded, 0 to remove and 0 not upgraded.
тоді спробував в /etc/apt/preferences.d/php замінити
на
Pin: release a=karmic-security
все ніби нормально
apt-get -s upgrade
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Відсутній nickat
  • дописів: 587
  • Debian user
« Відповідей #2 : 2011-01-13 17:32:58 »
Pin: release a=karmic вказує архів до якого повинен належати пакунок.  Версія, яку ви хотіли встановити, — це security-update, тому вона знаходиться в архіві karmic-security.  Може варто вказати не назву архіву, а назву реліза: Pin: release n=karmic ?
Best regards,
nickat
  • дописів: 370
  • I Like FreeBSD !
« Відповідей #3 : 2011-01-14 10:39:37 »
напевно шо варто, зараз поміняю ...  просто я не вникав в ті всі опції !!!  перший раз робив по знайденому мануалу.. і думав що результат буде такий як при Pin: release n=karmic, тобто оновлення для karmic будуть ставитися...
може, щоб не плодити нову напівтему, хтось підкаже
вчора робив apt-get upgrade /// він не хотів ядро обновляти .. видавав  ядро-нова-версія have been kept back , а aptitude - обновив ядро..
сьогодні  подивився, щось схоже знову, але вже з  landscape-common
#aptitude -s safe-upgrade
Reading extended state information
Initializing package states... Done
Resolving dependencies...
The following NEW packages will be installed:
  bc{a}
The following packages will be REMOVED:
  linux-headers-2.6.32-22{u} linux-headers-2.6.32-22-server{u} linux-headers-2.6.32-24{u} linux-headers-2.6.32-24-server{u} linux-headers-2.6.32-26{u} linux-headers-2.6.32-26-server{u}
The following packages will be upgraded:
  landscape-common
1 packages upgraded, 1 newly installed, 6 to remove and 0 not upgraded.
Need to get 338kB of archives. After unpacking 256MB will be freed.
Do you want to continue? [Y/n/?] n
Abort.
The following packages have been kept back:
  landscape-common
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
в неті вичитав, що то або може бути що бракує залежностей, або треба зробити спочатку  apt-get dist-upgrade ... потім вже і ap-get обновить даний пакет
