Автор Гілка: Центр програм висне й глючить  (Прочитано 1647 раз)
Відсутній Djalin
  • дописів: 662
Власне сабж - запускається лише через консоль і то з помилками, хто ще стикався?
[code sudo software-center
2012-09-04 15:22:32,186 - softwarecenter.fixme - WARNING - logs to the root logger: '('/usr/lib/python2.7/dist-packages/gi/importer.py', 51, 'find_module')'
2012-09-04 15:22:32,186 - root - ERROR - Could not find any typelib for Gst
2012-09-04 15:22:32,938 - softwarecenter.ui.gtk3.app - INFO - setting up proxy 'None'
2012-09-04 15:22:33,004 - softwarecenter.db.database - INFO - open() database: path=None use_axi=True use_agent=True
2012-09-04 15:22:33,841 - softwarecenter.region - WARNING - failed to use geoclue: 'org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Geoclue.Master was not provided by any .service files'
2012-09-04 15:22:35,223 - softwarecenter.backend.reviews - WARNING - Could not get usefulness from server, no username in config file
2012-09-04 15:22:36,246 - softwarecenter.ui.gtk3.app - INFO - show_available_packages: search_text is '', app is None.
2012-09-04 15:22:36,248 - softwarecenter.db.pkginfo_impl.aptcache - INFO - aptcache.open()
2012-09-04 15:22:56,901 - softwarecenter.region - WARNING - failed to use geoclue: 'org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Geoclue.Master was not provided by any .service files'
2012-09-04 15:23:08,130 - softwarecenter.ui.gtk3.app - INFO - software-center-agent finished with status 0
2012-09-04 15:23:08,185 - softwarecenter.db.database - INFO - reopen() database
2012-09-04 15:23:08,185 - softwarecenter.db.database - INFO - open() database: path=None use_axi=True use_agent=True
2012-09-04 15:23:12,951 - softwarecenter.ui.gtk3.widgets.exhibits - WARNING - download failed: '<class 'gi._glib.GError'>', 'Операція не підтримується'
[/code]
