Автор Гілка: Parrot 0.4  (Прочитано 1898 раз)
Parrot 0.4
« : 2005-12-08 16:11:26 »
Parrot - це віртуальна машина для різних мов програмування (в першу чергу - Perl6).
Нові можливості Parrot 0.4:
  • New lexical handling and closure support including better introspection for caller and outer
  • PGE (Parrot Grammar Engine) provides now compilers for P6Rule, P6Grammar, P5Regexp, and Glob
  • ca. 1000 new tests including 800 for Perl5 regexp
  • Improved unicode charset and encoding support
  • Calling conventions for exception handlers
  • Punie (Perl 1) uses TGE (Tree Grammar Engine) to convert from PGE match objects to AST via two steps of tree transformation grammars
  • New languages: amber and lua
  • The usual code fixes, cleanup, and improvements, including an overhaul of the config and test framework
http://use.perl.org/article.pl?sid=05/12/05/1536259
