Автор Гілка: Fedora 10  (Прочитано 8778 раз)
Fedora 10
« : 2008-11-25 18:24:32 »
Вийшла нова, ювілейна, 10-та версія дистрибутиву Федора.
Список реалізованого:
  • AMQP Infrastructure - A technology that makes it easy to build scalable, interoperable, high-performance enterprise applications
  • Appliance Tools - Tools and meta-data that make it easier for anyone (ISVs, developers, OEMS, etc) to create and deploy virtual appliances
  • Artistic 1.0 License Removal - Remove all packages licensed under only the Artistic 1.0 license before Fedora 10
  • Better Printing - Improve management and handling of printers
  • Better Remote Support - Make it easier to connect to remote controls and have them just work with many applications.
  • Better Start-up - Stream line graphical start up
  • Better Webcam Support - Improved webcam support
  • Connection Sharing - Enable adhoc network sharing
  • Eclipse 3.4 - Rebase Eclipse to version 3.4
  • Evdev Input Driver - Evdev is being used as the default input driver for X.Org.
  • Faster Startup - Decrease the amount of time it takes to start and stop fedora
  • First Aid Kit - First Aid Kit is an automated recovery tool that brings together common recovery processes and applies them to a system
  • Glitch Free Audio - Rewrite the PulseAudio sound server to use timer-based audio scheduling
  • Gnome 2.24 - Re-base Fedora to Gnome 2.24
  • GStreamer RPM dependencies - Assist automated installation of GStreamer codecs provided by third-party repositories
  • Kernel Modes Setting for Graphics - Move graphic mode initialization from the X server's DDX drivers to the kernel
  • LiveConnect - Allows JavaScript from web browsers to connect to a Java(TM) Virtual Machine and vice-versa.
  • LXDE Desktop - Make the LXDE lightweight X11 desktop environment available in Fedora
  • NetBeans IDE - Add the NetBeans IDE to Fedora
  • Online Accounts Service - Provides applications with credentials for user's online accounts listed on online.gnome.org or stored in GConf.
  • Python NSS Bindings - Include a newly developed package which provides python bindings for NSS
  • Remote Virtual Install - Enable the creation of virtual machines on remote hosts
  • RPM 4.6 - Update RPM to 4.6
  • Save to Bugzilla - Auto create bugzilla entry with anaconda tracebacks
  • Sbin Sanity - Add /usr/local/sbin:/usr/sbin:/sbin to the PATH for normal users to simplify command-line administration tasks
  • Security Audit - A new security audit system and intrusion detection system
  • Sugar Desktop - Include the Sugar Desktop (used in OLPC) in Fedora
  • Virtual Storage - Make storage provisioning over libvirt connections (local and remote) virtual machines as simple as possible.
Оголошення: https://www.redhat.com/archives/fedora-announce-list/2008-November/msg00015.html
Список нових можливостей: http://fedoraproject.org/wiki/Releases/10/FeatureList
« Змінено: 2008-11-25 18:39:01 від lvm »
Re: Fedora 10
« Відповідей #1 : 2008-11-25 18:49:44 »
Ікси переповзли на першу консоль, тепер треба тиснути Ctrl-Alt-F2 щоб попасти в текстову консоль і Alt-F1 щоб повернутися назад.
Відсутній gvy
  • дописів: 576
Re: Fedora 10
« Відповідей #2 : 2008-11-25 20:56:51 »
Re: Fedora 10
« Відповідей #3 : 2008-11-25 21:35:05 »
слава Аллаху! маю надію, що ця версія буде стабільною.
а кеди там які?
Re: Fedora 10
« Відповідей #4 : 2008-11-25 21:43:21 »
а кеди там які?
Цього разу Аллах не був милостивим - 4.1.3
Re: Fedora 10
« Відповідей #5 : 2008-11-25 22:14:16 »
ну, я будем сподіватися, що аж сильно падати вони не будуть. щось набридли вже треті.
фуух!
я думав, це ви мені зірочку вліпили за порушення п. 4.1.3 правил «розпалювання міжрелігійної ворожнечі», поліз читати — а там нема такого пункту  ;D
Re: Fedora 10
« Відповідей #6 : 2008-11-25 23:04:26 »
Flame:
Епічна брехня +  роздвоєння особистості. ;)
Ви вже набридли своїм нескінченним ниттям. Не подобається — не користуйтеся.
Заповзайте назад у GNOME. У мене 4.1.2 за місяць ще ні разу не впали (я маю на увазі повідомлення від kickoff про SIGXXX). У KDE4 не вистачає функціональності, але середовище не падає. Хто сумнівається, ласкаво просимо на bugs.kde.org.
« Змінено: 2008-11-25 23:05:49 від yurchor »
Re: Fedora 10
« Відповідей #7 : 2008-11-25 23:25:45 »
yurchor, я сьогодні нехоліварабельний. коротше, підтримую вас повністю, і навіть збираюся апдейтитись. :)
Re: Fedora 10
« Відповідей #8 : 2008-11-26 03:58:33 »
А що там з прискоренням запуску операційки? Чи то все реклама?
Re: Fedora 10
« Відповідей #9 : 2008-11-26 08:54:33 »
А мені - четверті. Цікаво, в Fedora 10 xmonad є? У всякому разі, в тому комплекті, що gvy качає. Чи доставляти ручками треба-буде.
Re: Fedora 10
« Відповідей #10 : 2008-11-26 15:31:30 »
Вона буде стабільною коли вийде Федора 11. :-)
Мусульманин
Re: Fedora 10
« Відповідей #11 : 2008-11-26 22:33:42 »
А дядя Федя колись мав на меті бути стабільним? Хіба, менш-більш стабільним, то таки так, можливо, але стабільність це не для цього дистрибутива. Чи Ви мали на увазі щось інше?
Re: Fedora 10
« Відповідей #12 : 2008-11-27 16:55:34 »
Під стабільністю (не плутати з надійністю і захищеністю) розуміють малу частоту змін в коді. Коли припинять розробку F10, тоді там почнуть в основному тільки виправляти помилки і кількість змін впаде. Ця подія наступить ближче до випуску F11.
Якщо мова йде про надійність, то політика Федори направлена на використання найновішого ПЗ а не найнадійнішого (тобто старого). Деколи везе і найновіше ПЗ, включене в дистрибутив, містить небагато помилок внаслідок чого відбувається швидка стабілізація дистрибутиву. Але це не є основною ціллю дистрибутиву. ;-)
Re: Fedora 10
« Відповідей #13 : 2008-11-28 14:59:38 »
а хто б міг мене ткнути в інструкцію апґрейду з 8 до 10, через yum?
на офіційному сайті пропонують записати образ DVD та апгрейднутись через інсталятор, чого я аж ніяк не хотів би робити.
Re: Fedora 10
« Відповідей #14 : 2008-11-28 15:28:18 »
