Автор Гілка: USB-пристрої постійно перепідключаються  (Прочитано 1725 раз)
VeryCold
Всім привіт  :)
Виникла проблема з USB-пристроями. При підключенні планшета чи флешки по ПК пристрій постійно перепідключається і виводить в лог наступне:
Dec 12 13:47:07 DIGITALL kernel: usb 1-2: new high-speed USB device number 98 using ehci-pci
Dec 12 13:47:07 DIGITALL kernel: usb 1-2: New USB device found, idVendor=0930, idProduct=7100
Dec 12 13:47:07 DIGITALL kernel: usb 1-2: New USB device strings: Mfr=2, Product=3, SerialNumber=4
Dec 12 13:47:07 DIGITALL kernel: usb 1-2: Product: AT100
Dec 12 13:47:07 DIGITALL kernel: usb 1-2: Manufacturer: TOSHIBA
Dec 12 13:47:07 DIGITALL kernel: usb 1-2: SerialNumber: 0123456789ABCDEF
Dec 12 13:47:09 DIGITALL kernel: usb 1-2: USB disconnect, device number 98
Dec 12 13:47:09 DIGITALL kernel: usb 1-2: new high-speed USB device number 99 using ehci-pci
Dec 12 13:47:09 DIGITALL kernel: usb 1-2: New USB device found, idVendor=0930, idProduct=7100
Dec 12 13:47:09 DIGITALL kernel: usb 1-2: New USB device strings: Mfr=2, Product=3, SerialNumber=4
Dec 12 13:47:09 DIGITALL kernel: usb 1-2: Product: AT100
Dec 12 13:47:09 DIGITALL kernel: usb 1-2: Manufacturer: TOSHIBA
Dec 12 13:47:09 DIGITALL kernel: usb 1-2: SerialNumber: 0123456789ABCDEF
Dec 12 13:47:18 DIGITALL kernel: usb 1-2: USB disconnect, device number 99
Dec 12 13:47:18 DIGITALL kernel: usb 1-2: new high-speed USB device number 100 using ehci-pci
Dec 12 13:47:18 DIGITALL kernel: usb 1-2: New USB device found, idVendor=0930, idProduct=7100
Dec 12 13:47:18 DIGITALL kernel: usb 1-2: New USB device strings: Mfr=2, Product=3, SerialNumber=4
Dec 12 13:47:18 DIGITALL kernel: usb 1-2: Product: AT100
Dec 12 13:47:18 DIGITALL kernel: usb 1-2: Manufacturer: TOSHIBA
Dec 12 13:47:18 DIGITALL kernel: usb 1-2: SerialNumber: 0123456789ABCDEF
Dec 12 13:47:20 DIGITALL kernel: usb 1-2: USB disconnect, device number 100
Dec 12 13:47:20 DIGITALL kernel: usb 1-2: new high-speed USB device number 101 using ehci-pci
Dec 12 13:47:20 DIGITALL kernel: usb 1-2: New USB device found, idVendor=0930, idProduct=7100
Dec 12 13:47:20 DIGITALL kernel: usb 1-2: New USB device strings: Mfr=2, Product=3, SerialNumber=4
Dec 12 13:47:20 DIGITALL kernel: usb 1-2: Product: AT100
Dec 12 13:47:20 DIGITALL kernel: usb 1-2: Manufacturer: TOSHIBA
Dec 12 13:47:20 DIGITALL kernel: usb 1-2: SerialNumber: 0123456789ABCDEF
Dec 12 13:47:21 DIGITALL kernel: usb 1-2: USB disconnect, device number 101
Dec 12 13:47:21 DIGITALL kernel: usb 1-2: new high-speed USB device number 102 using ehci-pci
Dec 12 13:47:21 DIGITALL kernel: usb 1-2: New USB device found, idVendor=0930, idProduct=7100
Dec 12 13:47:21 DIGITALL kernel: usb 1-2: New USB device strings: Mfr=2, Product=3, SerialNumber=4
Dec 12 13:47:21 DIGITALL kernel: usb 1-2: Product: AT100
Dec 12 13:47:21 DIGITALL kernel: usb 1-2: Manufacturer: TOSHIBA
Dec 12 13:47:21 DIGITALL kernel: usb 1-2: SerialNumber: 0123456789ABCDEF
Dec 12 13:47:22 DIGITALL kernel: usb 1-2: USB disconnect, device number 102
При підключенні USB-миші в той же порт такої проблеми немає.
Що це може бути, і як з цим боротись? Якщо подібна проблема десь обговорювалась - тикніть носом  :)
Відсутній cadca
  • дописів: 955
  • free like beer
Миша працює в режимі "full speed usb", інші пристрої пробують режим "high speed usb". Судячи з логу, режим "high speed usb" у вас чомусь не працює (поганий контакт в роз’ємі, режим вимкнено в BIOS тощо). Спробуйте заставити працювати пристрої в режимі "full speed usb" програмно вимкнувши (від root`а) модуль ядра
modprobe -r ehci_hcd ehci_pciта під’єднати потрібний пристрій знову.
« Змінено: 2013-12-15 00:00:24 від cadca »
