Автор Гілка: Ubuntu mke2fs не підтримує ext4  (Прочитано 1814 раз)
Відсутній peinguin
  • дописів: 1422
Ubuntu Hardy. Може її оновити?
Тоді як?
cat sources.list
# deb cdrom:[Ubuntu-Server 8.04.1 _Hardy Heron_ - Release i386 (20080701)]/ hardy main restricted
#deb cdrom:[Ubuntu-Server 8.04.1 _Hardy Heron_ - Release i386 (20080701)]/ hardy main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://ge.archive.ubuntu.com/ubuntu/ hardy main restricted
deb-src http://ge.archive.ubuntu.com/ubuntu/ hardy main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://ge.archive.ubuntu.com/ubuntu/ hardy-updates main restricted
deb-src http://ge.archive.ubuntu.com/ubuntu/ hardy-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
deb http://ge.archive.ubuntu.com/ubuntu/ hardy universe
deb-src http://ge.archive.ubuntu.com/ubuntu/ hardy universe
deb http://ge.archive.ubuntu.com/ubuntu/ hardy-updates universe
deb-src http://ge.archive.ubuntu.com/ubuntu/ hardy-updates universe
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://ge.archive.ubuntu.com/ubuntu/ hardy multiverse
deb-src http://ge.archive.ubuntu.com/ubuntu/ hardy multiverse
deb http://ge.archive.ubuntu.com/ubuntu/ hardy-updates multiverse
deb-src http://ge.archive.ubuntu.com/ubuntu/ hardy-updates multiverse
## Uncomment the following two lines to add software from the 'backports'
## repository.
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb http://ge.archive.ubuntu.com/ubuntu/ hardy-backports main restricted universe multiverse
# deb-src http://ge.archive.ubuntu.com/ubuntu/ hardy-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository. This software is not part of Ubuntu, but is
## offered by Canonical and the respective vendors as a service to Ubuntu
## users.
# deb http://archive.canonical.com/ubuntu hardy partner
# deb-src http://archive.canonical.com/ubuntu hardy partner
deb http://security.ubuntu.com/ubuntu hardy-security main restricted
deb-src http://security.ubuntu.com/ubuntu hardy-security main restricted
deb http://security.ubuntu.com/ubuntu hardy-security universe
deb-src http://security.ubuntu.com/ubuntu hardy-security universe
deb http://security.ubuntu.com/ubuntu hardy-security multiverse
deb-src http://security.ubuntu.com/ubuntu hardy-security multiverse
Re: Ubuntu mke2fs не підтримує ext4
« Відповідей #1 : 2010-12-15 21:51:22 »
mkfs.ext4 ?
Відсутній peinguin
  • дописів: 1422
« Відповідей #2 : 2010-12-15 21:52:48 »
mkfs.ext4
[1]+  Stopped                 mkfs.ext4
mkfs.ext3
Usage: mkfs.ext3 [-c|-l filename] [-b block-size] [-f fragment-size]
        [-i bytes-per-inode] [-I inode-size] [-J journal-options]
        [-N number-of-inodes] [-m reserved-blocks-percentage] [-o creator-os]
        [-g blocks-per-group] [-L volume-label] [-M last-mounted-directory]
        [-O feature[,...]] [-r fs-revision] [-E extended-option[,...]]
        [-T fs-type] [-jnqvFSV] device [blocks-count]
root@mail:~#
« Змінено: 2010-12-15 21:53:38 від peinguin »
Відсутній sigito
  • дописів: 105
« Відповідей #3 : 2010-12-17 00:34:36 »
можна й не обновляться, всього-на-всього обновити деякі пакуник.
Якщо взяти до уваги розділ про Убунту із даної статті, то треба тільки поставить  запропоновані версії пакунків, які можна скачати тут. (Зазначений каталог в статті перемістився)
« Змінено: 2010-12-17 00:35:01 від sigito »
Debian/wheezy x86_64, lxde
