Автор Гілка: Wine 0.9  (Прочитано 1955 раз)
k_ilya
Wine 0.9
« : 2005-10-25 18:00:14 »
Вільна реалізація Віндовс на Юнікс після 12 років розробки перейшла у стадію бета тестування
This is release 0.9 of Wine, a free implementation of Windows on Unix.
After 12 years of development, this release marks the beginning of the
beta testing phase.  Everybody is encouraged to try it; while there
are still bugs, most applications are expected to at least install and
do something useful.
Because of lags created by using mirrors, this message may reach you
before the release is available at the ftp sites.  The sources will be
available from the following locations:
  http://ibiblio.org/pub/linux/system/emulators/wine/wine-0.9.tar.bz2
  http://prdownloads.sourceforge.net/wine/wine-0.9.tar.bz2
Binary packages for various distributions will be available from:
  http://www.winehq.org/site/download
You will find documentation on http://www.winehq.org/site/documentation.
You can also get the current source directly from the CVS tree. Check
http://www.winehq.org/cvs for details.
Patches should be submitted to "wine-patches@winehq.org".  Please
don't forget to include a ChangeLog entry. If you submitted a patch,
please check to make sure it has been included in the new release.
Wine is available thanks to the work of many people. See the file
AUTHORS in the distribution for the complete list.
Re: Wine 0.9
« Відповідей #1 : 2005-10-27 13:11:46 »
Modplug Tracker вже працює. А от InstallShield 6 поламатий -- софтину встановити не можу :(
