Автор Гілка: Вильоти убунту  (Прочитано 3043 раз)
Відсутній Djalin
  • дописів: 662
Вильоти убунту
« : 2020-03-21 18:10:51 »
Доброго дня, як правильно діагностувати вильоти?
Проявляються у двох варіантах - або фріз, і допомагає лише ресет, або спонтанне перезавантаження
Логи  сіслог
Mar 21 18:07:02 Djalin-Home systemd[1]: Started Postfix Mail Transport Agent (instance -).
Mar 21 18:07:02 Djalin-Home systemd[1]: Starting Postfix Mail Transport Agent...
Mar 21 18:07:02 Djalin-Home systemd[1]: Started Postfix Mail Transport Agent.
Mar 21 18:07:02 Djalin-Home systemd[1]: Reached target Multi-User System.
Mar 21 18:07:02 Djalin-Home systemd[1]: Reached target Graphical Interface.
Mar 21 18:07:02 Djalin-Home systemd[1]: Starting Update UTMP about System Runlevel Changes...
Mar 21 18:07:02 Djalin-Home systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
Mar 21 18:07:02 Djalin-Home systemd[1]: Started Update UTMP about System Runlevel Changes.
Mar 21 18:07:02 Djalin-Home systemd[1]: Startup finished in 10.325s (firmware) + 4.205s (loader) + 3.743s (kernel) + 9.637s (userspace) = 27.910s.
Mar 21 18:07:02 Djalin-Home systemd[1]: Started Daemon for generating UUIDs.
Mar 21 18:07:02 Djalin-Home rtkit-daemon[1514]: Supervising 3 threads of 2 processes of 1 users.
Mar 21 18:07:03 Djalin-Home ntpd[1256]: Listen normally on 4 wlx00e02d3c0b43 192.168.0.101:123
Mar 21 18:07:03 Djalin-Home ntpd[1256]: Listen normally on 5 wlx00e02d3c0b43 [fe80::fcb3:9b40:33e3:343%3]:123
Mar 21 18:07:03 Djalin-Home ntpd[1256]: new interface(s) found: waking up resolver
Mar 21 18:07:05 Djalin-Home rtkit-daemon[1514]: Supervising 3 threads of 2 processes of 1 users.
Mar 21 18:07:05 Djalin-Home rtkit-daemon[1514]: message repeated 3 times: [ Supervising 3 threads of 2 processes of 1 users.]
Mar 21 18:07:05 Djalin-Home rtkit-daemon[1514]: Successfully made thread 2665 of process 2083 owned by '1000' RT at priority 10.
Mar 21 18:07:05 Djalin-Home rtkit-daemon[1514]: Supervising 4 threads of 3 processes of 1 users.
Mar 21 18:07:08 Djalin-Home systemd-resolved[1013]: Server returned error NXDOMAIN, mitigating potential DNS violation DVE-2018-0001, retrying transaction with reduced feature level UDP.
[code]
що ще потрібно?
Відсутній Djalin
  • дописів: 662
Re: Вильоти убунту
« Відповідей #1 : 2020-03-21 19:28:39 »
Цікавлюсь взагалі, куди дивитись і на що звертати увагу, діагностика лінуксу - це для мене нова річ.
Re: Вильоти убунту
« Відповідей #2 : 2020-03-22 14:18:34 »
Я, зазвичай, дивлюся на журнал journald. Ну, щось там таке:
journalctl --since "1 hour ago"Але, на жаль, усі проблеми, які у мене були, суто апаратні. Здихав вінчестер, відвалювалося кріплення планки пам'яті на материнській платі, були проблеми із кабелем USB...
Відсутній bebyx
  • дописів: 69
    • bebyx
Re: Вильоти убунту
« Відповідей #3 : 2020-03-22 18:03:44 »
На днях схожу проблему на лаптопі дружини вирішив тим, що оновив пакунки. Себто помогло звичайне:
sudo apt upgrade
Може зарадить і вам.  :)
Відсутній Djalin
  • дописів: 662
Re: Вильоти убунту
« Відповідей #4 : 2020-03-23 12:18:03 »
оновитись не можу, бо з новим ядром не заводиься відео, та ж проблема у дебіані - тільки там я ще й ві-фі завести не зміг, але то окрема тема.
Зараз більш цікавить як по логах виявляти у чому проблема.
Відсутній Djalin
  • дописів: 662
Re: Вильоти убунту
« Відповідей #5 : 2020-03-23 12:18:35 »
sudo apt upgrade
ну залізо у мене нове...буду дивитись
