Автор Гілка: проблеми при інсталяції КДЕ4 рк2  (Прочитано 952 раз)
Відсутній ussr1k
  • дописів: 100
  • [team Linux] KPI
ось рішився встановити КДЕ 4... погуглив - знайшов для своєї кубунти ось такий сайт де написано як встановитицю граф. оболонку http://kubuntu.org/announcements/kde4-rc2.php ...
перші кілька кроків нормально... а далі - борода - і я незнаю як з цим боротися
# apt-get install kdebase-workspace kdebase-kde4 kdebase-runtime
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
  kdebase-kde4: Depends: dolphin-kde4 (>= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
                Depends: kappfinder-kde4 (>= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
                Depends: kdebase-bin-kde4 (>= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
                Depends: kdepasswd-kde4 (>= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
                Depends: kfind-kde4 (>= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
                Depends: konqueror-nsplugins-kde4 (>= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
                Depends: konqueror-kde4 (>= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
                Depends: konsole-kde4 (>= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
                Depends: kwrite-kde4 (>= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
                Depends: libkonq5 (>= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
  kdebase-runtime: Depends: kdelibs5 (>= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
                   Depends: libsoprano4 but it is not going to be installed
                   Depends: kdebase-runtime-bin-kde4 (= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
  kdebase-workspace: Depends: kdebase-workspace-bin (>= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
                     Depends: klipper-kde4 (>= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
                     Depends: ksysguard-kde4 (>= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
                     Depends: kwin-kde4 (>= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
                     Depends: systemsettings-kde4 (>= 4:4.0.0-0ubuntu1~gutsy1~ppa1) but it is not going to be installed
E: Broken packages
root@ubuntu:/home/heartbeat# apt-get install dolphin-kde4
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
  dolphin-kde4: Depends: kdebase-runtime but it is not going to be installed
                Depends: libkonq5 but it is not going to be installed
E: Broken packages
« Змінено: 2008-01-11 11:22:30 від ussr1k »
Re: проблеми при інсталяції КДЕ4 рк2
« Відповідей #1 : 2008-01-11 11:33:39 »
Мабуть так:
apt-get install kdelibs5 libkonq5 libsoprano4 kdebase-workspace kdebase-kde4 kdebase-runtimeА ще краще почекати пару днів: сьогодні виходить KDE4!
