Автор Гілка: E: Failed to mount the cdrom.  (Прочитано 12922 раз)
Відсутній RyB
  • дописів: 27
  • Str8 Coding
« : 2007-05-28 11:23:34 »
Користуюся Убунту 7.04 (з ДВД), але після встановлення самого дистрибютиву, я не не можу встановити жодного додаткового пакету:
Media change: please insert the disc labeled
 'Ubuntu 7.04 _Feisty Fawn_ - Release i386 (20070418)'
in the drive '/cdrom/' and press enter
Звичайно, що диск залишився той самий з моменту установки, але проблема виникає досі.
Я спробував додати диск власноручно до sources.list, але виникла проблема..
:~$ apt-cdrom add
Using CD-ROM mount point /cdrom/
Unmounting CD-ROM
Waiting for disc...
Please insert a Disc in the drive and press enter
Mounting CD-ROM...
На разі мій sources.list виглядає так:
deb cdrom:[Ubuntu 7.04 _Feisty Fawn_ - Release i386 (20070418)]/ feisty main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://archive.ubuntu.com/ubuntu/ feisty main restricted
deb-src http://archive.ubuntu.com/ubuntu/ feisty main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://archive.ubuntu.com/ubuntu/ feisty-updates main restricted
deb-src http://archive.ubuntu.com/ubuntu/ feisty-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
deb http://archive.ubuntu.com/ubuntu/ feisty universe
deb-src http://archive.ubuntu.com/ubuntu/ feisty universe
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://archive.ubuntu.com/ubuntu/ feisty multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty multiverse
## Uncomment the following two lines to add software from the 'backports'
## repository.
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb http://us.archive.ubuntu.com/ubuntu/ feisty-backports main restricted universe multiverse
# deb-src http://us.archive.ubuntu.com/ubuntu/ feisty-backports main restricted universe multiverse
deb http://archive.ubuntu.com/ubuntu/ feisty-security main restricted
deb-src http://archive.ubuntu.com/ubuntu/ feisty-security main restricted
deb http://archive.ubuntu.com/ubuntu/ feisty-security universe
deb-src http://archive.ubuntu.com/ubuntu/ feisty-security universe
deb http://archive.ubuntu.com/ubuntu/ feisty-security multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty-security multiverse
deb cdrom:[Ubuntu 7.04 i386]/ feisty main restricted
Допоможіть, будь ласка!!
« Змінено: 2007-05-28 12:12:59 від RyB »
Відсутній rangel
  • дописів: 281
  • Python programmer
Re: E: Failed to mount the cdrom.
« Відповідей #1 : 2007-05-28 12:28:50 »
/etc/fstab в студію
Roman Suprotkin
Відсутній RyB
  • дописів: 27
  • Str8 Coding
« Відповідей #2 : 2007-05-28 13:48:26 »
# /etc/fstab: static file system information.
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
proc            /proc           proc    defaults        0       0
# /dev/sda3
UUID=3264d583-6fd3-4a88-adb8-d9e6cd11928c /               ext3    defaults,errors=remount-ro 0       1
# /dev/sda6
UUID=87db9fec-4927-4d85-879f-ac31f9a43835 none            swap    sw              0       0
/dev/scd0       /media/cdrom0   udf,iso9660 user,noauto     0       0
# UNCONFIGURED FSTAB FOR BASE SYSTEM
Відсутній rangel
  • дописів: 281
  • Python programmer
« Відповідей #3 : 2007-05-28 13:57:37 »
Є підозра, що тут прописано не зовсім коректно. Виясніть, як точно називається в системі cdrom. Не виключено, що існує symlink /dev/cdrom
Хм...  :)
Roman Suprotkin
« Відповідей #4 : 2007-05-28 14:30:09 »
Хм...  :)
Во-во... Раджу пану тричі перевірити fstab і сподіватись, що там таки є помилка (для початку приберіть "udf" з рядка про cd - це шкідливо). Інакше... Ну, є гіпотеза, що пан всім організмом став на граблі, по яких я недавно вже встиг добряче потоптатись (PATA Experimental support, собака... що там Майк Шигорін говорив про довіру дистроклепателям?).
Недавно дізнався, що подібне (повний або частковий відвал CD/DVD) трапляється не тільки в Zenwalk-4.6, а й в Feisty. В першому взагалі конфіг ядра майже під нуль скопійований з останнього, так що любителі ставити експерименти над користувачами саме в Ubuntu Team сидять, а Zenwalk Team їм радо підспівує. В такому випадку вас чекає ніч кохання з перезбіркою ядра, писанням правил для udev та масовою правкою конфігів. Інший варіант - встановити попередній реліз і просто проапгрейдити деякі пакети. Або взяти інший дистрибутив.
От що... надішліть вивід "dmesg | tail" після спроби змонтувати CD. Тоді можна буде сказати точно.
« Змінено: 2007-05-28 14:37:57 від Cthulhu »
« Відповідей #5 : 2007-05-28 14:37:10 »
У мене в Етчі fstsb виглядає саме так (тільки замість /dev/scd0 /dev/hdc). Симлінки: /cdrom -> media/cdrom -> cdrom0 .
Перевірте, чи працює монтування CD взагалі.
« Відповідей #6 : 2007-05-28 14:39:11 »
Я про це щойно цілу статтю написав=) Дебіанівці експериментів на користувачах не ставлять. Як і Патрік, між іншим...=)
Відсутній RyB
  • дописів: 27
  • Str8 Coding
« Відповідей #7 : 2007-05-28 15:28:14 »
Монтування СД працює виключно для користувача: користувач диск бачить, а система - ні!
Зараз зайду в Убунту, приберу
« Відповідей #8 : 2007-05-28 15:35:34 »
Нічого не зрозумів. Тобто диск таки монтується? Що значить "користувач бачить, система не бачить"?
Відсутній RyB
  • дописів: 27
  • Str8 Coding
« Відповідей #9 : 2007-05-28 15:59:57 »
Це означає, що користувач може змонтувати диск і його проглянути, а система на команду монтування СД, щоб його додати до списку видає:
ryb@RyB:~$ apt-cdrom add
Unmounting CD-ROM
Waiting for disc...
Mounting CD-ROM...
ryb@RyB:~$
dmesg | tail до монтування:
ryb@RyB:/etc$ dmesg | tail
[   72.935464] Bluetooth: Core ver 2.11
[   72.935603] NET: Registered protocol family 31
[   72.935608] Bluetooth: HCI device and connection manager initialized
[   72.935614] Bluetooth: HCI socket layer initialized
[   73.013350] Bluetooth: L2CAP ver 2.8
[   73.013358] Bluetooth: L2CAP socket layer initialized
[   73.094076] Bluetooth: RFCOMM socket layer initialized
[   73.094103] Bluetooth: RFCOMM TTY layer initialized
[   73.094107] Bluetooth: RFCOMM ver 1.8
[   80.818734] eth0: no IPv6 routers present
dmesg | tail після монтування диска:
[  622.676850] ISO 9660 Extensions: Microsoft Joliet Level 3
[  623.079982] ISO 9660 Extensions: RRIP_1991A
ryb@RyB:/etc$
« Відповідей #10 : 2007-05-28 16:04:35 »
Можете вважати, що вам пощастило (хоча дисків ви поки нарізати не пробували, тому може й не дуже). У всякому разі, дана проблема іншого характеру. Наприклад такого, що у вас просто не вистачає прав. Слід запускати "sudo apt-cdrom add".
« Змінено: 2007-05-28 16:04:59 від Cthulhu »
Відсутній RyB
  • дописів: 27
  • Str8 Coding
« Відповідей #11 : 2007-05-28 16:10:08 »
Результат той самий.  :(
« Відповідей #12 : 2007-05-28 16:46:42 »
М-дя. Почекайте, поки хтось з убунтоводів з'явиться, це явно щось специфічне. Як ви, вірогідно, помітили, в цій темі убунту тільки у вас=) Щодо sudo - це було лише припущення навмання ::)
Відсутній RyB
  • дописів: 27
  • Str8 Coding
« Відповідей #13 : 2007-05-28 16:52:42 »
А який дистрибютив ви мені порадите? Так щоб не потрібно було закачувати пакети відразу з Інтернету (в мене ВПН і його налаштування вимагає багато пакетів), а можна було встановити з диску?
І головне - щоб не було таких заморочок!
« Змінено: 2007-05-28 16:57:38 від RyB »
« Відповідей #14 : 2007-05-28 17:01:06 »
Я який дистрибютив ви мені порадите? Так щоб не потрібно було закачувати пакети відразу з Інтернету (в мене ВПН і його налаштування вимагає багато пакетів), а можна було встановити з диску?
Краще ще пошукайте на ubuntuforums, пограйтесь. Вірогідно, все фікситься дуже просто.
Щодо коробочних дистрів. IMO тут кожен має сам для себе знаходити. Можете взяти реліз Debian - система не зовсім bleeding edge, але ідеально вилизана і гарантовано працює, як очікується. Fedora-6 була геть нормальна, але з більш ранніми релізами в мене пов'язані погані асоціації. CentOS або RHEL - для роботи кращого просто не придумати.
