Автор Гілка: Modem Shuts-off Every 5 Min Under Suse9.1  (Прочитано 1369 раз)
Відсутній Fotokor
  • дописів: 90
  • Он воно як....
« : 2004-11-07 17:33:30 »
9.1 Pro works perfectly with US Rob 56 kb modem BUT when I install by Yast RPM any newer kernel - say 2.6.8-2 -Internet connection shuts down every 5 min  Only return to the original 2.6.4-52 solvs the problem.... Tested 3 newer kernels - all with this 5 min limit.......playing with /etc/ppp/options - did not help.......Log shows: terminating connection due to the lack of activity.....the connection was idle and shut down....... (which is not true - I was browsing the web) -------------this story happens every day and each time I log-in - so i am writing this message from my Wind2000 to have more than 5 min limit.......Any Live Linux -cd or Fedora (e.g) works without interruption on the Net -----so the Problem is in the SuSE - who can HELP me ?
Вибачаюсь що непереклав :Це просто копiя мого Оголошення на http://forums.suselinuxsupport.de
але там ще нiхто не допомiг  ???
« Змінено: 2004-11-08 19:42:41 від Fotokor »
Work Less - Live Longer
