Автор Гілка: Unknown media type in type 'chemical/x-cache'  (Прочитано 5074 раз)
Що воно таке?
Обрабатываются триггеры для man-db …
Обрабатываются триггеры для hicolor-icon-theme …
Обрабатываются триггеры для shared-mime-info …
Unknown media type in type 'chemical/x-alchemy'
Unknown media type in type 'chemical/x-cactvs-ascii'
Unknown media type in type 'chemical/x-cactvs-binary'
Unknown media type in type 'chemical/x-cactvs-table'
Unknown media type in type 'chemical/x-cdx'
Unknown media type in type 'chemical/x-cdxml'
Unknown media type in type 'chemical/x-chem3d'
Unknown media type in type 'chemical/x-cif'
Unknown media type in type 'chemical/x-cml'
Unknown media type in type 'chemical/x-daylight-smiles'
Unknown media type in type 'chemical/x-dmol'
Unknown media type in type 'chemical/x-gamess-input'
Unknown media type in type 'chemical/x-gamess-output'
Unknown media type in type 'chemical/x-gaussian-input'
Unknown media type in type 'chemical/x-gaussian-log'
Unknown media type in type 'chemical/x-genbank'
Unknown media type in type 'chemical/x-gulp'
Unknown media type in type 'chemical/x-hin'
Unknown media type in type 'chemical/x-inchi'
Unknown media type in type 'chemical/x-inchi-xml'
Unknown media type in type 'chemical/x-jcamp-dx'
Unknown media type in type 'chemical/x-macromodel-input'
Unknown media type in type 'chemical/x-mdl-molfile'
Unknown media type in type 'chemical/x-mdl-rdfile'
Unknown media type in type 'chemical/x-mdl-rxnfile'
Unknown media type in type 'chemical/x-mdl-sdfile'
Unknown media type in type 'chemical/x-mdl-tgf'
Unknown media type in type 'chemical/x-mmcif'
Unknown media type in type 'chemical/x-mol2'
Unknown media type in type 'chemical/x-mopac-graph'
Unknown media type in type 'chemical/x-mopac-input'
Unknown media type in type 'chemical/x-mopac-out'
Unknown media type in type 'chemical/x-msi-car'
Unknown media type in type 'chemical/x-msi-hessian'
Unknown media type in type 'chemical/x-msi-mdf'
Unknown media type in type 'chemical/x-msi-msi'
Unknown media type in type 'chemical/x-ncbi-asn1'
Unknown media type in type 'chemical/x-ncbi-asn1-binary'
Unknown media type in type 'chemical/x-ncbi-asn1-xml'
Unknown media type in type 'chemical/x-pdb'
Unknown media type in type 'chemical/x-shelx'
Unknown media type in type 'chemical/x-vmd'
Unknown media type in type 'chemical/x-xyz'
Unknown media type in type 'all/all'
Unknown media type in type 'all/allfiles'
Unknown media type in type 'uri/mms'
Unknown media type in type 'uri/mmst'
Unknown media type in type 'uri/mmsu'
Unknown media type in type 'uri/pnm'
Unknown media type in type 'uri/rtspt'
Unknown media type in type 'uri/rtspu'
Обрабатываются триггеры для libc-bin …
Бо воно мене лякає  [smiley=am.gif]
Відсутній Djalin
  • дописів: 662
Re:  Unknown media type in type 'chemical/x-cache'
« Відповідей #1 : 2014-06-02 22:37:49 »
Мовою кватирок це щось на кшталт, реєструються компоненти, додаємо ярлики і так далі.
Власне а чому лякає?  :o
« Змінено: 2014-06-02 22:38:53 від djalin »
« Відповідей #2 : 2014-06-02 23:07:22 »
та ні. то якісь помилки.  :-/
Відсутній Djalin
  • дописів: 662
« Відповідей #3 : 2014-06-02 23:12:07 »
Ви про
Unknown
це дуже може бути залишки проблем з асоціаціями, десь тут ваша ж тема й була...
знайшов осьо ваша тема
« Змінено: 2014-06-02 23:21:40 від djalin »
Вася Пупкин
« Відповідей #4 : 2014-06-02 23:21:52 »
Опен Сус, ідентично.
ihor@linux-agj5:~> sudo zypper install kdenlive
root's password:
Завантаження даних сховища...
Читання встановлених пакунків...
Розв’язання залежностей пакунків...
Буде встановлено НОВИЙ пакунок:
  kdenlive
1 новий пакунок встановити.
Загальний розмір звантаження: 3,7 MiB. Після дії, буде додатково використано
13,2 MiB.
Продовжити? [т/н/? shows all options] (т): т
Звантаження пакунок kdenlive-0.9.8-9.2.x86_64
                                      (1/1),   3,7 MiB ( 13,2 MiB розпаковано)
Звантаження: kdenlive-0.9.8-9.2.x86_64.rpm ..........[завершено (360,7 KiB/s)]
(1/1) Встановлення: kdenlive-0.9.8-9.2 ............................[завершено]
Додатковий вивід rpm:
ihor@linux-agj5:~>
Відсутній Djalin
  • дописів: 662
« Відповідей #5 : 2014-06-02 23:27:50 »
підозра - інсталятор просто перебирає всі види файлів й опитує програму чи не робити асоціації
а за Продовжити? [т/н/? shows all options] (т): т треба руки повідбивати
« Змінено: 2014-06-02 23:32:16 від djalin »
« Відповідей #6 : 2014-06-03 00:20:49 »
Про yes-ні, no-так я ;D , здається, зрозумів. А от про "оті помилки"... хйзн  :-/
« Змінено: 2014-06-03 00:21:44 від idontremember »
Відсутній Djalin
  • дописів: 662
« Відповідей #7 : 2014-06-03 19:08:04 »
так осьо вони
я думав розібрались вже
« Відповідей #8 : 2014-06-03 21:06:53 »
Ті проблеми я вирішив, бо у мене графка не розпізнавалась та і всі файли були  "невизначеного типу".  :o
Але воно у  мене зникло і знову вилізло - і невже знову та сама проблема???
Тільки то у мене вся графіка не розпізнавалась, а тепер шо...  :-/ ? і головне ЧОМУ???
« Змінено: 2014-06-03 21:10:42 від idontremember »
keithfay
« Відповідей #9 : 2014-06-03 21:44:55 »
Може буде корисно.
Debian працює із пакетами .deb, із .rpm - погано (читав в мануалах коли вирішував свої проблеми), тому радять використовувати програму alien, але вона не конвертує зі 100% гарантією, тому краще одразу шукати .deb пакети, якщо є можливість.
r00t x
« Відповідей #10 : 2014-06-04 07:39:51 »
у мене бубу...
