Автор Гілка: ArchLinux, desktop managers  (Прочитано 4588 раз)
  • дописів: 513
  • Карма: +3/-1
« : 2011-07-04 07:29:55 »
Після вводу пароля і назви користуача (викор. root) в  якомусь DM (пробував lxdm,slim) нічого не відбувається. Пробував вибирати сеанс icewm,xfce.
  • дописів: 513
  • Карма: +3/-1
Re: ArchLinux, desktop managers
« Відповідей #1 : 2011-07-05 09:06:27 »
X.Org X Server 1.10.2
Release Date: 2011-05-28
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.38-ARCH x86_64
Current Operating System: Linux myhost 2.6.27-lts #1 SMP Mon Apr 5 18:12:08 UTC 2010 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz26-lts root=/dev/sda7
Build Date: 30 May 2011  08:18:15AM
Current version of pixman: 0.22.0
      Before reporting problems, check http://wiki.x.org
      to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
      (++) from command line, (!!) notice, (II) informational,
      (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Jul  4 19:59:47 2011
(==) Using config directory: "/etc/X11/xorg.conf.d"
(EE) Failed to load module "nouveau" (module does not exist, 0)
(EE) Failed to load module "nvidia" (module does not exist, 0)
(EE) Failed to load module "vesa" (module does not exist, 0)
(EE) Failed to load module "fbdev" (module does not exist, 0)
mkdir: cannot create directory `/root/.config': Permission denied
mkdir: cannot create directory `/root/.cache': Permission denied
/etc/xdg/xfce4/xinitrc: line 114: xrdb: command not found
/etc/xdg/xfce4/xinitrc: line 171: ssh-agent: command not found
(xfce4-session:2682): libxfce4util-WARNING **: Invalid XDG_CACHE_HOME directory `/root/.cache', program may behave incorrectly.
(xfce4-session:2682): libxfce4util-WARNING **: Invalid XDG_DATA_HOME directory `/root/.local/share', program may behave incorrectly.
(xfce4-session:2682): libxfce4util-WARNING **: Invalid XDG_CONFIG_HOME directory `/root/.config', program may behave incorrectly.
/etc/xdg/xfce4/xinitrc: line 217: ssh-agent: command not found
xinit: connection to X server lost
waiting for X server to shut down error setting MTRR (base = 0xd0000000, size = 0x10000000, type = 1) Invalid argument (22)
Зараз шукю де значенння всіх  ціх XDG  встановлюютьсяї
  • дописів: 513
  • Карма: +3/-1
« Відповідей #2 : 2011-07-05 09:22:52 »
[dima@myhost home]$ set | grep XDG
XDG_CACHE_HOME=/root/.cache
XDG_CONFIG_DIRS=/etc/xdg:/etc/xdg
XDG_CONFIG_HOME=/root/.config
XDG_DATA_DIRS=/usr/share/:/usr/local/share/:/usr/share
XDG_DATA_HOME=/root/.local/share
XDG_MENU_PREFIX=xfce-
[dima@myhost home]$
Але чому?
« Змінено: 2011-07-05 09:23:12 від xuser13 »
Відсутній modeus
  • дописів: 278
  • openSUSE 11.4
« Відповідей #3 : 2011-07-05 09:22:53 »
Схоже на проблеми з відео драйверами. В ArchLinux не можна зайти в безпечному режимі?
  • дописів: 513
  • Карма: +3/-1
« Відповідей #4 : 2011-07-05 09:23:46 »
Що за безпечній режім7
Відсутній modeus
  • дописів: 278
  • openSUSE 11.4
« Відповідей #5 : 2011-07-05 10:18:55 »
Ну значить немає. В бунті, сусі при завантаженні системи є на вибір «безпечний режим» - там не працюють встановлені драйвера на відео, але можна зайти в GUI та встановити. Зручно. Оцінив це коли після оновлення ядра в сусі - перестав запускатися гном в нормальному режимі.
А так доведеться в консольному режимі заходити.
« Змінено: 2011-07-05 10:19:53 від modeus »
  • дописів: 513
  • Карма: +3/-1
« Відповідей #6 : 2011-07-05 10:32:35 »
Потрібно предати ядру  параметр single (здається).
Додавання
export XDG_CACHE_HOME=/home/dima/.cache
export XDG_CONFIG_HOME=/home/dima/.config
export XDG_DATA_HOME=/home/dima/.local/share
в .xprofile не допомогло. Може є якісь ідеї7
  • дописів: 513
  • Карма: +3/-1
« Відповідей #7 : 2011-07-05 11:02:48 »
Знайшов тимчасове вирішення цієї проблеми, якщо
#su - dima
$startxfce4
, то все прцює. Тільки не зрозуміло чому.
  • дописів: 513
  • Карма: +3/-1
