Автор Гілка: Проблеми після оновлення  (Прочитано 2411 раз)
Відсутній Вуйко з полонини
  • дописів: 181
Вирішив оновитися до Lenny. Оновлювався шляхом aptitude upgrade. Тепер хочу собі зібрати ядро...... а тут хоба:
#make menuconfig
[size=8]HOSTCC  scripts/basic/fixdep
scripts/basic/fixdep.c:107:23: error: sys/types.h: No such file or directory
scripts/basic/fixdep.c:108:22: error: sys/stat.h: No such file or directory
scripts/basic/fixdep.c:109:22: error: sys/mman.h: No such file or directory
scripts/basic/fixdep.c:110:20: error: unistd.h: No such file or directory
scripts/basic/fixdep.c:111:19: error: fcntl.h: No such file or directory
scripts/basic/fixdep.c:112:20: error: string.h: No such file or directory
scripts/basic/fixdep.c:113:20: error: stdlib.h: No such file or directory
scripts/basic/fixdep.c:114:19: error: stdio.h: No such file or directory
In file included from /usr/lib/gcc/i486-linux-gnu/4.2.3/include/syslimits.h:7,
                 from /usr/lib/gcc/i486-linux-gnu/4.2.3/include/limits.h:11,
                 from scripts/basic/fixdep.c:115:
/usr/lib/gcc/i486-linux-gnu/4.2.3/include/limits.h:122:61: error: limits.h: No such file or directory
scripts/basic/fixdep.c:116:19: error: ctype.h: No such file or directory
scripts/basic/fixdep.c:117:23: error: arpa/inet.h: No such file or directory
scripts/basic/fixdep.c: In function ‘usage’:
scripts/basic/fixdep.c:131: warning: implicit declaration of function ‘fprintf’
scripts/basic/fixdep.c:131: warning: incompatible implicit declaration of built-in function ‘fprintf’
scripts/basic/fixdep.c:131: error: ‘stderr’ undeclared (first use in this function)
scripts/basic/fixdep.c:131: error: (Each undeclared identifier is reported only once
scripts/basic/fixdep.c:131: error: for each function it appears in.)
scripts/basic/fixdep.c:132: warning: implicit declaration of function ‘exit’
scripts/basic/fixdep.c:132: warning: incompatible implicit declaration of built-in function ‘exit’
scripts/basic/fixdep.c: In function ‘print_cmdline’:
scripts/basic/fixdep.c:140: warning: implicit declaration of function ‘printf’
scripts/basic/fixdep.c:140: warning: incompatible implicit declaration of built-in function ‘printf’
scripts/basic/fixdep.c: At top level:
scripts/basic/fixdep.c:143: error: ‘NULL’ undeclared here (not in a function)
scripts/basic/fixdep.c: In function ‘grow_config’:
scripts/basic/fixdep.c:156: warning: implicit declaration of function ‘realloc’
scripts/basic/fixdep.c:156: warning: assignment makes pointer from integer without a cast
scripts/basic/fixdep.c:158: warning: implicit declaration of function ‘perror’
scripts/basic/fixdep.c:158: warning: incompatible implicit declaration of built-in function ‘exit’
scripts/basic/fixdep.c: In function ‘is_defined_config’:
scripts/basic/fixdep.c:174: warning: implicit declaration of function ‘memcmp’
scripts/basic/fixdep.c: In function ‘define_config’:
scripts/basic/fixdep.c:187: warning: implicit declaration of function ‘memcpy’
scripts/basic/fixdep.c:187: warning: incompatible implicit declaration of built-in function ‘memcpy’
scripts/basic/fixdep.c: In function ‘use_config’:
scripts/basic/fixdep.c:206: error: ‘PATH_MAX’ undeclared (first use in this function)
scripts/basic/fixdep.c:214: warning: incompatible implicit declaration of built-in function ‘memcpy’
scripts/basic/fixdep.c:220: warning: implicit declaration of function ‘tolower’
scripts/basic/fixdep.c:222: warning: incompatible implicit declaration of built-in function ‘printf’
scripts/basic/fixdep.c:206: warning: unused variable ‘s’
scripts/basic/fixdep.c:225: error: expected declaration specifiers or ‘...’ before ‘size_t’
scripts/basic/fixdep.c: In function ‘parse_config_file’:
scripts/basic/fixdep.c:227: error: ‘len’ undeclared (first use in this function)
scripts/basic/fixdep.c:233: warning: implicit declaration of function ‘ntohl’
scripts/basic/fixdep.c:244: warning: implicit declaration of function ‘isalnum’
scripts/basic/fixdep.c: In function ‘strrcmp’:
scripts/basic/fixdep.c:261: warning: implicit declaration of function ‘strlen’
scripts/basic/fixdep.c:261: warning: incompatible implicit declaration of built-in function ‘strlen’
scripts/basic/fixdep.c: In function ‘do_config_file’:
scripts/basic/fixdep.c:272: error: storage size of ‘st’ isn’t known
scripts/basic/fixdep.c:276: warning: implicit declaration of function ‘open’
scripts/basic/fixdep.c:276: error: ‘O_RDONLY’ undeclared (first use in this function)
scripts/basic/fixdep.c:278: warning: incompatible implicit declaration of built-in function ‘fprintf’
scripts/basic/fixdep.c:278: error: ‘stderr’ undeclared (first use in this function)
scripts/basic/fixdep.c:280: warning: incompatible implicit declaration of built-in function ‘exit’
scripts/basic/fixdep.c:282: warning: implicit declaration of function ‘fstat’
scripts/basic/fixdep.c:284: warning: implicit declaration of function ‘close’
scripts/basic/fixdep.c:287: warning: implicit declaration of function ‘mmap’
scripts/basic/fixdep.c:287: error: ‘PROT_READ’ undeclared (first use in this function)
scripts/basic/fixdep.c:287: error: ‘MAP_PRIVATE’ undeclared (first use in this function)
scripts/basic/fixdep.c:287: warning: assignment makes pointer from integer without a cast
scripts/basic/fixdep.c:294: error: too many arguments to function ‘parse_config_file’
scripts/basic/fixdep.c:296: warning: implicit declaration of function ‘munmap’
scripts/basic/fixdep.c:272: warning: unused variable ‘st’
scripts/basic/fixdep.c:301: error: expected declaration specifiers or ‘...’ before ‘size_t’
scripts/basic/fixdep.c: In function ‘parse_dep_file’:
scripts/basic/fixdep.c:304: error: ‘len’ undeclared (first use in this function)
scripts/basic/fixdep.c:306: error: ‘PATH_MAX’ undeclared (first use in this function)
scripts/basic/fixdep.c:308: warning: implicit declaration of function ‘strchr’
scripts/basic/fixdep.c:308: warning: incompatible implicit declaration of built-in function ‘strchr’
scripts/basic/fixdep.c:310: warning: incompatible implicit declaration of built-in function ‘fprintf’
scripts/basic/fixdep.c:310: error: ‘stderr’ undeclared (first use in this function)
scripts/basic/fixdep.c:311: warning: incompatible implicit declaration of built-in function ‘exit’
scripts/basic/fixdep.c:313: warning: incompatible implicit declaration of built-in function ‘memcpy’
scripts/basic/fixdep.c:314: warning: incompatible implicit declaration of built-in function ‘printf’
scripts/basic/fixdep.c:306: warning: unused variable ‘s’
scripts/basic/fixdep.c: In function ‘print_deps’:
scripts/basic/fixdep.c:343: error: storage size of ‘st’ isn’t known
scripts/basic/fixdep.c:347: error: ‘O_RDONLY’ undeclared (first use in this function)
scripts/basic/fixdep.c:349: warning: incompatible implicit declaration of built-in function ‘fprintf’
scripts/basic/fixdep.c:349: error: ‘stderr’ undeclared (first use in this function)
scripts/basic/fixdep.c:351: warning: incompatible implicit declaration of built-in function ‘exit’
scripts/basic/fixdep.c:355: warning: incompatible implicit declaration of built-in function ‘fprintf’
scripts/basic/fixdep.c:359: error: ‘PROT_READ’ undeclared (first use in this function)
scripts/basic/fixdep.c:359: error: ‘MAP_PRIVATE’ undeclared (first use in this function)
scripts/basic/fixdep.c:359: warning: assignment makes pointer from integer without a cast
scripts/basic/fixdep.c:366: error: too many arguments to function ‘parse_dep_file’
scripts/basic/fixdep.c:343: warning: unused variable ‘st’
scripts/basic/fixdep.c: In function ‘traps’:
scripts/basic/fixdep.c:378: warning: incompatible implicit declaration of built-in function ‘fprintf’
scripts/basic/fixdep.c:378: error: ‘stderr’ undeclared (first use in this function)
scripts/basic/fixdep.c:380: warning: incompatible implicit declaration of built-in function ‘exit’
make[1]: *** [scripts/basic/fixdep] Помилка 1
make: *** [scripts_basic] Помилка 2[/size]
Просто не уявляю що робити, бо оновлювався вперше, і з такою проблемою також вперше стикаюся.
Варто зробити dist-upgrade?
« Змінено: 2008-01-14 18:35:08 від body »
  • дописів: 181
Re: Проблеми після оновлення
« Відповідей #1 : 2008-01-14 22:34:32 »
Панове, мені необхідна допомога....
« Відповідей #2 : 2008-01-15 00:00:05 »
При переході з гілки на гілку dist-upgrade треба робити обов'язково - інакше буде оновлено не усі пакунки.
  • дописів: 181
« Відповідей #3 : 2008-01-15 00:09:27 »
Дякую. Я так і здогадувався, але все ж 1Gb трафіка трохи жалко. Добре хоч Воля дає нічний безліміт - завтра буду пробувати.
  • дописів: 181
« Відповідей #4 : 2008-01-15 16:21:55 »
Оновився шляхом aptitude dist-upgrade. Нічого не змінилося? Що це в мене таке???
Відсутній Fakel._Enterpuer
  • дописів: 164
  • Debian Gnu/Linux
« Відповідей #5 : 2008-01-26 22:28:53 »
попробуй превстановити kernel-headers/linux-image (наприклад 2.6.18.4-686)
взагалі це пролбема з загаловними файлами.
І далі можеш компілювати своє ядро.
LUG irc.id.km.ua
Відсутній smeegul
  • дописів: 5
  • Debian
« Відповідей #6 : 2008-01-27 13:03:18 »
до Дебіана входить пакунок apt-file , який шукає у Contents файлах до якого пакунку належить той чи інший файл
apt-file     update                      Fetch Contents files from apt-sources.
apt-file     search|find <pattern>       Search files in packages
пошукайте ним ті файли на які видається помилка No such file or directory
і встановіть необхідні пакунки
я збираю ядро так:
aptitude install linux-source-2.?.?? dpkg-dev fakeroot kernel-package
де ?.?? версія ядра яка вам потрібна
cd /usr/src/
tar xvvjf linux-source-2.?.??.tar.bz2
ln -s linux-source-2.?.?? linux
cd /usr/src/linux/
make menuconfg
dpkg-buildpackage -rfakeroot -uc -b -d
Відсутній Сашко Кравчук
  • дописів: 490
  • Debian GNU/Linux
« Відповідей #7 : 2008-01-28 14:28:37 »
apt-get install build-essential
А також linux-headers-*, якщо ядро Дебіенівське. Мо' пофартить! :)
