Автор Гілка: E: Sub-process /usr/bin/dpkg returned an error cod  (Прочитано 2877 раз)
Відсутній linex
  • дописів: 55
Виникла проблема з Debian Etch:
debian:/home/lin# apt-get dist-upgrade
Читання переліків пакетів... Виконано
Побудова дерева залежностей... Виконано
Обчислення оновлень... Виконано
оновлено 0, встановлено 0 нових пакунків, для видалення відмічено 0 пакунків, і 0 пакунків не оновлено.
не встановлено до кінця чи видалено 29 пакунків.
After this operation, 0B of additional disk space will be used.
Бажаєте продовжити [Т/н]? y
Setting up docbook-xml (4.5-5) ...
update-xmlcatalog: error: entity already registered
dpkg: error processing docbook-xml (--configure):
 subprocess post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of scrollkeeper:
 scrollkeeper depends on docbook-xml (>= 4.2-11); however:
  Package docbook-xml is not configured yet.
dpkg: error processing scrollkeeper (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of bug-buddy:
 bug-buddy depends on scrollkeeper; however:
  Package scrollkeeper is not configured yet.
dpkg: error processing bug-buddy (--configure):
dpkg: dependency problems prevent configuration of capplets-data:
 capplets-data depends on scrollkeeper; however:
dpkg: error processing capplets-data (--configure):
dpkg: dependency problems prevent configuration of gnome-panel-data:
 gnome-panel-data depends on scrollkeeper; however:
dpkg: error processing gnome-panel-data (--configure):
dpkg: dependency problems prevent configuration of gnome-control-center:
 gnome-control-center depends on capplets-data (>= 1:2.22); however:
  Package capplets-data is not configured yet.
 gnome-control-center depends on capplets-data (<< 1:2.23); however:
dpkg: error processing gnome-control-center (--configure):
dpkg: dependency problems prevent configuration of gnome-panel:
 gnome-panel depends on gnome-panel-data (>= 2.20); however:
  Package gnome-panel-data is not configured yet.
 gnome-panel depends on gnome-panel-data (<< 2.21); however:
 gnome-panel depends on gnome-control-center (>= 1:2.8.2-3); however:
  Package gnome-control-center is not configured yet.
dpkg: error processing gnome-panel (--configure):
dpkg: dependency problems prevent configuration of fast-user-switch-applet:
 fast-user-switch-applet depends on gnome-panel; however:
  Package gnome-panel is not configured yet.
dpkg: error processing fast-user-switch-applet (--configure):
dpkg: dependency problems prevent configuration of gedit:
 gedit depends on scrollkeeper; however:
dpkg: error processing gedit (--configure):
dpkg: dependency problems prevent configuration of synaptic:
 synaptic depends on scrollkeeper; however:
dpkg: error processing synaptic (--configure):
dpkg: dependency problems prevent configuration of gnome-app-install:
 gnome-app-install depends on synaptic (>= 0.57.8); however:
  Package synaptic is not configured yet.
dpkg: error processing gnome-app-install (--configure):
dpkg: dependency problems prevent configuration of gnome-applets-data:
 gnome-applets-data depends on scrollkeeper; however:
dpkg: error processing gnome-applets-data (--configure):
dpkg: dependency problems prevent configuration of gnome-applets:
 gnome-applets depends on gnome-applets-data (>= 2.22); however:
  Package gnome-applets-data is not configured yet.
 gnome-applets depends on gnome-applets-data (<< 2.23); however:
 gnome-applets depends on gnome-panel (>= 2.13.4); however:
dpkg: error processing gnome-applets (--configure):
dpkg: dependency problems prevent configuration of gnome-session:
 gnome-session depends on gnome-control-center (>= 1:2.22); however:
dpkg: error processing gnome-session (--configure):
dpkg: dependency problems prevent configuration of gnome-terminal:
 gnome-terminal depends on scrollkeeper; however:
dpkg: error processing gnome-terminal (--configure):
dpkg: dependency problems prevent configuration of nautilus-data:
 nautilus-data depends on scrollkeeper; however:
dpkg: error processing nautilus-data (--configure):
dpkg: dependency problems prevent configuration of nautilus:
 nautilus depends on nautilus-data (>= 2.20); however:
  Package nautilus-data is not configured yet.
 nautilus depends on nautilus-data (<< 2.21); however:
 nautilus depends on gnome-control-center (>= 2.6); however:
dpkg: error processing nautilus (--configure):
dpkg: dependency problems prevent configuration of yelp:
 yelp depends on docbook-xml (>= 4.1.2); however:
dpkg: error processing yelp (--configure):
dpkg: dependency problems prevent configuration of gnome-core:
 gnome-core depends on gnome-control-center (>= 1:2.22.2.1); however:
 gnome-core depends on gedit (>= 2.22.3); however:
  Package gedit is not configured yet.
 gnome-core depends on gnome-applets (>= 2.22.2); however:
  Package gnome-applets is not configured yet.
 gnome-core depends on gnome-panel (>= 2.20.3); however:
 gnome-core depends on gnome-session (>= 2.22.2); however:
  Package gnome-session is not configured yet.
 gnome-core depends on gnome-terminal (>= 2.22.2); however:
  Package gnome-terminal is not configured yet.
 gnome-core depends on nautilus (>= 2.20.0); however:
  Package nautilus is not configured yet.
 gnome-core depends on rarian-compat | scrollkeeper; however:
  Package rarian-compat is not installed.
 gnome-core depends on yelp (>= 2.22.1); however:
  Package yelp is not configured yet.
dpkg: error processing gnome-core (--configure):
dpkg: dependency problems prevent configuration of gnome-system-monitor:
 gnome-system-monitor depends on scrollkeeper; however:
dpkg: error processing gnome-system-monitor (--configure):
dpkg: dependency problems prevent configuration of gnome-user-guide:
 gnome-user-guide depends on scrollkeeper; however:
 gnome-user-guide depends on yelp; however:
dpkg: error processing gnome-user-guide (--configure):
dpkg: dependency problems prevent configuration of gnome-utils:
 gnome-utils depends on scrollkeeper; however:
dpkg: error processing gnome-utils (--configure):
dpkg: dependency problems prevent configuration of gucharmap:
 gucharmap depends on scrollkeeper; however:
dpkg: error processing gucharmap (--configure):
dpkg: dependency problems prevent configuration of nautilus-cd-burner:
 nautilus-cd-burner depends on nautilus; however:
dpkg: error processing nautilus-cd-burner (--configure):
dpkg: dependency problems prevent configuration of zenity:
 zenity depends on scrollkeeper; however:
dpkg: error processing zenity (--configure):
dpkg: dependency problems prevent configuration of gnome-desktop-environment:
 gnome-desktop-environment depends on gnome-core (= 1:2.22.2~4); however:
  Package gnome-core is not configured yet.
 gnome-desktop-environment depends on fast-user-switch-applet (>= 2.22.0); however:
  Package fast-user-switch-applet is not configured yet.
 gnome-desktop-environment depends on gnome-system-monitor (>= 2.22.2); however:
  Package gnome-system-monitor is not configured yet.
 gnome-desktop-environment depends on gnome-user-guide (>= 2.22.1); however:
  Package gnome-user-guide is not configured yet.
 gnome-desktop-environment depends on gnome-utils (>= 2.20.0.1); however:
  Package gnome-utils is not configured yet.
 gnome-desktop-environment depends on gucharmap (>= 1:2.22.1); however:
  Package gucharmap is not configured yet.
 gnome-desktop-environment depends on nautilus-cd-burner (>= 2.20.0); however:
  Package nautilus-cd-burner is not configured yet.
 gnome-desktop-environment depends on zenity (>= 2.22.1); however:
  Package zenity is not configured yet.
dpkg: error processing gnome-desktop-environment (--configure):
dpkg: dependency problems prevent configuration of gnome-office:
 gnome-office depends on gnome-core (= 1:2.22.2~4); however:
dpkg: error processing gnome-office (--configure):
dpkg: dependency problems prevent configuration of planner:
 planner depends on scrollkeeper; however:
dpkg: error processing planner (--configure):
dpkg: dependency problems prevent configuration of xorg:
 xorg depends on xterm | x-terminal-emulator; however:
  Package xterm is not installed.
  Package x-terminal-emulator is not installed.
  Package gnome-terminal which provides x-terminal-emulator is not configured yet.
dpkg: error processing xorg (--configure):
Errors were encountered while processing:
 docbook-xml
 scrollkeeper
 bug-buddy
 capplets-data
 gnome-panel-data
 gnome-panel
 gedit
 synaptic
 gnome-app-install
 gnome-applets-data
 gnome-applets
 gnome-session
 gnome-terminal
 nautilus-data
 nautilus
 yelp
 gnome-core
 gnome-user-guide
 gnome-utils
 gucharmap
 nautilus-cd-burner
 zenity
 gnome-office
 planner
 xorg
E: Sub-process /usr/bin/dpkg returned an error code (1)
debian:/home/lin#
Re: E: Sub-process /usr/bin/dpkg returned an error cod
« Відповідей #1 : 2008-09-08 17:03:04 »
apt-get -f install
Відсутній linex
  • дописів: 55
« Відповідей #2 : 2008-09-08 17:11:35 »
apt-get -f install
Проблему не вирішило...
Відсутній nickat
  • дописів: 587
  • Debian user
« Відповідей #3 : 2008-09-10 01:45:23 »
Bug#482140
Там є декілька способів обійти проблему.
Було б також добре, якщо б ти зробив архів твого http:///etc/xml та додав його до цього багрепорту.
« Змінено: 2008-09-10 02:10:31 від nickat »
Best regards,
nickat
Відсутній linex
  • дописів: 55
« Відповідей #4 : 2008-09-11 01:25:23 »
Вирішив проблему.
Виглядало це приблизно так:
- editing my /etc/apt/sources.list to switch back to etch
- apt-get remove docbook-xml (complains many times about
update-xmlcatalog: error: entity not registered )
- apt-get update
- apt-get install docbook-xml
- editing /etc/apt/sources.list to update to testing
- apt-get update
- apt-get dist-upgrade
