Автор Гілка: GIMP-2.1  (Прочитано 3528 раз)
GIMP-2.1
« : 2004-06-03 19:29:55 »
Доступний звідси: http://ftp://ftp.gimp.org/pub/gimp/v2.1/
Зміни:
  • Великі частини інтерфейсу були переписані для відповідності Рекомендаціям по написанню Інтерфейсу Корисувача для Ґнома.
  • Користувачі тепер можуть очищувати історію.
  • Використовується GTK+ 2.4, з усіма його перевагами.
  • The unit to be used for the rulers and the coordinates display is now
a display property and can be changed in the statusbar of the image
window.
  • New widgets and frameworks provided by GTK+ 2.4 are used; this means
    • uses the new GtkFileChooser dialog, vastly improving the file
    dialogs.
    • includes port of menus to GtkUIManager, which creates all core
    menus from XML files at runtime. This means that menu items can
    be rearranged by users simply by editing these files.
    • uses a global accelerator table in all docks and image windows.
    This means that a hotkey will do the same thing regardless of
    which dock or image window you are using.
    • adds replacement widgets based on GtkComboBox for most uses of
    GtkOptionMenu (GimpUnitMenu remains to be ported)
    • adds GimpContainerEntry, a GtkEntry with completion based on
    the contents of a GimpContainer.
    • makes the order and visibility of tools in the toolbox configurable
    • allows keeping toolbox and dock windows above other windows (if
    the WM supports this hint)
    [/list]
    • The toolbox now has an optional preview of the active image.
    • The image window now accepts file/uri drops.
    • More internal cleanup and refactoring of the core object model.
    • The brush rendering code has been separated from the generic paint
    tool code. The ink tool is now a paint tool (it can do straight
    lines) and the new infrastructure allows to implement new kinds of
    paint methods like vector based painting.
    • Gradients can now be created, deleted, renamed and edited through
    the PDB.
    • Some changes to plug-ins.
    • Plug-ins can now register the same procedures in multiple places (the API to register menu entries has been changed in a backward-compatible fashion).
    • Plug-ins can now optionally register a menu icon.
    • File plug-ins can now register a mime-type.
    • All plug-in dialogs have been reviewed and changed to make them
    comply better with the GNOME Human Interface Guidelines.
    • All plug-ins that need to access files use the new GtkFileChooser
    dialog.
    • The obsolete AlienMap and GIcon plug-ins were removed. AlienMap2
    does everything than AlienMap did, and the GIMP-specific GIcon format
    has not been used by anything for quite some time now.
    • A plug-in to load and save windows icon files has been added.
    dusoft
    Re: GIMP-2.1
    « Відповідей #1 : 2004-06-04 01:48:41 »
    Хе-хе :) Невже ми випередили ЛОР? Непогано-непогано.. :) А там нарешті з'явилася підтримка 16-бітного формату(там якийсь новий двигун графічний повинен був з'явитися..), про який на лорі усілякі нібито знавці поліграфії говорили?
    Відсутній preacher
    • дописів: 10
    • Пінґвінятко
    Re: GIMP-2.1
    « Відповідей #2 : 2004-06-04 12:58:49 »
    Ну то про шо я казав. Будуть новини своєчасно і у достатньому об'єму, будуть і відвідувати сторінку. Справді тішить факт, що новина тут з'явилась першою ніж на ішнших джерелах.
    [Mandrake] [Fedora] [Olympus]
