Автор Гілка: Ще раз про співаючих пінгвінів.  (Прочитано 2713 раз)
Відсутній root_x
  • дописів: 225
SLAX#> lspci
00:00.0 Host bridge: Intel Corporation 82845G/GL[Brookdale-G]/GE/PE DRAM Controller/Host-Hub Interface (rev 03)
00:02.0 Display controller: Intel Corporation 82845G/GL[Brookdale-G]/GE Chipset Integrated Graphics Device (rev 03)
00:1d.0 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #3 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801DB/DBM (ICH4/ICH4-M) USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 82)
00:1f.0 ISA bridge: Intel Corporation 82801DB/DBL (ICH4/ICH4-L) LPC Interface Bridge (rev 02)
00:1f.1 IDE interface: Intel Corporation 82801DB (ICH4) IDE Controller (rev 02)
00:1f.5 Multimedia audio controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Audio Controller (rev 02)
03:00.0 VGA compatible controller: ATI Technologies Inc RV280 [Radeon 9200 SE] (rev 01)
03:00.1 Display controller: ATI Technologies Inc RV280 [Radeon 9200 SE] (Secondary) (rev 01)
03:0a.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
Э й dmesg, але то вже буде флуд (?), і не всі осилять кілобайти туксту :), тому скорочую:
Ядро знаходить звукову карту:
slackware#>dmesg
Kernel command line: BOOT_IMAGE=music ro root=307
Intel 810 + AC97 Audio, version 1.01, 23:32:04 Jan 20 2007
i810: Intel ICH4 found at IO 0xdc00 and 0xe000, MEM 0xdff7fa00 and 0xdff7f900, IRQ 5
i810: Intel ICH4 mmio at 0xc8858a00 and 0xc885a900
i810_audio: Primary codec has ID 0
i810_audio: Audio Controller supports 6 channels.
i810_audio: Defaulting to base 2 channel mode.
i810_audio: Resetting connection 0
i810_audio: Connection 0 with codec id 0
ac97_codec: AC97  codec, id: CMI131 (Unknown)
i810_audio: only 48Khz playback available.
i810_audio: AC'97 codec 0 supports AMAP, total channels = 6
При переуомпіляції я включив підтримку для Intel 8xx карт. А також в розділі "Character devices" скрізь де є напис "Intel" (всього аж два) поставиви відмітку.
alsaconf пише
slackware#> alsaconf 2> err.txt; cat err.txt
modinfo: snd: no module by that name found
modinfo: snd:      ***
modinfo: snd:      ***
modinfo: snd-opl3sa2:      ***
modinfo: snd-cs4236:      ***
modinfo: snd-cs4232:      ***
modinfo: snd-cs4231:      ***
modinfo: snd-es18xx:      ***
modinfo: snd-es1688:      ***
modinfo: snd-sb16:      ***
modinfo: snd-sb8: no module by that name found
Я думаю мабуть, неспівпадає те, що в мене є - "Multimedia audio controller: Intel Corporation 82801DB" і те, що є в параметрах конфігурації ядра - "Intel ICH 82801AA, Intel ICH 82901AB". ???
Або якісь параметри треба вказати при запуску alsaconf.
Та мабуть треба модулі шукати. Що робити? Звідки їх викачувати? і чи можна взяти їх з іншого дистрибутива?
І для чого призначена alsamixer? (хм-м-м; можна ж man почитати).
І що робити в Slax 5.1.7 RU (2.6.16) - (завантаж. тільки з парам. nohotplug), якщо встановити його на hda, то як правильно налаштувати звук. Так само як і в Slackware, от тільки як?
Завантажуючись з livecd alsaconf 1.0.11 розпізнає карту, але alsamixer не працює (мабуть тому що в /dev/ немає dsp та інших пристроїв ?-( незнаячого. ./MAKEDEV чогось також нема. При установці Slax'у  на ЖД MAKEDEV зявится в /dev?
І що робити коли Knoppix 5.1.1 "завантажується" тільки з параметрами noudev nohotplug. Індикатор завантаження доходить до Done 100%, і пише кернел-панік, та такий "панік", що неможливо прочитати в чому причина (сумніваюсь, що воно мені допоможе) - рядки швидко-швико біжать по екрану.
В режимі debug - все те саме, на останній стадії також доходить до 100% Done і все, але нічого не пише., просто висне.
А якщо вантажиись по замовчуванні (Knoppix 5.1.1), то пише Starting udev hotplug hardware detection…
/sbin/modprobe abnormal exit
/bin/sh abnormal exit
/lib/udev/path_id abnormal exit
Якщо ж все-таки пощастить: яку команду потрібно ввести для встановлення Кнопки на ЖД? "knoppix-installer?"
А для Slax?
Ubuntu CE 2.0 взагалі незаю що від мене хоче. Чи я від нього. Просто висить красиво… я ще не розбирався з ним, і сумніваюсь що щось вийде :(
!!!Але LG3D 2.3 Livecd - завантажується і працює!!!, але поки відкриє firefox'а, то чайник* закипає. Курсор взагалі такий важкучий :), у мене ж 128 RAM (тобто не у мене а у компутера, у мене набагато більш, навіть таких одиниць вимірювання не існує)
Gentoo 2006.1 подобаєтьс тим що з Livecd відео, музика без проблем, і швидке як скажене жабеня. Ще не ставив на ЖД, маю "важливі" дані.
чайник - той в якому воду кип'ятять.
Відсутній root_x
  • дописів: 225
Re: Ще раз про співаючих пінгвінів.
« Відповідей #1 : 2007-01-22 16:33:27 »
Думая, що питання зрозуміле, чи ні?
Відсутній cadca
  • дописів: 955
  • free like beer
« Відповідей #2 : 2007-01-22 23:19:05 »
Схоже, Вам попався диск(CD-матриця) поганої якості (в розумінні - технологічно погані, а не програмно  ::)) або старенький CDROM
« Відповідей #3 : 2007-01-23 14:23:17 »
Ніби ясно пише що використовуються ці два модулі: i810_audio та ac97_codec. i810_audio та ac97_codec - це драйвери не від ALSA а драйвери для OSS.
Від Альзи має підійти драйвер snd-intel8x0.
Можливо його треба завантажувати примусово. Зробіть "modinfo snd-intel8x0" щоб побачити список PCI id-ок. Зробіть lspci -n щоб побачити id-ку вашої картки.
Напр. у мене:
#lspci | fgrep audio
00:1f.5 Multimedia audio controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) AC'97 Audio Controller (rev 02)
# lspci -n | fgrep 1f.5
00:1f.5 0401: 8086:24d5 (rev 02)
# modinfo snd_intel8x0 | egrep '8086.*24D5'
alias:          pci:v00008086d000024D5sv*sd*bc*sc*i*
Тобто моя картка автоматично розпізнається і для неї завантажується модуль.
Відсутній root_x
  • дописів: 225
« Відповідей #4 : 2007-01-28 14:11:42 »
Ні, просто необхідно почистити CD, бо навіть під Віндою не читає абсолютно нові диски.
Або (скоріше І) переставити драйвера для Вінди, бо почалося все після виликого та страшного віндовського глюку, чи може раніше. Але вони аж ніяк не впливабть на Knoppix (і на обєм памяті та швидкість процесору :'()  ;D
« Змінено: 2007-01-28 14:17:02 від root_x »
Відсутній root_x
  • дописів: 225
« Відповідей #5 : 2007-01-28 14:22:28 »
Пасибі, що не залишили мене у біді  :), і змогли дочитати до кінця "кілобайтит туксту"
« Відповідей #6 : 2007-01-28 23:02:05 »
SuSE 10.2 і вбудований звук C-Media на nForce2. Пінгвіни вперто мовчать.
> dmesg |grep audio
У відповідь -- "тиша".
У мене виходить таке:
> lspci | fgrep audio
00:06.0 Multimedia audio controller: nVidia Corporation nForce2 AC97 Audio Controler (MCP) (rev a1)
> lspci -n | fgrep 06.0
00:06.0 Class 0401: 10de:006a (rev a1)
І що тепер із цим робити? modinfo snd_intel8x0 видає довгий список.
« Відповідей #7 : 2007-01-29 15:58:52 »
s/навіть під Віндою/в першу чергу під Віндою/
Відсутній PAL
  • дописів: 317
  • Just linux admin
« Відповідей #8 : 2007-01-29 18:33:28 »
> lspci | fgrep audio
Вибачте, але яким тут боком intel до NVidia?  :o
Вам потрібні відповідні драйвера (можете, наприклад, спробувати з сайту nvidia, там були)
« Відповідей #9 : 2007-01-29 19:11:28 »
Перепрошую, Ви часом не захворіли? Чи просто забули, що усі звукові картки від nvidia працюють з драйвером від intel?
« Змінено: 2007-01-29 19:11:58 від Praporshic »
