Автор Гілка: SANE. Робота зо сканером  (Прочитано 2918 раз)
Відсутній Smoke
  • дописів: 7
[smoke@localhost smoke]$ xsane
(xsane:21971): Gtk-WARNING **: Не вдається віднайти механізм роботи з темами у module_path: "galaxy",
[gt68xx] Couldn't open firmware file (neither `/usr/share/sane/gt68xx/A2Dfw.usb' nor `/usr/share/sane/gt68xx/a2dfw.usb'): No such file or directory
На екран видає:
Failed to open device "gt68xx:libus:002:004": Invalid argument.
Сканер, наче, бачить.. але працювати із ним відмовляється.(?!)
Mustek BearPaw 2400TA Plus flatted scanner.
Mandrake 10.0
[root@localhost proc]# lsusb
Bus 004 Device 001: ID 0000:0000
Bus 003 Device 001: ID 0000:0000
Bus 002 Device 007: ID 055f:0219 Mustek Systems, Inc. BearPaw 2400 TA Plus
Bus 002 Device 005: ID 04a9:106a Canon, Inc.
Bus 002 Device 001: ID 0000:0000
Bus 001 Device 001: ID 0000:0000
[smoke@localhost smoke]$ sane-find-scanner
  # No SCSI scanners found. If you expected something different, make sure that
  # you have loaded a SCSI driver for your SCSI adapter.
found USB scanner (vendor=0x055f, product=0x0219 [USB Scanner], chip=GT-6816) at libusb:002:007
  # Your USB scanner was (probably) detected. It may or may not be supported by
  # SANE. Try scanimage -L and read the backend's manpage.
  # Scanners connected to the parallel port or other proprietary ports can't be
  # detected by this program.
  # You may want to run this program as root to find all devices. Once you
  # found the scanner devices, be sure to adjust access permissions as
  # necessary.
[smoke@localhost smoke]$ scanimage -L
device `gt68xx:libusb:002:007' is a Mustek BearPaw 2400 TA Plus flatbed scanner
[smoke@localhost smoke]$ scanimage -d test -T
scanimage: scanning image of size 157x196 pixels at 8 bits/pixel
scanimage: acquiring gray frame, 8 bits/sample
scanimage: reading one scanline, 157 bytes...   PASS
scanimage: reading one byte...          PASS
scanimage: stepped read, 2 bytes...     PASS
scanimage: stepped read, 4 bytes...     PASS
scanimage: stepped read, 8 bytes...     PASS
scanimage: stepped read, 16 bytes...    PASS
scanimage: stepped read, 32 bytes...    PASS
scanimage: stepped read, 64 bytes...    PASS
scanimage: stepped read, 128 bytes...   PASS
scanimage: stepped read, 256 bytes...   PASS
scanimage: stepped read, 255 bytes...   PASS
scanimage: stepped read, 127 bytes...   PASS
scanimage: stepped read, 63 bytes...    PASS
scanimage: stepped read, 31 bytes...    PASS
scanimage: stepped read, 15 bytes...    PASS
scanimage: stepped read, 7 bytes...     PASS
scanimage: stepped read, 3 bytes...     PASS
Відсутній Loof
  • дописів: 77
Re: SANE. Робота зо сканером
« Відповідей #1 : 2006-02-15 21:25:20 »
Зовсім не читаємо, що пише sane?
поставте драйвери sane-backends
або стягніть для свого сканера звідси
http://www.meier-geinitz.de/sane/gt68xx-backend/
« Змінено: 2006-02-15 21:25:51 від Loof »
