Автор Гілка: Не виходить cконфігурувати пакунок  (Прочитано 1637 раз)
Відсутній Styler
  • дописів: 31
Не виходить сконфігурувати пакунок:
./configure
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for sed... /bin/sed
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognize dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl.exe... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking whether we are using the GNU C++ compiler... no
checking whether g++ accepts -g... no
checking dependency style of g++... none
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
checking the maximum length of command line arguments... 98304
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
appending configuration tag "CXX" to libtool
appending configuration tag "F77" to libtool
checking for xgettext... /usr/bin/xgettext
checking for msgmerge... /usr/bin/msgmerge
checking for msgfmt... /usr/bin/msgfmt
checking for perl... /usr/bin/perl
checking for XML::Parser... ok
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking for LC_MESSAGES... yes
checking libintl.h usability... yes
checking libintl.h presence... yes
checking for libintl.h... yes
checking for ngettext in libc... yes
checking for dgettext in libc... yes
checking for bind_textdomain_codeset... yes
checking for msgfmt... (cached) /usr/bin/msgfmt
checking for dcgettext... yes
checking if msgfmt accepts -c... yes
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... (cached) /usr/bin/xgettext
checking for catalogs to be installed...  af am ar az be@latin bg bn bs ca ca@valencia cs da de dz el en_AU en_CA en_GB eo es et eu fa fi fr gl gu he hi hu id it ja ka kn ko ku lo lt mk my_MM nb ne nl nn oc pa pl pt_BR pt ps ro ru si sk sl sq sr sr@latin sv ta te th tr uk ur vi xh zh_CN zh_HK zh_TW
checking for ANSI C header files... (cached) yes
checking for sys/wait.h that is POSIX.1 compatible... yes
checking arpa/nameser_compat.h usability... yes
checking arpa/nameser_compat.h presence... yes
checking for arpa/nameser_compat.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking for unistd.h... (cached) yes
checking for locale.h... (cached) yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for stdint.h... (cached) yes
checking regex.h usability... yes
checking regex.h presence... yes
checking for regex.h... yes
checking for an ANSI C-conforming const... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking for time_t... yes
checking size of time_t... 4
checking whether byte ordering is bigendian... no
checking return type of signal handlers... void
checking for strftime... yes
checking for strdup... yes
checking for strstr... yes
checking for atexit... yes
checking for setlocale... yes
checking for getopt_long... yes
checking for inet_aton... yes
checking for __res_query in -lresolv... yes
checking for gethostent in -lnsl... yes
checking for socket... yes
checking for getaddrinfo... yes
checking for socklen_t... yes
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... 64
checking for dlopen... no
checking for dlopen in -ldl... yes
checking for fileno()... yes
checking for the %z format string in strftime()... yes
checking for GLIB... yes
checking for X... libraries , headers
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking for GTK... yes
checking for PANGO... yes
checking for X11... yes
checking for XScreenSaverRegister in -lXext... no
checking for XScreenSaverRegister in -lXss... yes
checking for SmcSaveYourselfDone in -lSM... yes
checking X11/SM/SMlib.h usability... yes
checking X11/SM/SMlib.h presence... yes
checking for X11/SM/SMlib.h... yes
checking for STARTUP_NOTIFICATION... no
no
configure: error:
Startup notification development headers not found.
Use --disable-startup-notification if you do not need it.
« Змінено: 2008-07-02 13:10:23 від Styler »
Відсутній rangel
  • дописів: 281
  • Python programmer
Re: Не виходить cконфігурувати пакунок
« Відповідей #1 : 2008-07-02 12:30:40 »
./configure --disable-startup-notificationПробували?
« Змінено: 2008-07-02 12:31:07 від rangel »
Roman Suprotkin
Відсутній raven
  • дописів: 0
  • linux kettle
« Відповідей #2 : 2008-07-02 12:53:18 »
./configure --disable-startup-notificationПробували?[/quote]Або встановити пакунок startup-notification. І заодно осилити тег [code] форуму.
Відсутній Styler
  • дописів: 31
« Відповідей #3 : 2008-07-02 13:09:25 »
Пробував, але далі вивалюється знову купа не знайдених хедерів... Пакунок startup-notification інсталював, але далі вивалюються ініш помилки --disable-gstreamer  gtkspell та інші...
« Змінено: 2008-07-02 13:17:47 від Styler »
Михайло Даниленко
« Відповідей #4 : 2008-07-02 13:42:18 »
Скоріше потрібен пакунок startup-notification-dev/devel, хоча це й дистрозалежне...
Ну то відповідно - gstreamer-dev, gtkspell-dev, чи як їх там.
Відсутній Styler
  • дописів: 31
« Відповідей #5 : 2008-07-02 13:47:02 »
Усе, дякую, інсталював...
Відсутній rangel
  • дописів: 281
  • Python programmer
« Відповідей #6 : 2008-07-02 15:22:12 »
Чисто інтересу ради...
А що ж це ставилося з такими потугами? І на яку систему?
Roman Suprotkin
