Автор Гілка: wine directx nvidia debian  (Прочитано 4177 раз)
Відсутній peinguin
  • дописів: 1422
« : 2012-11-09 22:27:06 »
Хочу запустити WoT. В когось є доствід? видає
p11-kit: couldn't load module: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: cannot open shared object file: No such file or directory
fixme:heap:HeapSetInformation 0x110000 0 0x31dcb8 4
fixme:advapi:RegisterTraceGuidsW (0x1e9d52d, 0x1fa6320, {0cfe0455-93ba-440d-a3fe-553973d0b723}, 1, 0x31dc10, (null), (null), 0x1fa6328,): stub
fixme:advapi:RegisterTraceGuidsW (0x1e9d52d, 0x1fa6340, {797fabac-7b58-4796-b924-d51178a59ce4}, 1, 0x31dc10, (null), (null), 0x1fa6348,): stub
fixme:wininet:CommitUrlCacheEntryInternal entry already in cache - don't know what to do!
fixme:wininet:InternetSetOptionW Option INTERNET_OPTION_RESET_URLCACHE_SESSION: STUB
fixme:t2embed:TTLoadEmbeddedFont (0x1e10e4 0x00000001 0x3294bc 0x00000000 0x3294c0 0x1f1e7df 0x148 L"d8348532a3955747001be7d8#230000" d8348532a3955747001be7d8#230000 0x3294c4) stub
fixme:msimtf:DllGetClassObject ({50d5107a-d278-4871-8989-f4ceaaf59cfc} {00000001-0000-0000-c000-000000000046} 0x32cc1c)
err:ole:apartment_getclassobject DllGetClassObject returned error 0x80040111
err:ole:CoGetClassObject no class object {50d5107a-d278-4871-8989-f4ceaaf59cfc} could be created for context 0x401
err:ole:CoGetClassObject class {6c736db1-bd94-11d0-8a23-00aa00b58e10} not registered
err:ole:CoGetClassObject no class object {6c736db1-bd94-11d0-8a23-00aa00b58e10} could be created for context 0x1
fixme:advapi:RegisterTraceGuidsW (0xb439f97, 0xb574b08, {3e1fd72a-c323-4574-9917-5ce9c936f78c}, 1, 0x32a524, (null), (null), 0xb574b10,): stub
fixme:advapi:RegisterTraceGuidsW (0xb439f97, 0xb574b28, {afff9c82-5be3-4205-9b3e-49e014c09a63}, 1, 0x32a524, (null), (null), 0xb574b30,): stub
fixme:wininet:InternetSetOptionW Option INTERNET_OPTION_CONNECT_TIMEOUT (300000): STUB
fixme:wininet:InternetSetOptionW INTERNET_OPTION_SEND/RECEIVE_TIMEOUT/DATA_SEND_TIMEOUT 300000
fixme:wininet:InternetSetOptionW INTERNET_OPTION_SEND/RECEIVE_TIMEOUT/DATA_SEND_TIMEOUT 3600000
fixme:wininet:IsHostInProxyBypassList STUB: flags=3 host=update.worldoftanks.ru length=22
fixme:wininet:InternetSetOptionW INTERNET_OPTION_IDN; STUB
fixme:wininet:InternetSetOptionW INTERNET_OPTION_SEND_UTF8_SERVERNAME_TO_PROXY; STUB
fixme:wininet:InternetSetOptionW Option INTERNET_OPTION_CODEPAGE (65001): STUB
fixme:wininet:InternetSetOptionW INTERNET_OPTION_CODEPAGE_PATH; STUB
fixme:wininet:InternetSetOptionW INTERNET_OPTION_CODEPAGE_EXTRA; STUB
fixme:wininet:InternetSetOptionW INTERNET_OPTION_COOKIES_3RD_PARTY; STUB
fixme:wininet:InternetSetOptionW Option INTERNET_OPTION_REQUEST_PRIORITY (-1): STUB
fixme:wininet:IsHostInProxyBypassList STUB: flags=3 host=static.worldoftanks.ru length=22
fixme:wininet:GetUrlCacheEntryInfoExW Undocumented flag(s): 100
fixme:wininet:IsHostInProxyBypassList STUB: flags=3 host=worldoftanks.ru length=16
fixme:heap:HeapSetInformation 0x110000 0 0x32ab70 4
fixme:atl:AtlModuleInit SEMI-STUB (0x35c7a2a8 0x35c7a310 0x35c50000)
err:winediag:X11DRV_WineGL_InitOpenglInfo Direct rendering is disabled, most likely your OpenGL drivers haven't been installed correctly (using GL renderer "GeForce GTX 660/PCIe/SSE2", version "1.4 (2.1.2 NVIDIA 304.48)").
err:d3d_caps:WineD3D_CreateFakeGLContext Can't find a suitable iPixelFormat.
err:d3d:InitAdapters Failed to get a gl context for default adapter
err:ddraw:ddraw_create_swapchain Failed to create swapchain, hr 0x8876086c.
err:ddraw:ddraw7_SetCooperativeLevel Failed to create swapchain, hr 0x8876086c.
fixme:heap:HeapSetInformation 0x110000 0 0x32aa24 4
fixme:atl:AtlModuleInit SEMI-STUB (0x35cedb08 0x2feede8 0x35cb0000)
fixme:ddrawex:IDirectDraw4Impl_CreateSurface Implement aggregation for ddrawex surfaces
fixme:ddraw:CreateSurface (0x2f74a90) : outer != NULL?
fixme:d3d:resource_check_usage Unhandled usage flags 0x20000000.
fixme:wininet:InternetSetOptionW Option INTERNET_OPTION_END_BROWSER_SESSION: STUB
peinguin@debian:/mnt/win/games/World_of_Tanks$ fixme:win:EnumDisplayDevicesW ((null),0,0x114c0f8,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),1,0x114c0f8,0x00000000), stub!
Direct3D9 is not available without OpenGL.
uname -a
Linux debian 3.2.0-4-amd64 #1 SMP Debian 3.2.32-1 x86_64 GNU/Linux
« Змінено: 2012-11-09 22:27:57 від peinguin »
Відсутній prapor
  • дописів: 518
Re: wine directx nvidia debian
« Відповідей #1 : 2012-11-11 01:37:21 »
glx-alternative-nvidia
libgl1-nvidia-alternatives
libgl1-nvidia-alternatives-ia32
libgl1-nvidia-glx:amd64
libgl1-nvidia-glx:i386
libglx-nvidia-alternatives
libnvidia-compiler:amd64
libnvidia-compiler:i386
libnvidia-ml1:amd64
nvidia-alternative
nvidia-cg-dev:amd64
nvidia-cg-toolkit
nvidia-cuda-dev
nvidia-cuda-doc
nvidia-cuda-gdb
nvidia-cuda-toolkit
nvidia-detect
nvidia-glx
nvidia-installer-cleanup
nvidia-kernel-common
nvidia-kernel-dkms
nvidia-libopencl1:amd64
nvidia-libopencl1:i386
nvidia-opencl-common
nvidia-opencl-dev
nvidia-opencl-icd:amd64
nvidia-opencl-icd:i386
nvidia-settings
nvidia-smi
nvidia-support
nvidia-vdpau-driver:amd64
nvidia-vdpau-driver:i386
nvidia-visual-profiler
nvidia-xconfig
xserver-xorg-video-nvidia
Десь отакий перелік пакунків має бути на 64-біти.
А взагалі, ви впевнені що версія wine підтримує іграшку? Свого часу там був WoTFLIX, який вже ніхто не користує і не оновлює, але з ним працювало. Зараз у Debian максимум 1.5.5, а для нормальної роботи треба 1.5.13.
- The knack?
- Can he lead a normal life?
- No, he'll be an engineer.
Відсутній peinguin
  • дописів: 1422
« Відповідей #2 : 2012-11-12 09:07:37 »
Дякую. Не скажу точно, чи ставив всі ці пакунки, але потім все зніс і поставив пропрієтарний драйвер.
Гра запустилась, але в білому віконці, в якому нічого не видно. Кажуть в wine 1.5.8 такого немає. Але під дебіен максимально можна 1.5.5 зібрати. А досвід ручного збирання навчив, що краще не треба.
Відсутній prapor
  • дописів: 518
« Відповідей #3 : 2012-11-12 16:59:03 »
Подивіться на їх форумі. Там була вже зібрана версія зі скриптами для запуску.
- The knack?
