Автор Гілка: Проблеми із підключенням до бездротової мережі на Debian  (Прочитано 3395 раз)
keithfay
Вітаю Вас, шановні користувачі!
Маю наступну систему:
Linux
Zensor-B (ім’я компа)
3.16.0-4-amd64
#1
SMP
Debian 3.16.7-ckt11-1+deb8u4 (2015-09-19)
x86_64
GNU/Linux
І наступне обладнання:
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 02)
00:01.0 PCI bridge: Intel Corporation Core Processor PCI Express x16 Root Port (rev 02)
00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06)
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05)
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 05)
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 05)
00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 2 (rev 05)
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 05)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a5)
00:1f.0 ISA bridge: Intel Corporation Mobile 5 Series Chipset LPC Interface Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 4 port SATA AHCI Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 05)
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 420M] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GF108 High Definition Audio Controller (rev a1)
02:00.0 Ethernet controller: Broadcom Corporation NetLink BCM57780 Gigabit Ethernet PCIe (rev 01)
03:00.0 Network controller: Broadcom Corporation BCM43225 802.11b/g/n (rev 01)
ff:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers (rev 02)
ff:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 02)
ff:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 02)
ff:02.1 Host bridge: Intel Corporation 1st Generation Core Processor QPI Physical 0 (rev 02)
ff:02.2 Host bridge: Intel Corporation 1st Generation Core Processor Reserved (rev 02)
ff:02.3 Host bridge: Intel Corporation 1st Generation Core Processor Reserved (rev 02)
Маю проблеми із підключенням до бездротових мереж:
Після перезавантаження намагаюсь підключитись до WiFi-роутера DLink DIR-620 і підключення відбувається немов би із таймаутом, тобто я не можу підключитись, потім проходить певний час (3-5 хвилин) і підключення відбувається без проблем.
Вивід dmesg:
[   39.171288] wlan0: direct probe to b8:a3:86:20:35:bc (try 1/3)
[   39.374620] wlan0: direct probe to b8:a3:86:20:35:bc (try 2/3)
[   39.574592] wlan0: direct probe to b8:a3:86:20:35:bc (try 3/3)
[   39.774528] wlan0: direct probe to b8:a3:86:20:35:bc timed out
[   40.531633] wlan0: direct probe to b8:a3:86:20:35:bc (try 1/3)
[   40.730343] wlan0: direct probe to b8:a3:86:20:35:bc (try 2/3)
[   40.930313] wlan0: direct probe to b8:a3:86:20:35:bc (try 3/3)
[   86.530682] wlan0: direct probe to b8:a3:86:20:35:bc (try 1/3)
[   86.726859] wlan0: direct probe to b8:a3:86:20:35:bc (try 2/3)
[   86.926825] wlan0: direct probe to b8:a3:86:20:35:bc (try 3/3)
[   87.126803] wlan0: direct probe to b8:a3:86:20:35:bc timed out
[   95.485034] [drm] nouveau 0000:01:00.0: PFIFO: unknown status 0x40000000
[   96.967960] wlan0: direct probe to b8:a3:86:20:35:bc (try 1/3)
[   97.164314] wlan0: direct probe to b8:a3:86:20:35:bc (try 2/3)
[   97.364236] wlan0: direct probe to b8:a3:86:20:35:bc (try 3/3)
[   97.564210] wlan0: direct probe to b8:a3:86:20:35:bc timed out
[  178.216328] wlan0: direct probe to b8:a3:86:20:35:bc (try 1/3)
[  178.416073] wlan0: direct probe to b8:a3:86:20:35:bc (try 2/3)
[  178.615936] wlan0: direct probe to b8:a3:86:20:35:bc (try 3/3)
[  178.815972] wlan0: direct probe to b8:a3:86:20:35:bc timed out
[  182.971056] [drm] nouveau 0000:01:00.0: PMFB0_SUBP0: 0x037f0010
[  182.971062] [drm] nouveau 0000:01:00.0: PMFB0_SUBP1: 0x037f0000
[  185.206169] wlan0: direct probe to b8:a3:86:20:35:bc (try 1/3)
[  185.402327] wlan0: direct probe to b8:a3:86:20:35:bc (try 2/3)
[  185.602181] wlan0: direct probe to b8:a3:86:20:35:bc (try 3/3)
[  185.802210] wlan0: direct probe to b8:a3:86:20:35:bc timed out
[  272.006939] wlan0: direct probe to b8:a3:86:20:35:bc (try 1/3)
[  272.204723] wlan0: direct probe to b8:a3:86:20:35:bc (try 2/3)
[  272.404657] wlan0: direct probe to b8:a3:86:20:35:bc (try 3/3)
[  272.604616] wlan0: direct probe to b8:a3:86:20:35:bc timed out
[  273.352193] wlan0: direct probe to b8:a3:86:20:35:bc (try 1/3)
[  273.548308] wlan0: direct probe to b8:a3:86:20:35:bc (try 2/3)
[  273.553110] wlan0: direct probe responded
[  273.553213] wlan0: authenticate with b8:a3:86:20:35:bc (try 1)
[  273.560301] wlan0: authenticated
[  273.564328] wlan0: associate with b8:a3:86:20:35:bc (try 1)
[  273.570047] wlan0: RX AssocResp from b8:a3:86:20:35:bc (capab=0xc11 status=0 aid=1)
[  273.570056] wlan0: associated
[  273.570647] ieee80211 phy0: brcms_ops_bss_info_changed: qos enabled: true (implement)
[  273.570662] ieee80211 phy0: brcmsmac: brcms_ops_bss_info_changed: associated
[  273.570669] ieee80211 phy0: changing basic rates failed: -22
[  273.570676] ieee80211 phy0: brcms_ops_bss_info_changed: arp filtering: enabled true, count 0 (implement)
[  273.571465] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  273.573119] cfg80211: Calling CRDA for country: UA
[  273.581153] cfg80211: Regulatory domain changed to country: UA
[  273.581159] cfg80211:     (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[  273.581167] cfg80211:     (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm)
[  273.581173] cfg80211:     (5150000 KHz - 5350000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[  273.581178] cfg80211:     (5490000 KHz - 5670000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[  273.581184] cfg80211:     (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[  273.581189] cfg80211:     (57240000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[  274.218089] ieee80211 phy0: brcms_ops_bss_info_changed: arp filtering: enabled true, count 1 (implement)
Така ж проблема відбувається і з підключенням до 3G мережі через модем Huawei EC 176.
Я плекав великі надії на оновлення Debian до 8-ої версії, однак після оновлення проблема не зникла (я встановлював систему на чистий жорсткий диск).
На Debian 7 була проблема із відключенням WiFi. Коли я відключав WiFi, то я не міг включити цю опцію знов і доводилось перезавантажувати ноут. На Debian 8 ця проблема усунута.
Коли у мене ця проблема виникла вперше, я копав в сторону PowerSave mode, але у мого адаптера цієї властивості нема, тому, думаю, причина в іншому.
Будь ласка, допоможіть вирішити цю проблему.
Відсутній prapor
  • дописів: 518
- The knack?
- Can he lead a normal life?
- No, he'll be an engineer.
keithfay
prapor, так дивився, там сказано, що проблема може бути пов’язана із каналом WiFi мережі, після того я, іще відносно давно, поставив 10 канал. Справа в тому, що проблема виникає як з WiFi, так і з 3g.
